NX1100 with Fotodiox M42 to NX lens adapter "No Lens" or "Lens Detached" error
Started Aug 12, 2014 | Discussions
ConcertPhotog Regular Member • Posts: 144
Hi. As the title says, I'm receiving this error message with my new adapter. I have two other adapters (FD and MD/MC, one Fotodiox and the other Rainbow Imaging) which work fine.
Should I return the adapter and try a new one from Fotodiox? Try another brand? I read about some 'fixes' on the web, but they seem pretty scary, involving tape or glue.
Any advice?
Thanks!
 ConcertPhotog's gear list:ConcertPhotog's gear list
Canon EOS 5D Canon EOS 6D Samsung NX1100 Canon EF 50mm F1.4 USM Canon EF 100mm f/2.0 USM +7 more
Samsung NX1100
xorgh Forum Member • Posts: 84
Re: NX1100 with Fotodiox M42 to NX lens adapter "No Lens" or "Lens Detached" error
It may be the same problem like this: http://www.dpreview.com/forums/post/53115241
 xorgh's gear list:xorgh's gear list
Samsung NX1 Samsung NX 50-200mm F4-5.6 OIS Samsung NX 45mm F1.8 Samsung 16-50mm F2.0-2.8
OP ConcertPhotog Regular Member • Posts: 144
Yes. I've done some more reading on this, and it seems they can be modified with epoxy and then sanded. I ordered one from Rainbow Imaging last night. If it works, I'll return the Fotodiox. If not, I may modify one. Both of those were available via Amazon Prime.
Received the Rainbowimaging adapter today. Works perfectly. Fotodiox model is going back.
wpstl Senior Member • Posts: 1,251
I had the same problem with a Fotodiox adapter for Nikon to NX. They can't seem to make one that works for NX.
 wpstl's gear list:wpstl's gear list
Samsung NX1 Sony a7R II Sony a7R III Samsung NX 85mm F1.4 ED SSA Samsung NX 60mm F2.8 Macro ED OIS SSA +5 more
My Canon FD to NX works fine, though I did have trouble getting it to 'lock' at first to the lens properly. Not sure what that was about.
This is my second Rainbow Imaging NX adapter (MD/MC and M42) that has worked flawlessly.
