Well this is disturbing (E-M10)
Started Aug 14, 2014 | Discussions
Chief T Regular Member • Posts: 193
After much hand wringing and gnashing of teeth, I finally pulled the trigger and bought an E-M10, 25mm f1.8 ($100 off) and E-CG1(free), plus another 5% off the total package. A good deal I think. This after 2 months of deliberating, reading reviews, lurking in the forum, etc.
Today, while perusing the Consumer Reports site, I came across their review. One thing stood out and it was "Poor image stabilizer, much lower than most cameras". How can this be? They said every other Olympus camera reviewed had and excellent stabilizer "better than most", even the lowly E-PM2. While I have no plans to return it, I would like to hear from other E-M10 owners and their experiences with image stabilization.
Chief T.
 Chief T's gear list:Chief T's gear list
Olympus OM-D E-M10 Olympus PEN E-PL5 Olympus E-M1 Olympus PEN E-P5 Nikon D70 +10 more
Olympus OM-D E-M10 Olympus PEN E-PM2
String
String Senior Member • Posts: 2,242
Re: Well this is disturbing (E-M10)
36
I think Consumer Reports should stick to rating fridges, stoves and maybe the odd coffee maker!
 String's gear list:String's gear list
Olympus E-M1 Olympus E-M1 II Panasonic Leica Summilux DG 25mm F1.4 Olympus 7-14mm F2.8 Pro Olympus 12-40mm F2.8 Pro +4 more
gugarci Senior Member • Posts: 1,622
Don't worry about that. While the 3 axis IBIS is not as good as the 5 axis it's better than the 2 axis version. Testing IBIS is not an easy thing to do. Some people can hand hold a camera better than others with or without IBIS. Ignore it & enjoy your camera.
 gugarci's gear list:gugarci's gear list
Panasonic Lumix DMC-LX3 Sony a6000 Sony E 16-50mm F3.5-5.6 PZ OSS Sigma 30mm F2.8 DN | A Sigma 19mm F2.8 EX DN +3 more
RaymondR
RaymondR Senior Member • Posts: 2,496
My experience with the E-M10 (having upgraded in the spring from the E-PL2) is that the stabilization of the E-M10 operates very well (seems a bit better than my E-PL2 which was good) and is consistent with the analysis in the DPReview review:
"The E-M10 offers a '3-axis' image stabilization system, a pared down version of the '5-axis' system offered in the other OM-D models. It's still a very effective system, reliably giving me 2 extra stops of shutter speed at the long end of the 14-42mm F3.5-5.6 II zoom lens (when comparing the number of steady shots achieved with it turned on and off). Movie IS uses a combination of the 3-axis mechanical system and electronic stabilization."
In short, I think the CR review indication that the E-M10 IBIS is bad is bonkers.  I stopped bothering with CR camera reviews years ago.  For camera evaluation, I will stick with the photography publications and sites for information gathering and user reports on the forums.
RaymondR
 RaymondR's gear list:RaymondR's gear list
Sony a7 II Sony a7C Sony FE 24-105mm F4 Sigma 70mm F2.8 DG Macro Art Tamron 17-28mm F2.8 Di III RXD +2 more
Shadowfixer Senior Member • Posts: 1,769
If you have researched as much as you claim, then you have seen the results from this camera. Why would an article from one magazine make you question your choice. Go out and enjoy your camera. It's a nice piece of equipment and will allow you to take many fine images with it. Take a deep breath and enjoy the toy.
 Shadowfixer's gear list:Shadowfixer's gear list
Olympus E-M1 II Olympus 9mm F8 Fish-Eye Body Cap Lens Olympus M.Zuiko Digital ED 75mm F1.8 Olympus M.Zuiko ED 75-300mm 1:4.8-6.7 II Olympus 12-40mm F2.8 Pro +1 more
Michael M Fliegel
Michael M Fliegel Veteran Member • Posts: 3,683
CR is good for household appliances.  For electronics?.............Not so much.  Enjoy the EM10.
 Michael M Fliegel's gear list:Michael M Fliegel's gear list
Olympus E-520 Olympus E-M1 Olympus PEN E-PL2 Olympus Zuiko Digital 11-22mm 1:2.8-3.5 Olympus Zuiko Digital 14-54mm 1:2.8-3.5 +13 more
gpb11 Veteran Member • Posts: 5,035
Consumer Reports? Seriously?
Consider the source. CR has never been very accurate in testing electronics in all the years I've seen their reviews. Clothes dryers and dishwashers and stores? Sure, CR is fine. Cameras, computers, etc? Not so much.
Yes the 5-axis IBIS will be slightly better than 3-axis IBIS in certain circumstances. That said, the E-M10's stabilization works very well in my experience.
You will be quite pleased with the camera. Nothing to worry about.
Images are about emotion. Technical perfection is nice, but does not stand by itself.
tt321
tt321 Forum Pro • Posts: 13,854
Others' experiences with IS are normally very close to useless, because any system of IS necessarily contains the user within the loop, and every user is somewhat different. The manufacturer can only design for 'the average user' which in all likelihood could be far from yourself or myself.
