What would be the better macro lens than XF 60mm?
Started Aug 20, 2014 | Questions
cyip0 Regular Member • Posts: 219
I was stuck at home over the weekend. We've been having ant attack due to warm and dry weather outside.
I tried to take some macro pictures using X-E1 and XF 60mm. However, I could not get the object to fill the frame. I had to heavily crop the pictures.
I am wondering if there is anything I can do to take better macro pictures with my X body.
Thanks.
 cyip0's gear list:cyip0's gear list
Fujifilm FinePix X100 Panasonic Lumix DMC-GF2 Olympus OM-D E-M5 Fujifilm X-E1 Sony Alpha NEX-6 +11 more
Trevor Kloeden Senior Member • Posts: 1,323
Re: What would be the better macro lens than XF 60mm?
I have the 50mm f2.8 Zeiss Touit.
It is an awesome lens and will give you 1:1 macro.
Here is a thread of mine re this lens.
http://www.dpreview.com/forums/post/54149473
You can also used extension tubes with existing lens.
Here is another post fo mine on extension tubes.
http://www.dpreview.com/forums/post/53834329
Trevor Kloeden
http://trevorkloeden.wordpress.com
http://trevor.kloeden.com/
http://www.flickr.com/photos/26503291@N03/sets/
 Trevor Kloeden's gear list:Trevor Kloeden's gear list
Canon PowerShot G7 Nikon Coolpix 990 Fujifilm FinePix X100 Olympus Tough TG-3 Olympus Tough TG-4 +9 more
OP cyip0 Regular Member • Posts: 219
Hi Trevor,
Thanks very much. I will look into this lens. I used a speedlight (off camera) for the shot but XF 60mm seems unable to get close enough.
Thanks!
photoreddi Veteran Member • Posts: 7,973
There are several things that you can do. The first is to get almost any macro lens for Canon or Nikon cameras and a lens adapter for it. You'll have to focus it manually but many macro photographers focus manually anyway even when the use autofocus lenses.
A much less expensive solution is to buy a set of extension tubes for Fuji's X mount. If you search Amazon you'll find many brands of tubes such as Fotodiox, Fotasy, Fotga, Neewer, Viltrox and others. They typically include 2 or 3 different size tubes and can be stacked together in different combination where the greater the tube length the greater the magnification.
The most expensive sets cost between $40 and $50. Fotodiox has one for $45 and another for $10. The $45 version includes a 10mm and a 16mm tube and claims to allow autofocusing but with the extreme magnification that the tubes allow, the depth of field is so razor thin that you'd probably be better off putting the camera on an adjustable rail that's mounted on a good tripod. The $10 version includes 3 tubes, 7mm, 14mm and 28mm.
http://www.amazon.com/s/ref=nb_sb_noss?url=search-alias%3Daps&field-keywords=extension%20tubes%20fujifilm
(unknown member) Veteran Member • Posts: 3,441
Give the Ant a bit Sugar.
slimandy Forum Pro • Posts: 17,161
The 60 is a superb lens but it does lack 1:1. I currently have a Zeiss 50mm that I borrowed. That is the only dedicated 1:1 macro lens for X-mount that I know of. IQ is excellent, but the lens is very frustrating largley due to the lack of working distance and also the lack of markings. My preferred option until a longer 1:1 becomes available is to use my old Nikon macros with an adapter. I have the older version of the Nikon 60 and a Tmaron 90. I use the older versions because they have aperture rings which means I can use an adapter that doesn't have one, and I can use a Nikon extention tube to go beyond 1:1.
www.andrewsandersphotography.co.uk
 slimandy's gear list:slimandy's gear list
Sony RX100 II Nikon D200 Nikon D700 Fujifilm X-E1 Fujifilm X-T1
britcam
britcam Senior Member • Posts: 2,583
I would take a look at one of the Tamron 90 macro lenses. The f2.5 is excellent and available at very low prices these days ...   You don't need AF, just a good tripod.
