What fast 35mm eqiv. lens would you recommend for m43?
Started Aug 11, 2014 | Questions
Bots_Revenge
Bots_Revenge Regular Member • Posts: 125
I'm considering buying a 35mm equiv. fast prime for my m43 bodies. My plan is to shoot weddings with 35mm, 85mm and 150mm primes on three bodies - 2x GX7 and E-PL5. Most times I may be using only two bodies with 35 and 85mm.
My current prime setup is 12mm f2, 25mm f1.4 and 45mm f1.8 (now is 42.5mm f1.2).
I'm seeing three options:
1. m.Zuiko 17mm f1.8 - appears to be tremendously mediocre in terms of sharpness except in the absolute center
2. PL 15mm f1.7 - looks sharper, but I really would have liked it to be further away from 12mm so that I don't feel like I've cropped 5% off my 12mm lens - I'd prefer a 35mm equiv instead of 30.
3. Voigtlander 17.5mm f0.95 - as I hear it's very sharp, but weighs way too much and I'd rather have AF instead of straining my eyes with the dynamic nature of weddings.
From the options I seem to have I'm disappointed because the Oly and Pana lenses just don't seem to be what I want. The Zuiko is closest to my preferences but when put next to the Nocticron and the 75mm f1.8 it isn't nearly sharp enough to match them.
My questions are:
1. Am I missing some alternative? Is there any other lens to consider?
2. Do any of the three lenses have any other strengths to consider?
3. Which lens in your personal opinion is best for the job?
 Bots_Revenge's gear list:Bots_Revenge's gear list
Olympus PEN E-PL5 Panasonic Lumix DMC-GX7 Panasonic Leica Summilux DG 25mm F1.4 Samyang 7.5mm F3.5 Fisheye Olympus M.Zuiko Digital ED 75mm F1.8 +3 more
Araldite Contributing Member • Posts: 829
Re: What fast 35mm eqiv. lens would you recommend for m43?
I think you might find the olympus 12-40mm f2.8 (24-80 in 35mm terms) would be very useful for weddings. I wish I had it when I used to do weddings. Failing that I would use the following primes
Lumix 15mm (30mm equiv)
Lumix 25mm (50mm eqviv)
Olympus 60mm macro (120mm equiv)
However whilst you are changing cameras, I would have got the shot with my 12-40.
Good Luck
David
 Araldite's gear list:Araldite's gear list
Fujifilm X-S10 Fujifilm 50-230mm Fujifilm 15-45mm F3.5-5.6 OIS PZ +2 more
biza43 Forum Pro • Posts: 15,074
I don't know where you are getting this "appearance" from, it's a fine little lens. And the one that I would recommend.
Of course it is not, but you are comparing it to two of the sharpest lenses available for MFT... again, this is far from being "tremendously mediocre"...
My questions are:
Yes, you could rent the 17 1.8 and try it out for yourself, instead of going with hear say...
This is what SLRGear have to say about the lens regarding its sharpness:
"Sharpness
The Olympus 17mm ƒ/1.8 m.Zuiko provided surprisingly sharp results. When used wide open at ƒ/1.8, there is some corner softness to speak of (and more towards the top of the frame), but the majority of the frame is very sharp. Stopping down provides an increase of sharpness, and for maximal sharpness you'll need to stop down to ƒ/5.6. At ƒ/8, diffraction limiting begins to set in, but there isn't a significant impact on sharpness until ƒ/11, and even then it's just a slightly overall decrease. Images start to lose their sharpness at ƒ/16, and become moderately soft at ƒ/22."
www.paulobizarro.com
 biza43's gear list:biza43's gear list
Fujifilm X-T3 Fujifilm X-T4 Fujifilm XF 16mm F1.4 R WR Fujifilm XF 70-300 F4-5.6 R LM OIS WR Fujifilm XF 33mm F1.4 R LM WR +1 more
Advent1sam
Advent1sam Veteran Member • Posts: 9,089
Bots,
I have found the 20mm mk1 very nice for low light on the Gx7, it is actually faster than ever on the Gx7 although it wont be upto the 42.5, you should try it in a shop or sale or return first? I use it in burst mode and electronic shutter and burst away, it acquires focus fast and as people are blinking and moving you can pick the bets of the bunch from the bursts, they don't even know your clicking away. I use the sandisk 95mb sd's to speed the write up a bit too. The 20mm is still a sublime lens and surprisingly gives very little up to the 35mm width. On the Oly em5 it used to have a banding issue even as low as iso800, not sure if it does on the epl5 and you may find focussing a little pedestrian on that too.