Since you have camera, have lens, and have additional grip, why not go out and test them yourself in your own typical shooting style/situations? Then you will know how many stops the IS gains you, or not, pretty clearly. Just try the same shots with and without IS at various shutter speeds for enough times to get meaningful statistics. Then you should know how much lower you can set the ISO or how much deeper DoF you can get with the IS. That others report that they can do better or worse than you is completely irrelevant.
Oli4D Contributing Member • Posts: 530
That's just nonsense, don't worry
Somebody probably just read that the E-M5 and E-M1 have 5 axis and the E-M10 3 axis... and then that person just though: "oh ok well that must result in "poor, much lower" performance".
And that's simply not true :). No need to worry, enjoy your E-M10!
 Oli4D's gear list:Oli4D's gear list
Panasonic Lumix DC-G9 Olympus E-M5 III Olympus 12-40mm F2.8 Pro Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R +7 more
drj3 Forum Pro • Posts: 12,636
5
I would not worry about their review.  The review says "because the lens has a poor image stabilizer"...  Maybe someone failed to realize the camera has in body sensor stabilization and that Olympus cameras do not have lens stabilizers.
drj3
 drj3's gear list:drj3's gear list
Olympus E-M1 Olympus E-510 Olympus E-5 Olympus OM-D E-M10 Olympus E-M1 II +13 more
justafan Forum Member • Posts: 77
If 25mm is your main lens to use, then I wouldn't even worry about IBIS that much. The new generation sensors are said to have better high ISO performance than older models, and you'd probably enjoy shooting fairly wide open with that Zuiko lens, I suppose.
Lab D Veteran Member • Posts: 6,938
Reality check: it is better than most cameras
Most ILCs do not have IBIS.  The only ones better than the E-M10 are the E-M1 and E-M5.
Most have reported the E-M10 IS is very good.
 Lab D's gear list:Lab D's gear list
Panasonic FZ1000 Panasonic Lumix DMC-GH4 Nikon D600
tt321
The thing with IS is that it's additional. So even if something is already very good, adding three stops (if possible) would bring a lot of additional benefits. Adding only a single stop may not be that significant.
harvo Regular Member • Posts: 419
A bit off topic. I owned a bicycle shop years ago. CR rated Windsor bikes, made in Mexico, as a best buy. We got a few in and found that the Mexican made aluminum rims were welded crooked. We trued and tightened the spokes. Then, with riding, the spokes loosened and the wheels wobbled. The bikes were worthless. I wrote a letter to CR explaining the problem. They never admitted the mistake or published the letter. They never answered me. I stopped subscribing and reading the magazine.
Harvo
 harvo's gear list:harvo's gear list
Olympus E-M1 Olympus 12-40mm F2.8 Pro Olympus 8mm F1.8 Fisheye Pro Panasonic Lumix G 20mm F1.7 ASPH Olympus M.Zuiko Digital 45mm F1.8 +2 more
Zensu11
Zensu11 Senior Member • Posts: 1,542
Do not worry about it! I've been reading CR reviews of film cameras then digital cameras for 40+ years now and I've often found their camera reviews to be way off base with my own personal experience with almost all the cameras I've owned including the Nikkormat FTN I purchased way back in 1970! Always take CR reviews of photographic equipment with a grain of salt.
"Three things cannot be long hidden: the sun, the moon, and the truth." - Buddha
Bobby
dougjgreen1 Veteran Member • Posts: 4,068
I agree with this.  While I DON'T agree with the folks who are generally bashing the Consumer Reports ability to evaluate cameras, as I think that they generally do a pretty good job of it, I do think this was clearly a case of someone not having the settings correctly set on the camera, and failing to realize that the Olympus lenses are unstabilized because the body takes care of that function.
 dougjgreen1's gear list:dougjgreen1's gear list
Olympus Stylus XZ-10 Nikon 1 V2 Olympus E-M1 Olympus E-PL7 Olympus PEN E-P5 +17 more
s_grins
s_grins Forum Pro • Posts: 14,011
Stop gnashing your teeth, stop reading reviews. Get camera in hands, and get out to take photos.
Camera in bag tends to stay in bag...
 s_grins's gear list:s_grins's gear list
Panasonic G85 Sigma 60mm F2.8 DN Art Panasonic Lumix G 20mm F1.7 ASPH Sigma 30mm F2.8 EX DN Samyang 12mm F2.0 NCS CS +3 more
Klarno
Klarno Veteran Member • Posts: 4,239
They consider the E-PM2's stabilization as being "better than most"? Most must be unspeakably terrible then.
It's best to stay away from reviewers for whom cameras are not their speciality, as they generally have no idea what is or isn't desirable in a camera. CNET and PC Magazine aren't good camera reviewers for this reason. Consumer Reports should be doubly avoided because electronics aren't even their speciality.
 Klarno's gear list:Klarno's gear list
Olympus E-M1 Sony Alpha NEX-6 Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R Olympus 12-40mm F2.8 Pro +9 more
(unknown member) Senior Member • Posts: 2,445
Re: Consumer Reports? Seriously?
Is this where they criticise the microwave oven because it killed the cat while drying it?
Cheers!
SoundWave76
SoundWave76 New Member • Posts: 6
Don't stress about one review in the interwebz. Keep calm and carry on, as the saying goes... or keep calm and steady hands?