Regards
Rich S (britcam)
 britcam's gear list:britcam's gear list
Fujifilm X-E2 Fujifilm X-M1 Fujifilm X-S10 Fujifilm XF 35mm F1.4 R Fujifilm XF 60mm F2.4 R Macro +8 more
baobob
baobob Forum Pro • Posts: 18,248
With the 60mm I use 2 sets of Viltrox macro extension tubes to get 1:1 ratio
A nother way is the Tamron 90mmwith adatall to fx adapter with manual ext tubes
Sony RX100 Panasonic ZS200 Fujifilm X-H2S Fujifilm X-H2 Fujifilm XF 35mm F1.4 R +16 more
pauldb126 Regular Member • Posts: 215
You could also add the Raynox DC-250, or any other quality close-up lens, to the front of the 60mm. You do not lose light as you would with extension tubes or have the worry over poor contacts. The Raynox enables you to get > 1:1.
-Paul
 pauldb126's gear list:pauldb126's gear list
Fujifilm X-T3
Photo Legit
Photo Legit Contributing Member • Posts: 533
I plan on using a Tamron Adaptall 90mm 1:1 macro with an adapter.
I found it for sale used for about $130 and man it's a sharp lens. It's not very big either.
 Photo Legit's gear list:Photo Legit's gear list
Fujifilm X-T3 Samyang 12mm F2.0 NCS CS Fujifilm XF 16-80mm F4 +2 more
baobob
I confirm, excellent very easy to MF as well
Westmill
Westmill Senior Member • Posts: 2,279
I would go with pauldb ...  I do not have a raydox or whatever they are called myself but I have seen an awful lot of stunning pics from folk that do use it
 Westmill's gear list:Westmill's gear list
Fujifilm X-Pro1 Nikon D4S Nikon D500 Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II Nikon AF-S DX Nikkor 16-80mm F2.8-4E ED VR +5 more
Jim King
Jim King Veteran Member • Posts: 8,588
baobob wrote:
(snip)
A nother way is the Tamron 90mmwith adatall to fx adapter with manual ext tubes.
I'll second that idea - I bought a Fuji FX to Adaptall-2 adapter and it works great with all my Tamron SP Adaptall lenses, including the excellent telephotos.
Jim King - Retired Colormonger - Suburban Detroit, Michigan, USA; GMT -4h (EDT)
Pentaxian for over 50 years.
There is hardly anything in the world that some man cannot make a little worse and sell a little cheaper, and the people who consider price only are this man's lawful prey.
- John Ruskin
A fanatic is one who can't change his mind and won't change the subject.
- Sir Winston Churchill
The difference between genius and stupidity is that genius has its limits.
- Albert Einstein
 Jim King's gear list:Jim King's gear list
Pentax K-3 Leica M10 Pentax MX-1 Fujifilm X30 Sony RX100 VII +138 more
The Name is Bond Regular Member • Posts: 247
Non-Fuji optimised lenses are likely to get a big resolution drop due to the properties of the thickness of the glass in front of the sensor. Don't ask me why, but it's true .
You might be better off with just the heavy cropping.
Otherwise rent the Touit 50/2.8 1:1 macro.
v30 Senior Member • Posts: 1,009
try an extension tube. I use an el cheapo 16mm extension tube (with autofocus) with the Fuji 35mm f 1.4 and am able to get this close (see full size). I bet it would be awesome on the 60mm.
djrocks66
djrocks66 Senior Member • Posts: 1,697
The Name is Bond wrote:
Non-Fuji optimised lenses are likely to get a big resolution drop due to the properties of the thickness of the glass in front of the sensor. Don't ask me why,but it's true .
In that article you linked he said using a Canon or Nikon lens on a NEX or Fuji should not be any different as the Sensor Stack Thickness is basically the same.
I have great luck using an old 90mm Macro lens for Canon FD mount. No resolution loss.
 djrocks66's gear list:djrocks66's gear list
Fujifilm X-Pro1 Canon EOS Rebel SL2 Olympus E-M5 III OM-1 Panasonic Lumix G 20mm F1.7 ASPH +15 more
I missed another trick which is that the sensor stack issue mostly affects wide-angles not these longer lenses.
