ISO 3200 Samples, Please Post Some!
Started Aug 27, 2014 | Discussions
trotteritco Regular Member • Posts: 120
Re: ISO 3200 Samples, Please Post Some!
jesuisdanny wrote:
I own an E-M1.. I would say the ISO 3200 images are just barely usable, but not good enough for print and definitely not commercial use of any sort. ISO 2500 is the acceptable max for me. Once you go past ISO 1600, there is a steady increase in noise, so I've set my Auto ISO to 2500, FWIW.
You must be joking, I have E-M1, and I have set auto ISO to 6400. ISO 3200 is perfectly usable, I'm not even hesitating using ISO 6400 or 8000 on this camera, it's not like E-3 and E-5 where one had banding all over the shadow area.
 trotteritco's gear list:trotteritco's gear list
Olympus OM-D E-M5 Olympus E-M1 Nikon D750 Olympus Zuiko Digital ED 50mm 1:2.0 Macro Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS +8 more
Lab D Senior Member • Posts: 6,938
Printing will melt away some noise too
Paniko wrote:
leaf shutter wrote:
Thanks! Did you do some noise reduction on these?
Iso 8000 shot : 16 Luminance NR in LR5.6
Iso 3200 shot : 0 Luminance NR in LR5.6
Iso 5000 shot : 55 Luminance NR in LR5.6
still trying to learn...
http://paniko.zenfolio.com
The few times I've printed high ISO pictures, if there was a little noise, it melted away.
Larger amounts of noise can be hidden with grain or converting to B&W allowing for even higher ISO pictures.
Those are 3 get shots and the one at ISO5000 is an excellent example.
 Lab D's gear list:Lab D's gear list
Panasonic FZ1000 Nikon D600 Panasonic Lumix DMC-GH4
R V C
R V C Senior Member • Posts: 1,257
leaf shutter wrote:
Particularly, examples of the newer 16mp sensors at ISO 3200 would be useful.
An extreme example, taken with the 75-300mm MKII . :))
"Anything worth doing is worth doing poorly until you learn to do it well."
-- Zig Ziglar
https://www.flickr.com/photos/126558841@N07/
 R V C's gear list:R V C's gear list
Ricoh GR II Olympus E-M1 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Olympus M.Zuiko Digital ED 40-150mm 1:4-5.6 R Olympus M.Zuiko Digital 45mm F1.8 +10 more
R V C
Ooo.. forgot to mention, this is OOC JPEG.. no editing of any kind has been done..
-- Zig Ziglar
-- Zig Ziglar
agentul Contributing Member • Posts: 619
here you are.
mrc4nl Regular Member • Posts: 366
Re: ISO 3200 Samples, gx7
raw, lightroom, noise reduction set to arround 19
OP leaf shutter Regular Member • Posts: 265
Thanks everyone for posting such great examples! Very generous of you to do this. While there are examples on this site they are quite technical and dry compared to these shots.
For the most part things look good, although I will take a hit coming from Fuji in this area. However, there would be many advantages to M43 too, including AF, less expensive but great lenses, IBIS, lens size, and a traditional Bayer sensor rather than x-trans (advantage to me, at least).
tnphoto
tnphoto Regular Member • Posts: 282
Here's the Panasonic GX7 at ISO 200, 400, 800, 1600, 3200, 6400, 12800, and 25600:
http://tnphoto.com/dpr/GX7_noise-test.jpg
Each stripe includes some fine detail and some blank area. There are two strips that were worked on with Topaz DeNoise at various settings. I hope it's self-explanatory. The image is the full resolution of the sensor.
Tom
 tnphoto's gear list:tnphoto's gear list
Panasonic Lumix DMC-GX7 Nikon D750 Panasonic Lumix G Vario 100-300mm F4-5.6 OIS Olympus M.Zuiko Digital 45mm F1.8 Panasonic Lumix G Vario 45-150mm F4-5.6 ASPH Mega OIS +2 more
Ontario Gone
Ontario Gone Senior Member • Posts: 4,183
This is a completely untouched ISO 3200 file. No sharpening, NR, exposure adjustment, nothing.
"Run to the light, Carol Anne. Run as fast as you can!"
 Ontario Gone's gear list:Ontario Gone's gear list
Nikon D7000 Canon EOS 70D Nikon AF-S DX Nikkor 35mm F1.8G Nikon AF-S Nikkor 50mm f/1.8G Canon EF 40mm f/2.8 STM
