Hugh J
Regular Member
Re: What fast 35mm eqiv. lens would you recommend for m43?
Bots_Revenge wrote:
I'm considering buying a 35mm equiv. fast prime for my m43 bodies. My plan is to shoot weddings with 35mm, 85mm and 150mm primes on three bodies - 2x GX7 and E-PL5. Most times I may be using only two bodies with 35 and 85mm.
35 on one GX7, 85 on the other GX7. E-PL5 in the trunk of your car, for backup, with a medium zoom attached, or your 25/1.4 which can sub out either of the 35/85 in a pinch if one or both of them break. Plenty of batteries. Small flash on a TTL cord held off camera, just to keep the ISO low when in darkness because as great as these cameras are, they ain't no 5D MkIII.
My current prime setup is 12mm f2, 25mm f1.4 and 45mm f1.8 (now is 42.5mm f1.2).
Anything wider than say 28 is a gimmick lens for weddings. You'll want to use it sparingly because of the distortion especially at or near the edges of the frame. I wouldn't even bother bringing it.
I'm seeing three options:
1. m.Zuiko 17mm f1.8 - appears to be tremendously mediocre in terms of sharpness except in the absolute center
2. PL 15mm f1.7 - looks sharper, but I really would have liked it to be further away from 12mm so that I don't feel like I've cropped 5% off my 12mm lens - I'd prefer a 35mm equiv instead of 30.
3. Voigtlander 17.5mm f0.95 - as I hear it's very sharp, but weighs way too much and I'd rather have AF instead of straining my eyes with the dynamic nature of weddings.
The 17/1.8 is sharp enough for weddings, despite what you may have read. Don't think of the 15 as being "too close" to the 12, which as I noted above you will want to use sparingly or not at all. Rather, the right question is whether or not the 15 offers you the FoV such that you'll be comfortable using it as your main lens. If you shoot 3:2 format it's actually very close to a 35 equivalent. For me, using it at my default 4:3 I would find it too wide for my main lens.
From the options I seem to have I'm disappointed because the Oly and Pana lenses just don't seem to be what I want. The Zuiko is closest to my preferences but when put next to the Nocticron and the 75mm f1.8 it isn't nearly sharp enough to match them.
My questions are:
1. Am I missing some alternative? Is there any other lens to consider?
2. Do any of the three lenses have any other strengths to consider?
3. Which lens in your personal opinion is best for the job?
I would use a 20/1.7 as my main lens. Closest to "normal" for this format with little to no wide angle distortion, leaving me to concentrate on my work at least until a tight portrait is needed.
