Considering a 17-40L....questions!
Started Aug 21, 2014 | Discussions
TreInJapan Regular Member • Posts: 122
Hello!
Recently picked up a 6D, and i'm loving it. I love the 24-105 and I'm really impressed by the low-light performance of the 6D. I still have my t3i which I love, and one of my favorite lenses is the Tokina 11-16 F/2.8, which is made for APS-C, so it's really only useful on FF at 16mm. I could keep it and very rarely use it on the t3i, or I could sell it and add a bit more to upgrade to a 17-40 for the 6D, but I have a couple of questions.
-My hopes for my next lens:
  • Wide enough to shoot interiors well. I do occasional interior photography and want something sharp and reliable. The Tokina was great for this.
  • Sharp enough for portraits at 40mm. (Had another thread recently where I got a bum Sigma 50/1.4 that I was hoping might fit this bill, but instead just got a full refund.)
  • Solid wide-angle performance for video and glidecam work.
  • Occasional low-to-mid-light group shots at parties and events.
-Questions
  1. Is it decent for portrait work?
  2. Any experience with video work? I know wide angle lenses are generally pretty solid, but perhaps I can hear first-hand from someone who has worked with this lens.
  3. Does the 6D's low-light performance compensate for the 3 stops in aperture over the Tokina? On my t3i, if I was shooting anything over 1000 ISO, the shots were pretty noisy. But with the 24-105 I can pretty much shoot into a dark corridor and shots still come out okay at 12,000 ISO. So I would assume it would be fine...
  4. If you don't recommend this lens for the above-stated goals, do you have another lens or pair of lenses that you would recommend for a similar price? Another option would be to just keep the Tokina and always use it at 16mm, then get a nifty fifty or pancake 40 or something. Though the last nifty fifty I had didn't focus right all the time, so that worries me a bit. Also, I need fast-focus!
Any first-hand experience or input would be great! Thanks!
Canon EF 17-40mm f/4.0L USM Canon EOS 600D (EOS Rebel T3i / EOS Kiss X5) Canon EOS 6D
Keith Z Leonard Veteran Member • Posts: 6,134
Re: Considering a 17-40L....questions!
TreInJapan wrote:
Hello!
-Questions
1.  I wouldn't choose 40mm for portraits, generally.  For single person portraits you'll want a focal length that doesn't distort features, which is typically 85-135mm range on the 6D.  You can take wide angle portraits, of course, but I wouldn't use it as my main portrait lens.
2.  I've not used this lens for video, sorry, but the 16-35 f4L IS would be a better choice as it's stabilized.  It's true that most ultra wides are fine for video due to the wide FOV resulting if a pretty steady shot, but 40mm isn't super wide, at that FL IS is quite nice for video.
3.  3 stops??? Where do you get that figure?  f2.8 vs f4 is 1 stop.  And yes, it is more than offset by the ISO performance difference between the t3i and the 6d.
If you can swing it the new 16-35 f4L IS is a no brainer for ultra wide in Canon land now, but if you are looking for a more affordable option, I would point you towards the Tokina 16-28 f2.8 as it's a much better performer than the 17-40L, though with a few drawbacks...weight, occasional rainbow flare, bulb front element makes filters tougher to use.  But for 600$ it's hard to beat, in my opinion, it's great for interiors unless you wanted to move to a tilt shift lens.
 Keith Z Leonard's gear list:Keith Z Leonard's gear list
Canon EF 70-200mm F4L USM Canon EF 100-400mm f/4.5-5.6L IS USM Sigma 50mm F1.4 EX DG HSM Canon EF 24-105mm f/4L IS USM Canon EOS 400D +16 more
OP TreInJapan Regular Member • Posts: 122
Thanks a lot Keith!
-Do you think the 24-105 that I already have is better for portraits than the 17-40? And then how about compared to a cheap 50 or 85mm?
I don't think I can swing the 16-35 as it is about 50% more than the 17-40. The Tokina 16-28 F2.8 looks great too, but I don't know if it will satisfy my requirements to take decent portraits...unless of course the 24-105 can do that already
TreInJapan wrote:
Thanks a lot Keith!
