One flash in a stereo setup
Started Aug 13, 2014 | Questions
DirkL Regular Member • Posts: 391
Will the shadows be ok when using a flash from only one of the cameras?
Moderate stereo bases, 7 - 14 cm, and subject within 4 - 15 m, assumed.
Thanks.
 DirkL's gear list:DirkL's gear list
Fujifilm FinePix Real 3D W3 Sony RX100 V Sony RX100 VA +9 more
Sailor Blue
Sailor Blue Forum Pro • Posts: 15,536
Re: One flash in a stereo setup
Thanks.
The flash for the Fuji Real 3D W3 is located between the two lenses. If the subject is close to a wall you see a dark shadow on the right side of the subject in one image and on the left side in the other image.  When viewing the image in 3D you can get a sort of shimmering effect with the shadows.  If you place the light above one of two cameras in a 3D rig you will get fewer strange effects but it would be best  to get the flash completely off the cameras.
The best way to use flash is to use it off-camera in a position that simulates more natural lighting, i.e. light from the sun. If you look at most portraits you will see the catchlight is from a light oriented above and about 45° to the side.
If you have a way of firing your off-camera flash with your 3D rig then these tutorials can help you learn how to use your flash. Whether your camera is 2D or 3D won't make any difference.
B&H - Bob Harrington - Off Camera Flash - YouTube
B&H - Bob Harrington - Using Small Flashes on Location Part 1
B&H - Bob Harrington - Using Small Flashes on Location Part 2
B&H - Syl Arena - Quick Start to Off-Camera Flash with Canon Speedlites
Living and loving it in Pattaya, Thailand. Canon 7D - See the gear list for the rest.
 Sailor Blue's gear list:Sailor Blue's gear list
Fujifilm FinePix Real 3D W3 Canon EOS 7D Canon EOS 5DS R Tamron SP AF 90mm F/2.8 Di Macro Tokina AT-X 16-28mm f/2.8 Pro FX +9 more
OP DirkL Regular Member • Posts: 391
Wow, that was a comprehensive answer, thanks a lot
I intend to use a flash as fill flash outdoors. Yes, I noticed strange 3D shadows indoors with the W3 too, and I've read that using two camera flashes in 3D-macro might also result in problematic shadows. So I was wondering.
I am already using a remote control to trigger the cameras, maybe I am able to fire the flash too with it, have to look into it, but I don't think so. But I also will need a second tripod or such, which will be awkward. And since the is plenty of available light, maybe the shadows will not be so harsh?
hdr Senior Member • Posts: 2,867
The flash for the Fuji Real 3D W3 is located between the two lenses. If the subject is close to a wall you see a dark shadow on the right side of the subject in one image and on the left side in the other image. When viewing the image in 3D you can get a sort of shimmering effect with the shadows...
Obviously the single flash and it's positioning on the W3 is not designed or optimized for use in the 3D mode, but in 2D mode it would be fine.
Depth has been the mizzing dimenzion for long enough. But still, few are bothered with 3D.
My favourite 3D-pair site:- http://www.SingaporeGallery.com
Sailor Blue
No, if you use the same trigger for the cameras and the flash the flash will fire before the camera shutters open.  You need a second set of triggers.  With my 7D I use one set of RF triggers on one frequency to trigger the camera.  A second set of RF triggers operating on a different frequency are for the lights - one is mounted on the hot-shoe flash shoe, the other on one of my studio strobes.
For my W3 I made a simple light reflector out of a piece of a plastic box, some aluminum foil, and a bit of glue and tape.  It has a tongue that fits between the camera body and the sliding lens cover to hold it in place over the flash.  The light from the built-in flash is directed upward where it bounces off the ceiling and then triggers my studio strobes.
Another way to use a built-in flash to trigger off-camera flash units is by using a fiber optic cable.  These are sold for underwater cameras but are expensive.  You can make your own for only a few dollars for non-underwater use.
ScubaBoard.com - my own DIY fiber optic trigger (for strobe)
PetaPixel - Trigger an External Flash with Some Fiber Optic Cable
If your flash doesn't have a built-in optical trigger then you could use the fiber optic cable with an optical hot-shoe flash trigger like this one.
B&H - Dot Line Hot Shoe Photographic Slave Flash Unit
3dreal Senior Member • Posts: 2,271
1. optical cable=good. one can use a cheap audio-optical cable. be aware. other photographers could trigger your external flash. you must shield the camera-end. slave flash trigger
2. slave flash trigger must have a preflash-blocking mechanisme. small camflash-power is mostly too low to trigger slave flash trigger if the latter is positioned far away. thats why it should be positioned(with velcro) near flash or optical cable needed. audiocables are quite thick. maybe there are also thin ones.
3. cyclopital3d.com has a flash-option built into one of their devices. dont know which one and if that would help you.
Which cameras are you using?If SDM(stereodatamaker) then it becomes much more complicated-in P-mode. We had multiple deep discussions in the yahoo-list. left flash(dimmed) is firing in advance(not preflash there is a synch-difference , slave flash trigger must not sit near it. main light comes from right flash.
