Two specific questions about the Samsung EX2F camera...
Started Aug 12, 2014 | Discussions
Ben Herrmann
Ben Herrmann Forum Pro • Posts: 21,163
Hello all...
Just 2 quick questions here. Because I've always been in the game for that "next best" enthusiast model (known as bridge cams or prosumer models in the past), I got a great deal on a new EX2F the other day (should arrive in a few days). I've been meaning to get this camera over the past few years, but for various reasons never got around to pulling the trigger.
1. My 1st question is what Samsung (or Pentax) flash units can effectively handle TTL flash with the EX2F. I have the Metz 44 AF (Samsung dedicated for my NX300), but I'm wondering if this flash will communicate properly with the older (and not X model) EX2F. So any flash recommendations (not manual or auto units) that would effectively mesh with this EX2F would be appreciated.
2. Also, the 2nd question is centered around firmware updates. Can the current Samsung i-Launcher software be used to check for and perform firmware updates to the likes of the EX2F? Or will some other way have to be done (i.e. manually - downloading and then installing that way)? And if it's manually done, can anyone provide me with a link to the Samsung site that may have the latest firmware (if there was even a firmware update released for this model)?
Thanking you in advance....
Have a great one....
Bernd (Ben) W. Herrmann
North Carolina, USA
link
 Ben Herrmann's gear list:Ben Herrmann's gear list
Canon EOS M Fujifilm X-E2S Fujifilm X-T2 Fujifilm X-T20 Canon EOS M6 +4 more
Samsung EX2F Samsung NX300M
Coldamus Senior Member • Posts: 2,281
Re: Two specific questions about the Samsung EX2F camera...
To the best of my knowledge, all Samsung NX flashes are also compatible with the EX2F. e.g SEF-15A, SEF-20A, SEF-42A SEF-220A, etc. The hotshoe layout is the same and so is TTL compatibility. The EX2F even has the two auxiliary power contacts at the rear of the hotshoe for the small NX bundled flashes such as SEF-8A that draw their power from the camera battery.
Pentax flashes are not TTL compatible with Samsung NX or EX series. They worked with the Samsung GX series dslrs which were rebadged Pentax cameras with a few cosmetic and firmware tweaks.
I can't say specifically that your Metz 44 AF will be compatible but can't see why not.
I checked the Australian and Canadian support sites and in both cases the only download available for the EX2F under "firmware" is the i-Launcher upgrade guide (pdf).
http://downloadcenter.samsung.com/content/FM/201307/20130730171808062/i-Launcher_guide_for_SEC_Camera_ENG.pdf
That seems to indicate that i-Launcher is your only option.
Ben Herrmann
OP Ben Herrmann Forum Pro • Posts: 21,163
Thanks, I appreciate that detailed information...
I didn't want to miss the opportunity of getting this EX2F camera before it became an afterthought on eBay (meaning used models).
I appreciate your detailed response.
North Carolina, USA
link
Bouldergramp
Bouldergramp Contributing Member • Posts: 616
Firmware updates are via iLauncher.  I have done two of them with no problem.
Bouldergramp, USA
 Bouldergramp's gear list:Bouldergramp's gear list
Samsung EX2F Panasonic Lumix DMC-ZS50 +3 more
