Some more 16-35 f/4L IS shots, including a sunburst and the world's largest word search!
Started Aug 21, 2014 | Discussions
yodermk Senior Member • Posts: 1,393
So I got this lens about 3 weeks ago, and am so far pretty happy with it.  Wanted to try sunbursts.  My conclusion: Sunbursts on this lens are massively better than they were on the 10-22, which this lens replaced (also going from a 60D to a 5D3).
As an aside, any general C&C here?  I just kind of shot it quickly because I liked the sun right next to the bus, and was walking by quickly.  The people in the picture were unintentional bystanders.  I think they add a lot to the picture, but I wonder if they are recognizable enough that I need to be careful with it?  Not that I intend to sell it.  I like the shot myself but wanted to get other peoples' takes.
Then there is the world's largest word search, which happens to be in my office building.  Well, OK it was the biggest at one time, and we have a certification by Guiness.  However, I understand the record has been beaten since then.
My observations: You can definitely notice a bit of CA in the corners, but it's not particularly bothersome.  Also it's maybe a *little* short of pixel perfect tack sharp, but again, not really a huge deal.  This was shot a few feet away from the puzzle on a nearby escalator.  I was actually surprised that 16mm did not encompass all of it.  Using the 8mm fisheye on the 60D I did get almost all.
Finally, for kicks and jollies, here is an obligatory shot of a kitten sitting in a crockpot.  You can kind of tell the bokeh this lens can produce.
These are the JPEGs straight from the camera, no processing. (I do still have the RAWs but don't generally mess with them unless I really feel the need.)  Thanks for looking!
If it's a *Single* Lens Reflex, why do I need so many lenses?
 yodermk's gear list:yodermk's gear list
Canon EOS 80D Canon EOS 5D Mark IV Canon EF 400mm f/5.6L USM Canon EF 100mm f/2.8 Macro USM Canon MP-E 65mm f/2.5 1-5x Macro +12 more
Canon EF 16-35mm F4L IS USM Canon EOS 5D Mark III Canon EOS 60D
salamander1 Senior Member • Posts: 1,427
Re: Some more 16-35 f/4L IS shots, including a sunburst and the world's largest word search!
i don't want to disappoint you, but i think this sunburst is pretty generic.  the 16-35 f/4L IS appears to  have a number of other very fine qualities, though.
in my opinion the "old" 16-35 f/2.8L II produces phenomenal sunburst, probably  best in the business.
OP yodermk Senior Member • Posts: 1,393
Really? Any samples of the "old" lens sunburst?
Kevin Jorgensen Contributing Member • Posts: 745
I agree. I've got a couple buried somewhere, will look tomorrow, but I think they're up home.
 Kevin Jorgensen's gear list:Kevin Jorgensen's gear list
Canon EOS 5D Mark III Canon EF 85mm F1.8 USM Canon EF 100mm F2.8L Macro IS USM Canon EF 70-200mm F2.8L IS II USM Samyang 14mm F2.8 ED AS IF UMC +2 more
GeoffreyH Regular Member • Posts: 340
Here's one from Albion Basin, Alta, Utah
16-35 f/4 @ f/16
Atoche
Atoche Contributing Member • Posts: 682
I had no idea Utah was so amazing!
"I may be a geek, but it pays for the car...!"
 Atoche's gear list:Atoche's gear list
Pentax Optio WG-2 GPS Canon EOS 7D Canon EOS 6D Sony Alpha NEX-3N Canon EF 24mm f/1.4L II USM +9 more
kevindar
kevindar Veteran Member • Posts: 4,625
first off, thanks for posting.
I like your sun burst picture, and I like the people in it.
I own both lenses right now (16-35II and f4IS). the f4 lens has more rays in its sunburst due to its 9 aperture blades, same as 24-70II. is it better or worse, is I suppose a matter of taste. I think its worse than 16-35II, which I agree has the best sun burst effect, but its a matter of taste.   here is 16-35II I think just the perfect number of rays.
And here is the samyang 14, for a comparison, not enough number of rays if you ask me.
and of course your sample.  too many rays for my taste.
Your word puzzle is a lens testers dream. we should have DPR rent space in your building. You also seem to have and very sharp and very well centered copy of the lens, which is great. you should set up a tripod and do a full test at 16, 21, 24 and 35, from f4 to f11 on that wall.  it would probably be one of the most useful sharpness tests
 kevindar's gear list:kevindar's gear list
Canon EF 85mm F1.2L II USM Canon EF 70-200mm F2.8L IS II USM Canon EF 24-70mm F2.8L II USM Sony a7R II Sony a6300 +25 more
kamsing New Member • Posts: 3
Here's one from Petronas Twin Towers (KLCC) Malaysia
Kasra A
Kasra A Regular Member • Posts: 189
16-35 f/2.8L II Sunburst for comparison!
I don't have the f/4 version but I got this with my 16-35 f/2.8L.
I believe the look of sunbursts largely depend on the conditions that the picture was shot in. In my experience, if you shoot through leaves, or the corners of walls, you'll get longer and better defined sunbursts than shooting directly toward the sun.
EF 16-35 f/2.8L II @ f/20
I also noticed that my 24mm TS-E gives me these interesting split rays:
TS-E 24mm @ f/10
 Kasra A's gear list:Kasra A's gear list
Sony a7R II Canon EOS R6 Canon EF 16-35mm F2.8L II USM Canon EF 100mm F2.8L Macro IS USM Canon EF 70-200mm F2.8L IS II USM +5 more
that is awesome n/t
Re: 16-35 f/2.8L II Sunburst for comparison!
Thanks, I will have to try that.  Nice shots BTW.
I'm tempted now to do sunburst tests on all my lenses.
Thanks for the samples. I still like the rays of the f/4.
Yep!  Guess I need to do more with that wall, though it's hard to get a straight shot at it from very far away because of an escalator next to it.
