Konica Minolta 7D LCD Diplay- where to get this part
Started Aug 21, 2014 | Questions
Speedlight New Member • Posts: 2
Hi
I've got a konica minolta 7d and this year vacation was a total fail for me. After a littel car accident my LCD got broke. I'm seachring for the LCD but did not get to much information where i can get it.
I did find this info on german minolta forum:
2181090 "LCD MONITOR" (U3040516U) USD 115,02
but sony website says it's no longer available ;/
Search on ebay did not go good as well. Any ideas where i can get it? or is there someone who want to sell an LCD?
Calico Jack Senior Member • Posts: 2,306
Try the Dyxum Boneyard thread . . .
If you can get a GGS/FOTGA/JYC glass LCD screen protector, you can remove the broken LCD and replace it with one of those. Heat the LCD screen with a hair dryer to soften the adhesive around the edge and gently remove the top LCD screen from the body and then thoroughly clean the ridge where the LCD screen sits (there's a small lip so it needs to be totally clear of any residue). Remove the adhesive film from the JYC/FOTGA/GGS screen and accurately place it into the camera. Job done!
Screens can be bought very cheaply on evilBay. I can't see one specifically for the 7D, but there are plenty listed for 2.5" screens, so worth asking the vendor if they know if it will be compatible, though the standard size for these is 56.5mm horizontal x 45mm vertical, so if the 7D LCD screen is that size, then you'll be fine. See items: 321159750570 and 320937927586 as examples.
I very much doubt you'll find an OEM glass LCD screen, so these will be every bit as good, though do check the dimensions (in mm) first.
I'm assuming it's the screen cover and not the actual LCD itself. That said, there is a forum for dead 5D/7D DSLR's on Dyxum, so it may be worth asking there if anyone who has a dead 7D would be prepared to remove it and sell it to you (no harm in asking). See the Boneyard thread.
Mark (aka Pirate!)
 Calico Jack's gear list:Calico Jack's gear list
Sony Alpha DSLR-A850 Konica Minolta Maxxum 7D Sony Alpha DSLR-A100 Sony DT 11-18mm F4.5-5.6 Tamron SP AF 90mm F/2.8 Di Macro +26 more
Mikem65d Regular Member • Posts: 319
Re: Try the Dyxum Boneyard thread . . .
Another place to try is KEH.com
I've been able to find many parts for Minolta cameras there.
 Mikem65d's gear list:Mikem65d's gear list
Sony a6000 Sony E 55-210mm F4.5-6.3 OSS Sony E 16-50mm F3.5-5.6 PZ OSS Canon EOS 50D Olympus E-PL7 +3 more
Additional info, questions, advice and a suggestion
Ahoy!
Further to my previous reply, unless you can source the part free or extremely cheaply, it'll be financially unviable to do a repair (buying new parts) and I would advise you look for a Sony A700 which is about the same in terms of build, weight and size to the Dynax/Maxxum 7D though is arguably better and these can be bought pretty cheaply in todays used market.
I don't have the answer to this, but is the Minolta LCD removable from the rear and connects via a small connector, or do you have to dismantle the body and access it from the rear of the body housing internally?
You can get a lot of info, software and documentation directly from the KM website here.  FWIW, I also have the DiMAGE Master software with the update and serial number with user guides posted online via DPR here if you need it.
Mark (aka Pirate!)
OP Speedlight New Member • Posts: 2
Re: Additional info, questions, advice and a suggestion
Hi Mark
First thing. Thanks for the reply. Didn't have much time lately.
Sad to say the screen protector is ok it's the LCD. I did took the LCD out because I had hope it's only a connection problem... i'm looking actually on the boneyard.
I still have hope for my friend ;/
digitalshooter
digitalshooter Forum Pro • Posts: 19,604
All of the parts were transferred to Sony when they took over KM
photograpic end.  So if Sony handles this the way they do current models, you are SOL!
Thanks,
Digitalshooter
PS: all posts are just my opinion!
 digitalshooter's gear list:digitalshooter's gear list
Sony Alpha DSLR-A700 Canon Pixma Pro9000 Mark II
lennoxsd New Member • Posts: 1
Re: All of the parts were transferred to Sony when they took over KM
Hi - anyone know just how to remove the Dynax D7 LCD display to fit a replacement one?
EvilOne
EvilOne Forum Pro • Posts: 14,627
Contact Kaitlyn Axton at Precision camera in Ct. She is the repair program mgr at the largest Camera repair facility in the country with 4 million cameras repaired. Just a chance she might help... To my knowledge there are no parts available.
Kaitlyn Axton
Precision Camera and Video RepairProgram Manager
Phone: 860-272-2100  Fax: 860-749-6878
www.precisioncamera.com
Just a small chance
Bill aka EO
 EvilOne's gear list:EvilOne's gear list
Minolta DiMAGE 7Hi Nikon Coolpix 990 Konica Minolta Maxxum 7D Sony Alpha DSLR-A700 Sony SLT-A77 +5 more
EvilOne
I am so ashamed. I've fallen victim to a three year old thread.
unclebrudy
unclebrudy Contributing Member • Posts: 575
Doesn't matter - what matters is you tried to help.
Just a Maxxum, an Alpha, and crossed fingers.
 unclebrudy's gear list:unclebrudy's gear list
Fujifilm X-M1 Fujifilm X-T1 Fujifilm X-T3 GoPro Hero6 Black Fujifilm XF 18mm F2 R +6 more