My questions are:
SkiHound Veteran Member • Posts: 3,939
You might rent a 17 f/1.8 and give it a trial. It's a lens that most users, including me, find very satisfying. I know it doesn't put up stellar numbers in formal tests but I think it's more than sharp enough and produces really nice images. If you really pixel peep I think the PL25 is a bit sharper but I don't notice a difference in images at typical viewing sizes. Wide open it suffers some in the corners and it does vignette a little, though for people pictures those faults are sometimes assets. It focuses very fast and handles well. The manual focus clutch is very useful. I do think it's more designed for street/social/people rather than architecture or landscape.
Bots_Revenge
OP Bots_Revenge Regular Member • Posts: 125
@Araldite - Thanks. I should have mentioned that I have the 12-40 f2.8 and the 35-100 f2.8. I love them both for numerous reasons.
The reason I want to shoot primes is that I can get more subject separation especially with the shorter lenses. When I shoot with the 12-40 shoulder to shoulder with my colleague with 5D mk III + 24-70 f2.8, my shots look like they are coming from a compact camera in terms of DoF.
I'm not looking to recreate the DoF of FF primes but at least to be close to the standard zooms.
@biza43 - I'm getting that impression from the image samples in photozone.de and photographyblog.com. What I mean by mediocre is not by m43 standards but in the whole range of competitors from other systems. I shoot alongside people with FF cameras with the highest grade lenses. My 12-40, 35-100, 75mm, 42.5mm, 45mm and 25mm f1.4 hold no punches and produce images that can be indistinguishable from the FF cameras. The 17m f1.8 just looks out of that league. Indeed I shall try it for myself.
I also tried giving some of the image samples some smart sharpening and they do become quite alright but that means I have to separately sharpen them.
@Advent1sam - I have thought about the PL20mm f1.7. I had the mk I before and it was amazing in terms of sharpness. Such a joy for the eyes. Unfortunately on my E-PM2 it was indeed quite slow to focus. I shall try it on my GX7 but I have my reservations about the focal length since I will not be using a wider lens when I put this one on.
@SkiHound - thank you for the input! I will try for myself.
I also have the 12-40, the 75, and will soon have the 25 1.4. Indeed these lenses are one notch above the 17mm 1.8, but then, they cost a whole lot more. As for FF, well, I also shoot with a Canon 6D and Zeiss 21, so yes, again, a different league.
However, photography is about compromising and in that regard, there are a lot worse "compromising" than the 17mm 1.8. It's a fine little lens on its own, and it is cheap. Should Olympus or Panasonic come up with a 17mm lens that would be on par with some of the lenses mentioned above? Well, perhaps yes, for some users need the absolute best in the format, but then the cost would rise accordingly.
Bots_Revenge
I personally can put up with the prices if the lenses are as high quality as the 75, 12-40, 42.5 f1.2, 35-100 and so on.
Ulric Veteran Member • Posts: 4,559
Actually I think the 17/1.8 would be excellent.
One lens you didn't list is the Panasonic 20/1.7. It would be unsuitable on an E-PL5 because of problems with banding - clearly unacceptable on a once in a lifetime event like a wedding. But it would probably be great on a GX7.
 Ulric's gear list:Ulric's gear list
Panasonic Lumix DMC-GF3 Olympus OM-D E-M5 Panasonic Lumix DMC-GM1 Olympus PEN-F Panasonic Lumix G 20mm F1.7 ASPH +13 more
Pic Man Senior Member • Posts: 1,310
I imagine for wedding photography the centre will be the most important area. I think in real world picture the oly 17mm isn't actually that bad, not amazing but good enough.
You could sell your 12mm and buy this. Pretty decent lens optically and with the aperture ring it will complement the 42.5mm. Also remember if you crop to 3:2 ratio the lens will be more like 31mm.
My questions are:
You could consider buying a fixed lens 35mm camera like the fuji x100s or even better the sony rx1 but then you'd have to learn another camera.
Personally I'd go for the 15mm. I like something a bit wider though, easier to get closer than further away but I don't shoot weddings and it's just my preference.
Good luck with your choice
xerophytenyc Regular Member • Posts: 434
Voigtlander hands down should be the best as it is fast and sharp, rendering is fantastic.  With a little practice, focusing can be very quick with the help of focus peaking.  As long as you're not trying to photograph kids running around you should not have difficulty focusing.  Beyond a few feet the focus range moves quickly on the lens, no need for lots of turning.  Maybe try manual on one of your existing short FL lenses and see how it works for you.
 xerophytenyc's gear list:xerophytenyc's gear list
Sony RX100 II Panasonic Lumix DMC-GH4 Voigtlander Nokton 42.5mm F0.95 Voigtlander Nokton 17.5mm F0.95 Aspherical Olympus Tough TG-2 +6 more
Bots_Revenge
I have tried manual focusing but the "focus by wire" system adapts to the speed I'm turning the ring so if I try to remember where a certain position of the ring puts the focus plane, once I turn the ring back and forth the position will not match. This is an advantage of the Voigtlander indeed.
