STM lenses and older EOS bodies
Started Aug 31, 2014 | Questions
GreenPig Regular Member • Posts: 292
Do the STM lenses work on the EOS 350D?
Is there any reason why they would not work?
 GreenPig's gear list:GreenPig's gear list
Fujifilm FinePix F200EXR Panasonic Lumix DMC-ZS50 Canon EOS 350D Canon EOS 400D Canon EOS 70D +9 more
Rexgig0
Rexgig0 Veteran Member • Posts: 7,399
Re: STM lenses and older EOS bodies
My 40mm 2.8 STM functions normally on 5D and 1D Mark II N cameras, which were both introduced in 2005. I see no reason that STM lenses should not function on the earliest EOS cameras, from the 1980s.
I wear a badge and pistol, and make evidentiary images at night, which incorporates elements of portrait, macro, still life, landscape, architecture, and PJ. I enjoy using both Canons and Nikons.
 Rexgig0's gear list:Rexgig0's gear list
Canon EOS 7D Mark II Canon EF 135mm F2L USM Canon EF 400mm f/5.6L USM Canon EF 100mm F2.8L Macro IS USM Nikon AF-S Micro-Nikkor 60mm F2.8G ED +54 more
Mark B.
Mark B. Forum Pro • Posts: 29,756
If they are EF-S lenses then they will not mount on film cameras, which are EF only - same as current FF DSLR bodies from Canon.
Mark
Rexgig0
Mark
Quite true. I failed to consider that part of the equation. (... need caffeine, before replying!) STM, alone, is not a limitation, within the EOS system, but EF-S does limit one's camera compatibility.
I will edit my above reply, to add a correction, if I am still within the time limitation. (Edit: It was too late to edit my first post.)
quiquae Senior Member • Posts: 2,265
STM lenses will work on the 350D.
 quiquae's gear list:quiquae's gear list
Canon EOS R5 Canon EF 100mm F2.8L Macro IS USM Canon EF 70-200mm F4L IS USM Canon EF 16-35mm F4L IS USM Canon EF 100-400mm F4.5-5.6L IS II +6 more
OP GreenPig Regular Member • Posts: 292
Thanks - I was just making sure that any new communications protocol would be ok. Typically these things are backward compatible.
totleytom Contributing Member • Posts: 564
I'm not sure there is a new protocol. That was always touted as one of the great advantages of the EOS system, right from the start in 1987: the camera would issue a high-level instruction, e.g. 'change focus to a nearer focus point' or 'close the aperture diaphragm', and it would be the lens which would convert that into specific instructions appropriate to the technology in the lens. We've had lenses with micro-motors (e.g. as in the 50mm f1.8), several variants of ultra-sonic motors, and now STM lenses, and (subject to the EF/EF-S/EF-M differences) they all just work on whatever body.
Canon got it right 27 years ago, and we're still seeing the benefits.
 totleytom's gear list:totleytom's gear list
Canon EOS 90D Canon EF 70-200mm F4L IS USM Canon EF 40mm f/2.8 STM Sigma 17-70mm F2.8-4 DC Macro OS HSM | C Canon EF-S 24mm F2.8 STM
Well, the STM lenses do have one backwards-incompatible wrinkle: continuous AF when shooting video works only on recent APS-C cameras (650D, 700D, 100D, 70D). I did not bother to mention this before because the 350D doesn't shoot video at all.
msowsun
msowsun Contributing Member • Posts: 740
Just to add.....
STM lenses are "optimized" for Continuous AF in that they have smoother and generally silent AF BUT.... Continuous AF during video is a function of the camera body and has NOTHING to do with the lens.
You don't need STM to do Continuous AF, and older non-STM lenses will still do Continuous AF when mounted on the appropriate body. They will just be noisy and jumpy.
 msowsun's gear list:msowsun's gear list
Canon PowerShot S110 Canon EOS D30 Canon EOS 5D Mark III Canon EOS Rebel SL1 Canon EOS 80D +27 more
