DiMAGE Master 1.0 + 1.1.0 Update Free Download From Me
Started Aug 14, 2014 | Discussions
Calico Jack Senior Member • Posts: 2,306
Ahoy!
Just in case anyone has been after this software (old as it is), I uploaded it to my personal web space, so if you want a copy, help yourself.  Just click this link and then click the 2 installation files to download.
You can either send a rum ration or a £5.00 donation to my pension fund via PayPal
If you need any KM support, click this link for the KM support website where you'll find firmware, software and user manuals etc for most if not all KM cameras and scanner series.  I'd recommend you add it to your favourites/bookmarks for future reference.
Enjoy!
Mark (aka Pirate!)
John Paul Contributing Member • Posts: 830
Re: DiMAGE Master 1.0 + 1.1.0 Update Free Download From Me
Thanks, I downloaded them, but it asks for a serial number.
Actually, I was just trying to find a copy of DIVU. But all the versions I can find with Google give me a virus (adware) alert when I download them.
John Paul
-- changing the subject line makes threads easier to follow --
http://barkmanart.smugmug.com
 John Paul's gear list:John Paul's gear list
Olympus OM-D E-M5
OP Calico Jack Senior Member • Posts: 2,306
Try: KM5A83TL
Mark (aka Pirate!)
 Calico Jack's gear list:Calico Jack's gear list
Sony Alpha DSLR-A850 Konica Minolta Maxxum 7D Sony Alpha DSLR-A100 Sony DT 11-18mm F4.5-5.6 Tamron SP AF 90mm F/2.8 Di Macro +26 more
darobin1 Regular Member • Posts: 428
Yeah, it requires a software serial number...and that one does not work.
 darobin1's gear list:darobin1's gear list
Canon PowerShot G5 Canon PowerShot G6 Minolta DiMAGE A1 Konica Minolta DiMAGE A2 Fujifilm X-S1 +5 more
The serial number is shown with the downloadable files. Click on Dimage Master 1.0 Full, then v1.0 then Dimage Master S/N .txt which is: KM5A83TL
It's all there people including the PDF manual.  Just click the links and check for sub links for other files.  When you click on the 1.1.0 update, you'll see other files regarding the update.
You will see these links anyway as the downloadable .exe files are also listed with them, so please check all the file links as everything you need is there.
Enjoy!
Mark (aka Pirate!)
jch2103 Junior Member • Posts: 37
It appears DiMAGE Master doesn't like Windows 7 (even in Win 2000 compatibility mode), even with the 1.1.0 update... ('DiMAGE Master has stopped working')
Probably easier to download Photoshop CS2 in that case as it's now free with serial number as supplied by Adobe as they no longer support it.  You can also download the update from Adobe as a separate .exe file.
Mark (aka Pirate!)
Thanks. Actually, I was trying to figure out a work-around for getting A2 raw data into DxO (DxO does support A2 jpg for optical corrections), and I've got CC, so I can do A2 raw developing too, but not both together! Not really critical either way, as the A2 certainly isn't my prime (or even active) camera, but as someone pointed out recently, the macro mode works well. Plus I have some old A2 images I was curious how well I could process...
The A2 was a pretty clever camera for its time, just a bit more advanced than its sensor.
Gesture Forum Pro • Posts: 10,236
:The A2 was a pretty clever camera for its time, just a bit more advanced than its sensor.:
I think you could say the same for Dimage 7.  Still keep the Dimage 5 and Dimage 7 around for infrared, And the G500/600 were excellent cameras for that era.
