need a fast, ultra wide, full frame lens. something under 20mm.
Started Sep 10, 2014 | Questions
solomonshv Junior Member • Posts: 41
i currently have a canon 16-35 f/2.8L II. while i like the lens mostly, sometimes the images are softer than i would like them to be. and the distortion is just ridiculous at smaller focal lengths.
i'm looking to upgrade to something better. don't care if it is prime or zoom, auto focus or full manual. i just need the best image possible with a 5D Mark III and i need it to be under 20mm.
i looked at the Carl Zeiss 15mm Distagon T* f/2.8 ZE. i'm thinking that may be my best option. but before i plunk down such a stupid amount of money for what is nothing more than hobby, i want to know if it is worth it.
are there any other suggestions that i may have missed?
thanks
 solomonshv's gear list:solomonshv's gear list
Sony a7R II Canon EF 70-200mm F2.8L IS II USM Sony FE 24-70mm F2.8 GM Sony FE 85mm F1.4 GM Zeiss Batis 18mm F2.8 +2 more
Canon EF 16-35mm F2.8L II USM Canon EOS 5D Mark III Carl Zeiss Distagon T* 2,8/15
Rick Knepper
Rick Knepper Forum Pro • Posts: 17,870
Re: need a fast, ultra wide, full frame lens. something under 20mm.
thanks
I rejected the Zeiss 15mm ZE for not being sharp in the corners for a lens that, as you say, costs "stupid money".
Have you checked out the 16-35/4 IS. Slower but...your only other decent choices that might beat the 16-35 II in the Canon brand are the 14/2.8 II, the TSE-17 or maybe one of the fish-eyes.
For the price of the Zeiss, you could buy the latest APS-C camera (7D 2?) and try the EF-S 10-22 or 18-something or druther or the 18-35/1.8 by some3rd party  manf whose name escapes me.
Rick Knepper, photographer, shooting for pleasure. It is better to have It and not need It than need It and not have It. Various RAW comparisons at Link below. Includes 5D3 vs D800E (new uploads), 5D3 vs. 6D, Zeiss lenses etc. https://app.box.com/s/71w40ita6hrcfghojaie
 Rick Knepper's gear list:Rick Knepper's gear list
Pentax 645Z Canon EOS 5DS R Fujifilm GFX 50S Sony a7R IV Pentax smc D FA 645 55mm F2.8 AL (IF) SDM AW +11 more
Abu Mahendra Veteran Member • Posts: 5,312
Forget the 17TS-E. At f/4 it ain't fast, and the 16-35IS is just as sharp (source: Lensrentals Blog testing).
>> I love the Canon EF-M 11-22mm f/4-5.6 IS STM lens! <<
 Abu Mahendra's gear list:Abu Mahendra's gear list
Canon EF 100mm F2.8L Macro IS USM Canon EF 70-200mm F2.8L IS II USM Canon EF 70-200mm F4L IS USM Canon EF 24-70mm F2.8L II USM Canon EF 40mm f/2.8 STM +5 more
hotdog321
hotdog321 Forum Pro • Posts: 21,141
I've used the new 16-35 f/4L IS several times under really cruddy light and been delighted. My old 16-35 f/2.8 (version 1) has been relegated to a drawer for backup duty. Center sharpness is similar to the 24-70 f/2.8L II and the corners/edges are light years better than the 16-35 f/2.8.
In theory I want the lens to be f/2.8 to match the rest of my lens lineup, but I honestly have not missed the extra stop.
photojournalist
 hotdog321's gear list:hotdog321's gear list
Canon EOS 5D Mark IV Canon EF 100mm f/2.8 Macro USM Canon EF 70-200mm F2.8L IS II USM Canon EF 24-70mm F2.8L II USM Canon EF 16-35mm F4L IS USM +3 more
ericktodd
ericktodd Regular Member • Posts: 416
The 16-35 doesn't have much distortion, its considered a pretty clean lens from the distortion side.
Unless yours is unusually bad, you are probably talking about "distortion" from being Ultra Wide Angle (which is not distortion, is just the extreme stretching and exaggeration that happens with super wide angle lenses).
So you should know that the greatest optical 15mm lens in the world will have the identical exaggeration as your 16mm (except even worse since 15mm is wider) as you see it.
Tilt Shift is your only real option if you want to improve the natural exaggeration of wide angle lenses, and even then it won't be perfect.
 ericktodd's gear list:ericktodd's gear list
Sony a7R IV Sony FE 35mm F2.8 Sony FE 55mm F1.8 Sony FE 70-200mm F2.8 GM OSS Sony FE 85mm F1.8 +5 more
oscarvdvelde Senior Member • Posts: 1,420
If you want fast, you will get not wide enough choices, like 24mm f/1.4, or the Sigma 20mm f/1.8. The latter is useful and sharp but does exhibit odd star shapes in the corners in night shots. My Tokina 16-28mm f/2.8 is wider, very low vignetting and distortion, but can't be reliably focused at infinity, and also isn't so sharp wide open. The Samyang 14mm f/2.8 is apparently very good wide open though it vignettes and has crazy distortion.
