OP
Altruisto
Contributing Member
Re: Already FULL SIZE LEAKED sample images from the G7 X!
technic wrote:
Altruisto wrote:
What do you think guys?
not bad, but certainly not convincing. I too see lots of processing, e.g. if you look from center to corner in the WA shot; it's a bit similar to what I noticed on S110, only the noise performance is better (of course, thanks to the smaller sensor).
The tele shot looks a bit soft even at f/5.6 but it may be better than an upsampled 75mm shot The soft rendering at f/2.8 100mm was to be expected, just like the G1X II; as this is mostly for portraits, you could consider it a build-in 'soft focus filter'
For a real impression what the camera can do we need to see high quality RAW images, that might take a while. The question is if you can improve the image quality with standard RAW processing (instead of fine-tuning for focal length and aperture issues); Canon JPEG output in compacts is usually pretty good. On the S110 I could make significant improvements compared to JPEG when working from RAW, but it usually required finetuning which takes too much time for general use.
But ... given how bad many Canon sample images are maybe this is promising Btw, the images on the G7X website looked VERY convincing, although those were much lower res. PP or even just sharpness/tone curve etc. settings are very important ...
P.S.: the close up shot (locks) looks soft with artificial sharpness in some areas, just like the RX100-1/2 'macro' shots. The noise and noise processing (sensor feature?) makes it even more apparent.
Yeah, that ambitious lens had to falter somewhere. I think there are a lot of software corrections going on here for distortion, fringing, lack of sharpness, aberrations,... We prefer when the opticians do the job. When of the best compact lenses I have tried are in Nikon P7800 and Olympus XZ-2. The results were just "innately" good. G7 X had to involves compromises, but to which point? Being too ambitious is sometimes not rewarding.
We'll wait for other samples, but the "75mm at the long end" camera you referred to, could have a well corrected lens, since it's not squeezing the camera size at all price (and judging by LX7 standards).
I don't think the wide open performance at 100mm is acceptable since it's meant for portraits, as many people want more zoom, and were willing to crop those generous 20MP to get further. I remember one "ambitious" guy speaking of decent 5MP files at 200mm equivalent.
