GH4 Eye Sensor AF? What is it? Anyone get it to work?
Started Aug 6, 2014 | Discussions
geogan
geogan New Member • Posts: 14
"Together with the Eye Sensor AF which starts focusing by just looking into the viewfinder, the AF/AE lock button works for AF for quick auto focusing even when using the LVF. "
I'm confused about this Eye Sensor AF thing.
What I thought it meant was that when you looked at something in the viewfinder the camera would figure out what point you were looking at and focus at this point. Some old cameras had this tech I think.
But I can't see any sort of autofocus mode on the camera that behaves like this.
Is this what it means?
From what I can see all the "Eye Sensor" does is turn off the external LCD panel when you get close to it and turns on the EVF. But this is NOT the "Eye Sensor AF" advertised.
Note: this is not the Eye Detection AF ie. "GH4 incorporates Eye Detection AF which automatically sets focus right on the eye of human face."
 geogan's gear list:geogan's gear list
Canon EOS-1D Mark II Panasonic Lumix DMC-GH4 Canon EF 16-35mm F2.8L USM Canon EF 24-70mm f/2.8L USM Canon EF 70-200mm f/2.8L IS USM +2 more
amipal
amipal Senior Member • Posts: 1,275
Re: GH4 Eye Sensor AF? What is it? Anyone get it to work?
I use it on my GH3 - it simply means that, when the eye-sensor detects that you're close to the viewfinder, it's starts to focus on whatever the camera is pointing at/where the AF point is set.
Paul
 amipal's gear list:amipal's gear list
Panasonic Lumix DMC-GH4 Panasonic Lumix DMC-GM5 Panasonic Lumix DC-G9 Panasonic Lumix G 20mm F1.7 ASPH Panasonic Leica Summilux DG 25mm F1.4 +7 more
uRebel Rob Senior Member • Posts: 1,537
I have it on too on my GX7. Since I'm usually on AF-S, it only focuses when I first look into the EVF, much like a half press on the shutter. Since I don't use AF-C, I'm not sure if it continuously AF the whole time while you're looking through the EVF, but it sounds like it.
 uRebel Rob's gear list:uRebel Rob's gear list
Pentax K-1 Panasonic Lumix DC-G9 Olympus M.Zuiko Digital ED 60mm F2.8 Macro Pentax FA 28-105mm F3.5-5.6 Nikon D5100 +21 more
gugarci Senior Member • Posts: 1,622
Me too. I always have it on my GX7.
 gugarci's gear list:gugarci's gear list
Panasonic Lumix DMC-LX3 Sony a6000 Sigma 19mm F2.8 EX DN Sony E 16-50mm F3.5-5.6 PZ OSS Sigma 30mm F2.8 DN | A +3 more
TN Args
TN Args Forum Pro • Posts: 10,687
uRebel Rob wrote:focuses when I first look into the EVF, much like a half press on the shutter.
That's right.
It's not what the OP thought.
call me Arg
 TN Args's gear list:TN Args's gear list
Sigma dp0 Quattro Panasonic Lumix DMC-GX7 Olympus E-M5 II Sony a7R III Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 +10 more
pannumon Veteran Member • Posts: 4,130
The difference between Pre-focus and AF-C
I have no experience with GH3/GH4, but it sounds that Eye Sensor AF means that pre-focus is enabled when eye sensor detects the eye (from infrared radiation). Pre-focus at least in older models means that there is continuous focus when shutter release button IS NOT pressed at all, whereas AF-C means that there is continuous focus when the shutter button release IS (half-)pressed. Pre-focus + AF-C means that the camera is focusing all the time. I don't use either.
Panasonic Lumix DMC-GF1 Panasonic Lumix DMC-GH2 Panasonic Lumix DMC-GM1 Panasonic Lumix DMC-GM5 Panasonic Lumix DMC-G7 +21 more
geogan
OP geogan New Member • Posts: 14
Right, well it's not what I thought it meant then - that's a very basic feature then. I was thinking it was a way more advanced eye-tracking-focus system that would focus on the point your eye is looking at in the viewfinder and continue to track your eye position and refocus as where you looked changed.
I seem to have got this impression both from the name they choose to call it and what I seem to remember was on one of the brochure sites for the camera on some Panasonic site. Maybe they deliberately did this to make people think it was the more advanced system...
Poweruser Contributing Member • Posts: 516
Nah... the only eye-controlled AF system is in the Canon EOS 5 I think. That´s a film camera. Not the 5D.
TN Args
Been done and dropped many moons ago.....
call me Arg
lattesweden
lattesweden Veteran Member • Posts: 5,583
Many if not all Pana cameras have Face detect AF meaning they will focus on the face. Olympus has that in combination with Eye-focus so it is searching and marking the eye nearest the camera with an extra small frame and focuses on that. It works fairly well on my PL5. My Pana G6 with the face detect AF is not as good as nailing the focus on the eyes.
But GH4 seams to have a special new mode similar to Olympus. From the GH4 manual I googled up:
The camera automatically detects the person’s face
and eyes.
An eye closer to the camera will be in focus, while
the exposure will be optimized for the face. (When
[Metering Mode] is set to [ ])
• Up to 15 faces can be detected. Eyes that can be
detected are only those of the face that is in focus.
• You can change the eye to be in focus. (P97)
• Position and size of the AF area can be changed. (P101)
Best regards
/Anders
I'm from Sweden, but my pictures are in all languages: http://500px.com/anderslattermann
Bob Meyer Veteran Member • Posts: 5,375
I don't recall reading anything, from Panasonic or elsewhere, that implied it was more than it is. I thnk you just didn't read carefully. It was clear to me what it does.
 Bob Meyer's gear list:Bob Meyer's gear list
Panasonic Lumix G Vario 7-14mm F4 ASPH Panasonic 12-35mm F2.8 Panasonic Lumix G Vario 14-140mm F3.5-5.6 O.I.S Panasonic Lumix DMC-G3 Panasonic Lumix DMC-G7 +6 more
jefrs Junior Member • Posts: 48
This keeps coming up.
The Panasonic "Eye Sensor AF" will, as the Instruction Manual says, " automatically adjust the focus when the eye sensor is active". When your eye is on the EVF it will continually focus and adjust focus within the focus box (whatever you have set)
It is not tracking
It is not AFC
It will not work well in low light.
It is not fast.
It has a limited range of focal distances
It will not lock the focus as the half-press does.
It is for framing the shot so you can see what you are looking at, not focussing to shoot.
It is very useful. You pick the camera up to your eye and can see what you see.
 jefrs's gear list:jefrs's gear list
Olympus C-2040 Zoom Panasonic Lumix DMC-FZ200 Panasonic Lumix DMC-G5 Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GH4 +4 more