Of course the 24-105 does that!    And yes, it would be better than an UWA lens.  The 24-105 is a good lens, weakest on the wide side, which is why an overlapping UWA there makes some sense if you don't mind carrying both around.  The beauty of the 24-105 is in it's versatility.
The 85 f1.8 is a very well regarded lens for portrait photography, and quite inexpensive.  I use the Sigma 50 f1.4 ex, Canon 70-200 f4 and the Canon 135L f2 for most of my portrait efforts, but the 24-105 certainly gets its fair share as well.  There are many pro photographers who use the 24-105 for studio portraiture.  The advantages of the primes are generally sharper images and the ability to use thin depth of field for subject isolation when you want.  But on a 6D you can achieve pretty good subject isolation even at f4 @ 105mm with good center sharpness.  When shooting in more controlled situations you don't need to worry about that so much anyway...just stop down the lens and have at it.
Here are a couple of portraits with the 24-105, some with studio lighting and some more PJ style.
victorian squid
victorian squid Veteran Member • Posts: 3,391
TreInJapan wrote:
Hello!
This will have a similar wide range as your 11-16 on the 6D, but go much longer of course.
Not the best choice, but it could work in a pinch.
Yes, it works great this way. I've shot LOTS of video using a steady-cam. I can't tell any difference between this and my 16-35 used this way.
On a 6D? F4 is not an issue.
-Questions
Nope - but if you're shooting lots of people, sure.
  1. Any experience with video work? I know wide angle lenses are generally pretty solid, but perhaps I can hear first-hand from someone who has worked with this lens.
I use this lens, the 16-35 and Rokinon 14/2.8 for all of my steady-cam type work. The 17-40 has been my workhorse lens for a year.
  1. Does the 6D's low-light performance compensate for the 3 stops in aperture over the Tokina? On my t3i, if I was shooting anything over 1000 ISO, the shots were pretty noisy. But with the 24-105 I can pretty much shoot into a dark corridor and shots still come out okay at 12,000 ISO. So I would assume it would be fine...
I think this already got answered - 3 stops isn't what you've got - what you've got is basically the same thing. f2.8 is about the same as f4 on the 6D. The 6D is the first camera I've had where I'll leave it on auto ISO in most conditions. I couldn't really go over 800 with my 60D, and didn't even like that. 12400 is a bit much on the 6D (which is crazy high!), but passable - I've done it frequently if I have to stick with a shutter speed but try to avoid it. 800-1600 looks like 200-400 on the 60D.
  1. If you don't recommend this lens for the above-stated goals, do you have another lens or pair of lenses that you would recommend for a similar price? Another option would be to just keep the Tokina and always use it at 16mm, then get a nifty fifty or pancake 40 or something. Though the last nifty fifty I had didn't focus right all the time, so that worries me a bit. Also, I need fast-focus!
Just to summarize, I have both the 17-40 and new 16-35. While the 16-35 is obviously a superior lens, it can be a question mark for a lot of people. I've still not been able to part with my 17-40 - it's an excellent little lens. But, I probably should as the 16-35 is a perfect replacement.
My main purpose for UWA's is interior/architecture/real estate photography. But of course, they're invaluable for landscapes as well. As has already been answered, not a particularly good choice for portraits, even at 40, unless you've got a bunch of people!
I have shot lots of video using the lens. Yes, it's nice to have stabilization, but depending on how you're doing it - it really doesn't make much difference. I've used it almost exclusively handheld, and using a steady-cam. Honestly, I haven't been able to see much difference between it and the stabilized lenses going this way. Off the steady-cam, yeah, you can see it. But typically, I'm steady-cam, some cage (not much), or on a tripod with a longer lens.
