Which Ultra Wide Angle?
Started Sep 16, 2014 | Questions
Abu Mahendra Veteran Member • Posts: 5,312
Re: Which Ultra Wide Angle?
DannH wrote:
My vote goes to the Tokina 11-16. Well built, superb IQ, fast aperture, can't fault it.
Well, very strong CA, very bad trying to focus with live view contrast detect AF. That is two faults
If you don't care about the f/2.8 then the Canon 10-18mm is prob best overall deal with the price.
...and, like all Tokinas, neanderthal flare performance. How one can recommend the Tokina as the top IQ when it suffers from such dramatic flaws is inconceivable.
>> I love the Canon EF-M 11-22mm f/4-5.6 IS STM lens! <<
 Abu Mahendra's gear list:Abu Mahendra's gear list
Canon EF 100mm F2.8L Macro IS USM Canon EF 70-200mm F2.8L IS II USM Canon EF 70-200mm F4L IS USM Canon EF 24-70mm F2.8L II USM Canon EF 40mm f/2.8 STM +5 more
DannH Contributing Member • Posts: 642
The flare is way over exaggerated. Just returned from a trip and shot over 3000 photo's. Not one had flare in it... Maybe if you was shooting directly in to the sun at midday sure, but if you plan on using it for sunsets etc then it's not an issue.
Right. It's all in my head.
brightcolours Forum Pro • Posts: 15,885
I tend to use manual for landscape shots so I can't comment on the live view AF, but CA has hardly ever been a problem. Certainly no more than any other lens I own.
Then you own only unusually strong CA-ing lenses....
To quote:
"The lateral chromatic aberration is a more serious problem, and I do mean serious here. In fact you can describe it with just one word: monstrous."
"So far things looked bright but the lens has also a problem - lateral chromatic aberrations - visible as color shadows at harsh contrast transitions. The characteristic is uniformly high across the range with an average pixel width at 2.1-2.6px at the image borders. A typical flaw found in many Tokina lenses actually."'
"A huge level of chromatic aberration is a nightmare of wide angle Tokinas. The predecessor of the tested lens had big problems in this category as well, so did many other instruments (it’s enough to mention here the 12-24 mm, the 16-50 mm or the 16.5-135 mm lenses). It’s high time the producer did something with that aberration because the rivals deal with it much better."