Other options are fisheyes. Canon and Sigma 15mm f/2.8 and maybe the new Samyang 12mm f/2.8 for full frame. In my experience the Samyang 8mm for APS-C is not so sharp wide open, I hope the new model is... It has stereographic projection which feels natural, with curved lines but every small object retaining its natural shape without compression near the edges, unlike equidistant and equisolid projections, or stretching like rectilinear wide angle lenses.
 oscarvdvelde's gear list:oscarvdvelde's gear list
Fujifilm X-T3 Fujifilm XF 27mm F2.8 Samyang 12mm F2.0 NCS CS Fujifilm XF 16mm F1.4 R WR Samyang 50mm F1.2 +4 more
rowlandw Regular Member • Posts: 386
Samyang 14mm f/2.8. I own it.  Very sharp for the money but lots of distortion.  Not so bad if you keep horizontal lines bisecting the frame.
 rowlandw's gear list:rowlandw's gear list
Olympus C-3020 Zoom Canon PowerShot S100 Canon PowerShot SX40 HS Panasonic Lumix DMC-LX7 Panasonic Lumix DMC-FZ70 +5 more
Peter too Contributing Member • Posts: 909
The TSE 17mm is very good, sharp corner to corner, good colour and has the TS functions as an added bonus. However to get the best out of you need to take time setting it up and use a good tripod.
OP solomonshv Junior Member • Posts: 41
i'm guessing it is due to the IS? i'll give it a whirl. since i don't use my wide angle lens at night the aperture shouldn't matter too much. and i too would like to have a wide angle that matches the aperture of my other lenses. but oh well.
brightcolours Forum Pro • Posts: 15,885
Why??
but oh well.
hotdog321
In truth, I always had to stop my old 16-35 f/2.8 down to f/4 or f/4.5 anyway to achieve decent edge results, so the new f/4 16-35 is fine for real world shooting. The IS function is quite useful if the subject isn't jumping around too much.
photojournalist
chinch Senior Member • Posts: 1,731
What are you shooting?
I own this lens and don't see the "distortion" you are referring to. As stated by others maybe it's the UWA perspective throwing you off. This requires care when shooting and can benefit from perspective tweaks. If i really wanted sharper corners the 16-35/4IS would be the obvious choice but all the same "distortion" would apply to any lens 16mm or less obviously.
Lightroom has nice lens corrections for the 16-35II which work great making any issues with it moot imho anyways. maybe you should try using them before buying new glass.
thanks
 chinch's gear list:chinch's gear list
Canon EOS 5D Mark III Canon EF 85mm F1.8 USM Canon EF 24-70mm f/2.8L USM Canon EF 70-200mm F4L USM Canon EF 100-400mm f/4.5-5.6L IS USM +4 more
Dan_168 Forum Pro • Posts: 11,055
Quite a few options out there
thanks
Zeiss 15 is definitely one option, but a pricey one. Another good one is the Zeiss 21mm, well, not under 20mm but close enough, it's my all time favorite landscape lens.Talking about Zeiss, I would stay away from Zeiss 18 though, not in the same league as their 21mm.
Another good one is the TSE-17, I actually use this lens even more than my Zeiss 21, the T/S is really really handy when you want to control your foreground/background focusing, also for interior and tall buildings, very versatile lens, but of course it's not a point and shoot lens, it takes time and effort to get the most out of it, but if you do spend the time to learn the lens and use it right you will get result you simply can't with other lenses, to me this lens is optically as great as the Zeiss 21 even without T/S, and it's absolutely SHARP edge to edge, even with maximum tilt, it still have better edge than the 16-35L F2.8.
Another option is the Samyang 14mm, a dirt cheap option actually, I love mine and use it a lot even I have the Zeiss and TSE, I mainly use it for night photo, shooting MilkyWay, it beats all my other lens in this specific application, because it has very very low Coma Aberration, very important for night photography, very sharp lens even wide open, it has more distortion than the other two mentioned, but for this specific application, distortion is none issue, I don't even need to do any distortion correction.
One more option is the newer 16-35 F4 IS, seems to be day and night sharper lens than the 16-35 F2.8 II, by the way I owned that 16-35L 2.8 II and the 17-40L at one point as well but sold that long time ago and never missed them, I will also give this 16-35 F4 IS a try myself, seems to be a winner if you don't need fast aperture.
And if you do need great optic quality and fast aperture, there is a Nikon 14-24 F2.8G, you can use it on Canon with adapter, I used mine this way for years before the D800E came out, I was really please with it, a fast zoom with a quality of a high quality prime, actually better than a lot of primes, at least is quite a bit better than the 14L II I tries.
Again if large aperture is one of your concern, since you said you are fine with MF, the new Nikon 20 F1.8 they just announced last night may fit your bill, it's pretty cheap for a 20mm 1.8 lens (if optic quality is good), under $800 USD. I have it pre-Ordered already, I am really looking for a FAST WIDE lens for astrophotography, and I don't use tracker, so faster the better wider the better, the Samyang 14 is wide but not as fast, and this new 20mm is faster but not as wide, so compromise again.
NancyP Veteran Member • Posts: 6,608
Samyang 14mm f/2.8  - this is a decent astrophotography lens, little coma, corners reasonably sharp at f/2.8, better at f/3.5 to f/4. $300.00
Canon 15mm L f/2.8
Zeiss 15mm f/2.8
Canon 16-35 f/2.8 L II
Nikon 14-24mm f/2.8 with adapter
That's it for the f/2.8s
If you can deal with f/4:
Canon 16-35mm f/4 L, brand new
Canon TS-E 17mm f/4 (widest TS-E available from any manufacturer)
NancyP
 NancyP's gear list:NancyP's gear list
Sigma DP3 Merrill