I've posted lots of comparison shots between the 16-35 and 17-40, but it really sounds like ultimate corner resolution is not that important to you - so save the money!
 victorian squid's gear list:victorian squid's gear list
Canon EOS 6D Canon EOS 70D Canon EF 24-70mm F2.8L II USM Tamron SP 150-600mm F5-6.3 Di VC USD Canon EF 16-35mm F4L IS USM +37 more
Victorian Squid,
Thanks so much for the super-thorough response. You've been very helpful!
RS_RS Senior Member • Posts: 1,788
I have had a 17~40 since film days, and am currently considering upgrading it to the new 16~35/4IS. The 17~40 is a pretty good FF UWA lens, but has poor corner performance at wide apertures at the wide end. The corners improve a lot on stopping down, so for landscape and architectural work this is not a big problem. However, the thing to remember with Canon UWA lenses is that the use of Digital Lens Optimizer within Digital Photo Professional dramatically improves performance.
Dan_168 Forum Pro • Posts: 11,061
TreInJapan wrote:
-Questions
I had the 17-40L a while back and here is my 2 cents worth comments:
Unless for a group shot and I have no space to back off, I would never use the 17-40L for portrait, I prefer to use a fast prime both for background isolation and better bokeh quality, even when the 35-40mm focal range is what I need, I would still use my fast 35mm prime instead. Whether is the ancient AI-S 35 1.4, 35L 1.4 (both sold now) or the modern Zeiss 35 1.4, to the latest Sigma 35 1.4 art. As the matter of fact, 35mm was/is never my favorite FL for portrait, I prefer longer lens for that.
I don't normally shoot video but if I do I would prefer to use my MF primes. but I do know friends use that lens to shoot video and I didn't hear any complaint from them so it must be working pretty good for them.
I don't have a 6D but any modern body does a good job in low light, so from light gathering stand point F4 is less of an issue than before, but what you will get from a slow F4 zoom is a really dark VF indoor, few night ago I used my F4 TSE 17 in Standford church again for a project and boy it was DARK when I look thru my 1DS3 VF, just too spoiled by those 1.2 1.4 primes, but then I am using the LV most of time for tripod work so that dark VF is no issue now, but for handheld shooting that sure is annoying, also you will be force to bump up your ISO, lower iso always give cleaner image no matter what camera brand or model, so while the ISO 12800 may look OK but the ISO 3200 image from the same camera will always look better, not to mention a F4 zoom don't have much control on background isolation even "wide open", no matter how sharp that is, it's still a F4, just keep that in mind.
With that being said, I do not recommend this 17-40 lens for any application ( on FF) , not even back in 2008, it worked nicely on my 20D but as soon as I upgrade to my first FF DSLR 1DS2, the edge softness shows up right away even stop down for my landscape picture, just image with the higher resolution higher DR sensor in the near future, the issue can only be more pronounced, and it's really slow and dark lens for in door low light, so I didn't like it for outdoor landscape or portrait and I didn't like it for indoor low light. in 2014, you have a much better alternative, the 16-35 F4L IS, much much better landscape lens, a lot sharper edge to edge, perfect for landscape application except for Astrophotography because it's still a slow lens. IS can be handy if you use it for handheld shooting, For portrait, there is bunch of cheaper, much faster aperture primes to choose from, anywhere from 24mm to 135mm, pick the focal length you prefer. I know you mentioned "similar price", but I strongly suggest to stretch your budget a little further and consider the 16-35 F4 IS instead, it's really a day and night better lens, you don't buy lens everyday, one good lens last for long long time, I would rather get a good one and be done with it. I am still shooting with lenses from the 80's from my high school days, if you look at it from the long term, few hundred or even a thousand dollars extra doesn't really make any difference over the period of 30 years.
gipper51 Veteran Member • Posts: 5,904
TreInJapan wrote:
Hello!
-Questions
I use the 17-40 extensively for commissioned architectural work.  It is quite good for this with three caveats:  stop down to f11, proper manual focusing, distortion correction in software.  With these met it performs admirably.  17mm is the weakest setting but still very good.  The majority of the shots on my website below were taken with this lens.  Replacing it with something better is a low priority item.