I have to test it but I'd rather have a lighter lens than that piece of chunky metal.
G1Houston Veteran Member • Posts: 3,188
Many would prefer to use two zoom lenses.  12-35 or 12-40 plus 35-100.  You may want to get a macro lens for close up of rings and other small decorative items at wedding, and the 42.5 for formal head/shoulder shots.
If you already have a 25 mm lens, do you really need a 20-15mm lens?
As many have said this "tremendously" misrepresents the capability of this lens.
Pannasonic 20/1.7.
 G1Houston's gear list:G1Houston's gear list
Nikon D7100 Panasonic Lumix DC-GX9 Panasonic Lumix G 20mm F1.7 ASPH Panasonic Lumix G 14mm F2.5 ASPH Nikon 85mm F1.8G +6 more
Bots_Revenge
Pannasonic 20/1.7.
The 12-40 f2.8 offers an admirable closeup ability. I also have extension rings for extreme closeups. I do like the flexibility of the zooms (that I have) and the 35-100 also gives me quite satisfying defocus control. The 12-40, although a stunningly good lens, has depth of field that is sometimes too large. That's why I'm aiming at two well balanced primes in terms of FoV and DoF. 35mm equiv. seems right on the money as it is not too wide or narrow for my wider lens.
I'm also trying to move away from the PL 25mm f1.4 because on my Pens I often have issues with missed focus. I'm also not too pleased with the accuracy I get with the 12mm f2.
I must say that I've always used the touch screen to place a small AF point instead of choosing one of the available 35 small points on the E-PM2/E-PL5. Perhaps on the GX7 the accuracy will be higher and I could keep the 12mm f2 and the 25mm f1.4.
Still I want to move from using three narrowly spread focal lengths (24, 50, 85mm equiv.) and use 35 and 85mm. Since I plan on using two GX7s and at times the E-PL5, I can put the 35mm equiv. on it and use 85mm and 150mm on the two Panasonics.
So now I'm about to try out the m.Zuiko 17mm f1.8 and the Voigtlander 17.5mm f0.95. The price of the Voigtlander is 2.5x higher and it weighs 4.5x more so it'd have to perform spectacularly to justify me carrying that weight, paying so much money and bothering to manually focus.
Thank you all for your input! I appreciate your advice and will consider all that's been said.
Bhima78 Senior Member • Posts: 2,850
Honestly, for what you are looking for you already have it covered.
You say you want a shallower DoF for subject isolation, but you really aren't going to get much with either the 17mm 1.8 or the 15mm 1.7 on m43's without serious subject distortion. Your best bet is to have the 12-40 on one camera, 35-100 on another and then a portrait prime (45mm or 75mm). If you want just primes... your setup is already as good as it gets for the most part: 12/2, 25/1.4, 45mm/75mm.
 Bhima78's gear list:Bhima78's gear list
Panasonic Lumix DMC-GX8 Panasonic Lumix DMC-GX85 Panasonic G85 Panasonic Lumix G Vario 7-14mm F4 ASPH Panasonic Lumix G X Vario 35-100mm F2.8 OIS +12 more
frankmurphy Junior Member • Posts: 38
You could try the snapback focus ring on your 12-40. It's still focus-by-wire, but I believe that it keeps the physical ring lined up with where the focus is.
 frankmurphy's gear list:frankmurphy's gear list
Olympus OM-D E-M10 Panasonic Leica Summilux DG 25mm F1.4 Olympus M.Zuiko Digital 45mm F1.8 Samyang 7.5mm F3.5 Fisheye Panasonic Lumix G Vario HD 12-32mm F3.5-5.6 Mega OIS +2 more
Re:Olympus 17mm
biza43, I have the pany leica 15mm f1.7, I sold my 25mm f1.4 as I find the extra width better for me. It's just as good as the 25mm. I bought the 15mm for indoor shots of buildings
Henry Richardson Forum Pro • Posts: 21,959
If you don't like the Olympus 17mm f1.8 you can look at the Sigma 19mm f2.8 and Olympus 17mm f2.8 also.
Henry Richardson
http://www.bakubo.com
Bots_Revenge
Thanks! I would avoid f2.8 lenses because I already have some of the best and also because f2.8 doesn't provide shallow enough DoF with short lenses. If There was a 17mm f1.2 lens and it was good, I'd buy it.
I haven't read through the whole thread, but it seems like you have eliminated all the options for m4/3 since none are good enough for you. I think you are in the process of convincing yourself to switch to Fuji, Sony, Leica, Canon, Nikon, or some other option. It seems like it is the only solution. Expensive to switch, but in order to get a fast 35mm equivalent that meets your requirements it seems the way to go.
Henry Richardson
