Do you think dropping an Olympus M5 on the sidewalk might affect the
Started Aug 23, 2014 | Questions
clear glass Contributing Member • Posts: 814
body's seals against moisture?
It seems to have hit lens first (ouch! The glass in the filter broke and I can't get the empty filter ring off). The body had only a few small nicks on both sides of the bottom plate, no outside deformation of the skin I could see. Everything seems to work A OK, including autofocus.
But the seal against moisture is important to me. Is there any sign I should look for (besides taking it out in the rain and seeing if it self-destructs) that the seals are not functional?
eques Veteran Member • Posts: 3,331
Re: Do you think dropping an Olympus M5 on the sidewalk might affect the
I guess, the rubber seals are the last thing to be damaged. I would test, if there is no wobbling any where - this might indicate that the rubber seals don't have contact to the harder structure of the lens, which could produce leaks.
Did you make optical tests after the accident? I would be afraid that the calibration of the lenses might be affected. Even more so in complicated zoom lens like the 12-40/12-35 which I quess you were using.
But my 14-45 survived a hit like this as well as my 20, so you have good chances of still having a fully functional lens!
Peter.
 eques's gear list:eques's gear list
Panasonic Lumix DMC-GX7 Panasonic Lumix G 20mm F1.7 ASPH Olympus M.Zuiko Digital ED 40-150mm 1:4-5.6 R Samyang 7.5mm F3.5 UMC Fisheye MFT Olympus 12-40mm F2.8 +2 more
MatsP
MatsP Senior Member • Posts: 2,526
Peter.
My E-M5 with the 40-150 on it dropped from a cafe table onto a concrete floor, bouncing on a stone fondament on its way down. A few scrathes, that's all. Sorry about your filter and I hope you manage to remove the ring and that the thread isn't damaged.
 MatsP's gear list:MatsP's gear list
Canon EOS 5D Mark II Olympus OM-D E-M5 Canon EF 50mm f/1.4 USM Canon EF 17-40mm f/4.0L USM Canon EF 24-105mm f/4L IS USM +3 more
alcelc
alcelc Forum Pro • Posts: 10,143
If no obvious deformation, would there be any crack even if it would be a hair thin one? If no, probably you would be OK.
Panasonic Lumix DMC-GF3 Panasonic Lumix DMC-GX1 Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GX85 Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS +9 more
Sam in Hawaii Regular Member • Posts: 271
At first I thought this was a joke!  Apparently,the em5 is even tougher than I thought.  What next; "will driving  nails with my epm2 void the warrantee?"  "How high will a em10 bounce?"  "Guess what! My em1 floats!"
 Sam in Hawaii's gear list:Sam in Hawaii's gear list
Panasonic LX100 Panasonic ZS100 Olympus TG-5 Sony a7 II Olympus E-M5 II +2 more
Jeff4500
Jeff4500 Senior Member • Posts: 1,694
Try heating the ring with a hair dry. Sounds counter intuitive but it has worked for me several times.
 Jeff4500's gear list:Jeff4500's gear list
Panasonic 12-35mm F2.8 Panasonic Lumix DMC-GX8 Panasonic Lumix DMC-GX85 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Panasonic Lumix G 14mm F2.5 ASPH +5 more
Billharr9 New Member • Posts: 15
Try a large rubber band around the stuck filter for extra grip.
 Billharr9's gear list:Billharr9's gear list
Olympus OM-D E-M5 Olympus E-M1 Olympus E-M5 II Olympus E-M1 II Sigma 150mm F2.8 EX DG Macro HSM +8 more
MatsP
It might help but be very careful. The lens coatings are sensitive to heat. Try sone tool first like a poly-grip or the like and put something in between to avoid scratches.
