DP2M shutterbutton stuck
Started Aug 10, 2014 | Discussions
Vakr New Member • Posts: 17
Hello,
I've got a problem with my DP2M as dust or sand has gotten into the shutterbutton/release and its not possible to push it anymore. I'm currently travelling and have no option to turn the camera in for service. Not sure if this can be fixed with limited means. Any suggestions welcome.
MOD Kendall Helmstetter Gelner Forum Pro • Posts: 20,256
Re: DP2M shutterbutton stuck
Can you at least get some small screwdrivers to take off the case? You may not have to take it apart much to get to the switch to blow it out a bit.
Also you could try a can of compressed air, blowing into the edges of the button. as you roll around the top in a circular motion to try and convince some of the sand to blow out.  Heck, perhaps even without the compressed air if you just did that with the camera upside down it would shake out whatever is stopping it.
 Kendall Helmstetter Gelner's gear list:Kendall Helmstetter Gelner's gear list
Sigma 70-200mm F2.8 EX DG OS HSM Sigma 8-16mm F4.5-5.6 DC HSM Sigma 24-70mm F2.8 EX DG HSM Sigma 50-500mm F4.5-6.3 DG OS HSM Sigma 85mm F1.4 EX DG HSM +4 more