As for portraits, sure it will work.  The center is sharp at any aperture and focal length (on a good copy).  f4 will not give you much background blur at wide angles unless you are right in the subject's face.  But then, even f1.4 is tough to truly blur a background at UWA unless you are very close to the subject.
For event type portraits (group shots, full body) it's a good lens.  You'll often need f4 just to get everybody in focus.  I find it great at wedding reception.
If you have kids, UWA zooms are fun for portraits.  Set it wide and stick the lens right in their face and you can get some great perspectives.
 gipper51's gear list:gipper51's gear list
Canon EOS 5DS Panasonic Lumix DMC-GX85 Canon EOS R6 Mark II Canon EF 85mm F1.8 USM Canon EF 135mm F2L USM +20 more
rebel99 Veteran Member • Posts: 4,025
i don't know about using 17-40mm f4.0 for portrait on a FF camera, using 24-105mm f4.0L for this purpose would be much better. i strictly use my 17-40mm f4.0 with my 40D on my trips overseas and they work wonderfully for me together. for portrait, i'd get the ef 85mm f1.8 for a very reasonable price. 85mm 1.8 has a very quick and accurate focus and a nice bokeh. so, for portrait, you have many other reasonable choices. 17-40 f4.0 makes a very good walk around lens in the cities. it has a very sharp center and i like its micro contrast, which is a typical "L" lens trait. hope this helps.
cheerz.
KENTGA Veteran Member • Posts: 8,733
Don't use the 17-40 for portraits unless its a large group. Use 85- 105 for 6D. 85 1.8 or 100L macro would be good for portraits or macro. 17-40 will be about the same as the Tokina when you consider the crop factor. I have the 17-40 and Sigma 12-24 for wide angle and the Sigma gets a little "out-of-round" at 12mm. Sorry but I can't think of a better term but it's kind of tending toward the fisheye effect.
I love the 6D and also have the 7D. Maybe keep the crop setup unless you need higher ISO.
Kent
 KENTGA's gear list:KENTGA's gear list
Canon EOS 7D Canon EOS 6D Canon EOS Rebel SL1 Canon EOS 80D Tamron AF 18-270mm F/3.5-6.3 Di II VC LD Aspherical (IF) MACRO +14 more
Kent
kent, if you read my post carefully, i did not recommend 17-40 f4.0 for portrait! i did suggest 85mm f1.8 or 24-105mm f4.0 for portrait. like i said, for portrait there are many other lenses available
cheerz.
To: rebel99
I was not responding to your comment. I was making a statement about using WA lenses for portraits.
Kent
chinch Senior Member • Posts: 1,731
Many of the OP's questions have been answered, notably the 24-105 (or longer prime) would be better for portraits. It sounds like the 17-40 would be an excellent complimentary lens for you as the <24mm range is really critical to many shooters including myself. It would do interiors well (obviously is not the Canon TS-E 17). There are not many affordable FF alternates and the 17-40 is a quality FF lens that is reasonably affordable (or close to the price/performance). The AF & MF works great and should have no trouble with video.
Having just taken a trip with the 6D, 24-105L and 16-35II, I can tell you 51% of the shots were 24mm or wider and this would have jumped ~10-20% except the 16-35 was not readily available when we unexpectedly had a photo opportunity. So if UWA is indispensable and $ is not unlimited the 17-40 is a great FF choice.
 chinch's gear list:chinch's gear list
Canon EOS 5D Mark III Canon EF 85mm F1.8 USM Canon EF 24-70mm f/2.8L USM Canon EF 70-200mm F4L USM Canon EF 100-400mm f/4.5-5.6L IS USM +4 more
TreInJapan wrote:
Hello!
-Questions
here is a portrait taken with 24-105 f4.0 on a 5D:
please click on the photo and view it on dp viewer for detail!
i use my 17-40mm f4.0 strictly on my aps-c (40D) and get very good result. here is a gallery, all taken with 17-40 and 40D:
http://azbaha.zenfolio.com/p572883877
cheerz.
