If you bought a GH4 and one lens to accompany it, which one would it be?
Started Aug 12, 2014 | Polls
Kim Letkeman
Kim Letkeman Forum Pro • Posts: 33,444
Re: If you bought a GH4 and one lens to accompany it, which one would it be?
jeffharris wrote:
Kim Letkeman wrote:
jeffharris wrote:
Kim Letkeman wrote:
L0neW0lf wrote:
-Only one lens! (and the only lens you will have to use with the GH4)
14-140 MK 1 ...
Just curious, but why the 14-140mm I and not the version II?
Slightly sharper in the center, no shuttershock, excellent match for the bigger bodies (Gx, GHx) ....
The penalty is that it is a bit larger and heavier and that it is slightly less sharp outside the center ... but I mostly care about the center on this lens and I have not felt that the corners were a problem anyway ...
Okay. I'm in the process of selling some lenses, including a 14-140mm I to fund a 14-140mm II. I stopped using it after getting bit by the prime bug, so no big deal. My girlfriend doesn't like the bulk of version I and the 14-42mm II I got for her isn't zoomy enough, either.
It should be fine with a Panny body with the eshutter ... otherwise a little luck and some training
I've often thought about grabbing the smaller one, but the cost differential is pretty high right now and those issues, however minor, bug me a bit.
 Kim Letkeman's gear list:Kim Letkeman's gear list
Nikon Coolpix 990 Fujifilm FinePix F770EXR Nikon D600 Nikon D7200 Panasonic Lumix DMC-G7 +27 more
Bob Meyer Veteran Member • Posts: 5,375
I really don't get questions like this.
I by ILCs specifically BECAUSE I can use multiple lenses. If I didn't want to change lenses, I'd just buy an FZ1000.
I could say a 12-35, because it's what I'd use most often. But that would still prevent me from getting at least half of the shots I want to take. I could say the 7-14, because some of the favorite images come from that lens, but it would eliminate at least 3/4 of the shots I take.
So I can't play this game, until someone creates a 7-300 f/2.8 with OIS in a packge about the size of the current 14-140.
 Bob Meyer's gear list:Bob Meyer's gear list
Panasonic Lumix G Vario 7-14mm F4 ASPH Panasonic 12-35mm F2.8 Panasonic Lumix G Vario 14-140mm F3.5-5.6 O.I.S Panasonic Lumix DMC-G3 Panasonic Lumix DMC-G7 +6 more
CobaltFire Regular Member • Posts: 220
Re: I really don't get questions like this.
Some people buy a camera like the GH4 not for the interchangeable aspect, but because the features and capabilities of the camera mose closely match their needs. I would venture a guess that those people are the most likely to want advice pertaining to a "one lens solution" as they have neither the background nor inclination to select and use multiple lenses.
I'd bet the GH4 will see quite a bit of use as a single lens camera for some people due to it's unique blend of great still image capability and astounding video capabilities.
 CobaltFire's gear list:CobaltFire's gear list
Sony Alpha NEX-5N Olympus OM-D E-M5 Canon EOS 6D Sony a6000 Canon EF 17-40mm f/4.0L USM +10 more
Jason1500 Regular Member • Posts: 301
Why no Olympus 12-40 2.8?
The 12-35 is stabilized in lens the 12-40 isn't because of Olympus ibis
 Jason1500's gear list:Jason1500's gear list
Panasonic Lumix DMC-GX8 OM-1 Panasonic Leica Summilux DG 25mm F1.4 Panasonic 12-35mm F2.8 Panasonic Lumix G X Vario 35-100mm F2.8 OIS +4 more
nzmacro Forum Pro • Posts: 18,754
L0neW0lf wrote:
Hello everyone!
Rules are:
-Vote on the poll and then comment with your reasons
Thanks for stopping by! Have a goodnight/day
Only one lens, would have to be the Canon FD 500 F/4.5L with the GH4 in that case. No other lenses appeal. I didn't vote
Danny.
Birds, macro, motor sports.... http://www.birdsinaction.com
Just Kingfisher ..... http://www.flickr.com/photos/96361462@N06/
 nzmacro's gear list:nzmacro's gear list
Sony Alpha NEX-7 Olympus E-M1 Olympus E-M1 II Sony a7R IV Sony FE 200-600 F5.6-6.3 +5 more
bluevellet Veteran Member • Posts: 4,168
Pic Man wrote:
Shooting with a panasonic body the 12-35mm f2.8 would be a better option because of the OIS. The 12-35 and 12-40 are very similar so there is no point in adding it.
Cheaper, with greater range and pseudo macro abilities. Even without IOS, that kind of flexibility when you're limited to one lens should matter.
 bluevellet's gear list:bluevellet's gear list
Panasonic Lumix DMC-GM5 Nikon Z6 OM-1 Sigma 35mm F1.4 DG HSM Art Olympus M.Zuiko Digital ED 8-25mm F4 Pro +23 more
I disagree the OIS on the GH4 body allows photos to be taken in much lower light conditions (4 stops over non-stabilized) & allows for relatively stable handheld video.  The extra 5mm is insignificant....what just take a step or so forward.  And pseudo marco the lumix lens has that too, close focus of 25mm w/ magnification of 0.34x.
Fredrik Glckner Veteran Member • Posts: 3,894
It would be the Lumix X 12-35mm f/2.8, which I think is a fantastic lens, probably the best I have used:
http://m43photo.blogspot.com/2013/01/lumix-x-12-35mm-f28-review.html
schirmer Regular Member • Posts: 443
14-140 since I need different focal for sport acrobatics videos...
Many would never speak with a full mouth, but do it with an empty head.
(Orson Welles)
ms18
ms18 Veteran Member • Posts: 3,530
It does not have f/0.98 (n/t)
No text.
 ms18's gear list:ms18's gear list
Fujifilm X-T20 Fujifilm XF 14mm F2.8 R Fujifilm XF 23mm F1.4 R Fujifilm XF 56mm F1.2 R +1 more
dulynoted
dulynoted Senior Member • Posts: 2,267
25mm nokton. Its all I need.
cameron2 Veteran Member • Posts: 4,142
I just used the 14-140ii today for video the first time. Holy cow, it is a good video lens. I did not expect much at all, but the result looks great. (I only rarely use zooms. I just happened to have this one out because I had been doing testing of "shutter shock".)
 cameron2's gear list:cameron2's gear list
Sony RX100 Panasonic Lumix DMC-GX8 Hasselblad X1D
