LCD on my K5-IIs is over bright
Started Sep 6, 2014 | Questions
yudi Regular Member • Posts: 484
I usually shoot with M mode by setting the exposure according to the position of EV bar in OVF. And I used to having the EV bar at -1 (under exposure), and Auto EV Compensation OFF.
Everything was OK until one day of last month, when I found the LCD on my K5-IIs was so bright that it washed out the whole image, if I do Live View, Instant Review and Playback the images I am taking.
Then I adjusted the LCD Display Settings to Brightness -3, Contrast +3. The Playback of images is acceptable now, but in Instant Review the image would still be washed out.
I was wondering what I did wrong with MENU and buttons, so I tried to Reset Custom Functions. However, the Reset OK does not work at all, I don't get "Returns the custom function settings to default values". I had turned the camera ON and OFF, Reset for several times, all my custom settings are still there!
I have had a *ist DS, K10D and K01, but never run into this kind of trouble with them. This problem is pretty odd for me. Generally, I use Instant Review to see if I got over-exposure or under-exposure to make adjustment on my iso, aperture, shutter speed settings. Now, forget it! Unless my images are way ... under exposure, coming out black, the Instant Reviewed images on LCD would be washed out, almost completely white.
BTW, I already installed the latest firmware 1.07 in K5-IIs.
Is there any thing wrong with my K5-IIs, or with what I have done?
 yudi's gear list:yudi's gear list
Pentax K10D Pentax K-01 Pentax smc DA 16-45mm F4 ED AL Pentax smc DA* 50-135mm F2.8 ED (IF) SDM Pentax smc DA 12-24mm F4.0 ED AL (IF) +5 more
Pentax *ist DS Pentax K-01 Pentax K10D Pentax K-5
brandrx Forum Pro • Posts: 28,337
Re: LCD on my K5-IIs is over bright
In the Camera Menu, Tools, Tab #1 see if you have the LCD Display Settings turned up too high.
Ron
Ron - 'We don't have time to go take pics this afternoon Carl.'
Carl - 'What do you mean? It will only take 1/1000s.'
'Keep your eyes looking forward. However, glance back now and then to see where you've come from. It will put a smile on your face.' ~ brandrx
OP yudi Regular Member • Posts: 484
Ron
Tab #2?
I had set LCD Display Settings with Brightness -3, Contrast +3.
I noticed that the GrayRGB color chart on LCD Display Settings screen is very bright, before I set the new values. Now, I am increasing Brightness & decreasing Contrast to set [-4, +4]. Tomorrow I will try again to see what it is like.
The odd thing is that the Reset Custom Functions is completely a failure.
DrewE Senior Member • Posts: 2,053
The LCD settings are not custom settings, per se; those refer to the numbered items in the custom menu (the C icon over on the right of the menu).
--DrewE
 DrewE's gear list:DrewE's gear list
Pentax K10D Pentax K-5 Pentax smc DA 18-55mm F3.5-5.6 AL Pentax smc DA 40mm F2.8 Limited Voigtlander 58mm F1.4 Nokton SL II +3 more
Tan68
Tan68 Veteran Member • Posts: 5,792
did this work out ok ?
 Tan68's gear list:Tan68's gear list
Phase One Capture One Pro +1 more
Sorry for updating so late. I forgot my passwd to login DPREVIEW, when I was out for a week.
My K5-IIs seems be back fine. I cannot tell what has made it normal again. I only did the following:
1. increasing Brightness & decreasing Contrast to set [-4, +4] in LCD Display Settings, but it didn't resolve the problem at all. Anyway, I leave it as [-4, +4].
2. Reset Custom Functions for numerous times, turn the camera OFF, then ON, Reset; OFF, ON, Reset; ...
3. take the battery out and recharge it, put it back.
Then, I found that the LCD was OK on the road. Now I set the Brightness & decreasing Contrast to [0, +2], the LCD looks good, nothing wrong. So weird!
