Nikon Coolscan scanner Ghosting
Started Aug 30, 2014 | Questions
Doss Senior Member • Posts: 2,080
Hi all, I'm hoping someone can explain the ghosting I'm seeing on scanned images.
The ghosting is most visible where high contrasts meet. eg in below image clearly visible along man's right knee and girl's left shoulder. However, I think it appears to affect overall sharpness across the whole image. It is also often visible along the edges of the frame (despite film being mounted)
x
Details:
  • Scanner: Nikon Coolscan V ED
  • Settings: Full res tif scan, all adjustments switched off. No pp
  • Film: Kodachrome64
It is definitely 100% NOT the usual suspect: ie a misplaced/dirty mirror
I wonder if it could be internal light reflections inside the scanner?
This suspicion is elevated by the fact my scanner has no internal plate? Should it have? The below pictures show these on an LS-40 and a Coolscan 5000 (I can't find an image showing inside a Coolscan V)
Source: www.sebsgarage.com/2005/11/cleaning-nikon-coolscan-iv-ed-ls-40-film-scanner/
Source: http://www.pearsonimaging.com/articles/howto/ls5000cleaning.html
Thanks in advance,
Doss
my words, my pictures
Photo Essays
Photo Gallery
Facebook page
Svein Eriksen Senior Member • Posts: 1,808
Re: Nikon Coolscan scanner Ghosting
I doubt this is the problem, but using ICE with Kodachrome can cause artefacts.
technic Veteran Member • Posts: 8,932
can't help you but it looks similar to the ghosting in my images from high contrast slides that were scanned with a Coolpix 5000 by a scanning service (only those were worse, in your image I have to boost the curves to see the ghosting but in my images it was often very obvious in the basic image). The effect is strongly reduced local contrast - which lowers apparent sharpness but I don't think the detail itself was worse.
I haven't seen this problem with images I scanned myself over the years with several different Canon and Minolta slide scanners, or the Kodak PhotoCD service. Maybe it's a Coolscan issue (design or maintenance problem?).
OP Doss Senior Member • Posts: 2,080
Thanks - tried with it on/off = Same.
Thanks for your time.
I previously had a Canoscan, so re-scanned some slides to see the ghosting evident with the Nikon which weren't with the Canon.
I find it a bit hard to accept this is the norm for what are considered 'good' scanners.
Did the scanning service you used have anything to say about it?
they didn't really comment on the problem but said I could send the slides again for a new (free) scan. Did not try that because there were other problems and it was a foreign company (risk that the slides are lost in transit). Many slides were way too dark which is a problem when you have only jpegs - which I used for most scans because of storage requirements. And many slides were rotated several degrees, so all in all it didn't make a very good impression (of course, the first test scans they did for me were very good ...).
I don't think it is the norm either, but it seems to be a common problem (have heard about it from others).
I learned it is better to scan yourself, but only the slides that you really need in best quality. I'm now using a 'slide copy' setup for scanning (very fast), which is good enough for most of my needs and in some ways better than the professional scanning service...
What about the frames, glassless?
yes, all glassless and almost all were hamafix frames. These are light grey color, and I was thinking that maybe this causes a diffuse reflection with the Coolscan (mine also had ghosting both around some very high contrast features and sometimes at the borders).
Then I'm out of suggestions. I've scanned a couple of hundred KC64 and KC200 slides on LS-2000/LS-5000 and never seen that effect, but I'm not sure if I've any image with quite as strong contrast as the affected areas.
From what I remember I also had this problem only with VERY high contrast slides, e.g. a dark room with one light source. Maybe it just doesn't show with normal contrast as the brightness of the 'ghosting' is probably a certain percentage of the normal image.
bronxbombers4 Veteran Member • Posts: 3,387
examples Coolscan V vs Coolscan 9000 ED:
Many scanners suffer from some of that halation at extreme contrast borders.
We had a Coolscan V and it had some of that, but it had it and most do. Then got the Coolscan 9000 ED which used diffused side lighting and it has none of that sort of issue at all, it also doesn't overemphasize emulsion bubbles and grain nearly so much either.
See here is with Coolscan V (direct lighting):
And then with the advanced diffused lighting of the 9000 ED:
And emulsion bubbles/grain differences first V:
with the 9000:
8000/9000 used diffused lighting and don't have the problem
the V and most scanners do
the 5000 I guess does but to a much lesser degree than the V from what you say
Otts Forum Member • Posts: 85
Are you using the Nikon software or a 3rd party like VueScan?  I use VueScan with my 5000 - I think they might have a free trial - otherwise it is really inexpensive to purchase and is always kept up to date.
 Otts's gear list:Otts's gear list
Fujifilm X100F Olympus E-M1 II Panasonic Lumix G Vario 7-14mm F4 ASPH Olympus M.Zuiko Digital 17mm 1:1.8 Panasonic Lumix G Vario 14-140mm F3.5-5.6 ASPH. / Power O.I.S +1 more
I do have Vuescan. Alas, it makes no difference (but I do agree it's excellent value/supported software)
Thankyou for posting these comparisons.
Yes, the above looks like the wishy-washy sort of results I'm getting. You are saying this is normal for a Coolscan V?
Makes me wonder why it has such a good reputation for a mid-range consumer scanner/ My old FS2710 (going for 1/10th the price on ebay) gave much sharper results
Re: Thankyou for posting these comparisons.
My experience from using the FS2710 and looking at slides scanned on the Coolpix 5000: the coolpix files are sharper, but that is about the only advantage. It also has more obvious grain, and these artifacts. Probably the Coolpix is faster in use though. Maybe the good reputation is based on the high end models with diffusion lighting?
Unfortunately almost all these old scanners are a pain to use due to outdated hardware interfaces, outdated drivers and lack of repair options if anything breaks down.
Samuel Dilworth
Samuel Dilworth Regular Member • Posts: 291
Why do you say that? I ask because it looks very much like the dusty mirror these scanners suffer from unless kept fastidiously clean. I store mine lying on its side in a plastic bin bag (which statically attracts dust) and furthermore scan with it on its side when possible. This reduces the amount of dust falling onto the mirror.
Internal Front plate?
To stop anyone before they suggest it is the reason
With due respect, I know it's easy to assume I'm wrong (considering some of the bullwhip you read from self-proclaimed savvy folk on here ). But honestly,  I am technically minded enough to know how to take apart something like this to clean/inspect (and when to draw the line and let someone else service it)
I'm still hoping someone who has done likewise with their Coolscan V can confirm the absence of the internal front plate as normal.
