Olympus 75-300mm II for Closeups
Started Aug 6, 2014 | Discussions
MarkLeeds2k5 Regular Member • Posts: 115
Playing with my go-to lens again, the m.zuiko 75-300mm II, this time for closeups of small subjects.
I've thought about getting a dedicated macro lens, but I've come to the conclusion that I prefer close up shots to actually be not-so-close, still allowing for some environment to be included.
I know you can't get anywhere near the 1:1 of true macro with this lens. However while the 75-300 requires some degree of cropping afterwards, the benefit of not having to get too close to the target is a tradeoff I think I'm happy with. The dragonflies for example wouldn't let me get within 6 feet before flying away.
All hand held with ibis:
This last one was taken with the all mighty Olympus 12-40mm, but in my personal opinion the image quality is not noticeably better than those above, which again is another pleasant surprise.
I'd be interested in hearing other people's experiences with the 75-300 II for close ups like this.
lambert4
lambert4 Senior Member • Posts: 2,335
It all comes down to lighting...
I love the dragonfly shots I seldom see them here in my neck of the woods in AZ but think they are beautiful creatures.
I have been trying to get used to the lens myself, the close focus distance minimum is the toughest adjustment for me. But the ability to bump ISO so high has really helped, these are ISO 2500 hand held as well.
Shot with m.zuiko 75-300 on EM5
Posted in the Oly SLR forum as well
Here's to learning something new everyday, and remembering it the next.
 lambert4's gear list:lambert4's gear list
Nikon D500 Sigma 10-20mm F3.5 EX DC HSM Nikon AF-S Nikkor 70-200mm F4G ED VR Tamron SP 150-600mm F5-6.3 Di VC USD Nikon 35mm F1.8G ED +3 more
Gregm61 Forum Pro • Posts: 15,899
Re: Olympus 75-300mm II for Closeups
The way you are doing it works beautifully. Very nice.
This lens also works very well with dedicated extension tubes. I use the Kenko 10mm and 16mm tubes with mine quite often for floral closeups. You can get in quite close, but the focus range is limited at any one focal length, so you have to zoom the lens to the right spot where it will focus correctly. Easier than it sounds after you get the hang of it. I was doing this with my Olympus DSLR's and the 50-200 and 70-300 Zuikos with the EX25 tube. As soon as Kenko came out with their Micro Four-Thirds tubes I nabbed a set to use with the 75-300 and it works great.
"There's shadows in life, baby.." Jack Horner- Boogie Nights
Old Listener
Old Listener Senior Member • Posts: 2,028
Re: It all comes down to lighting...
Lots of fine pictures in this thread.  Using the 75-300mm lens is working for both of you.
 Old Listener's gear list:Old Listener's gear list
Panasonic Lumix DMC-FZ50 Panasonic FZ1000 Panasonic Lumix DMC-G6 Panasonic Lumix DMC-G7 Panasonic Lumix G Vario 100-300mm F4-5.6 OIS +5 more
Anders W
Anders W Forum Pro • Posts: 22,144
Nice examples of the utility of this lens for close-ups. I use my tele zooms for that purpose too (previously 40-150 and 100-300, now 40-150 and 75-300 II). Although you can't get to 1:1, you can get a bit more magnification by means of extension tubes (which I have found preferable optically to close-up lenses with these tele zooms although you get less magnification). The below samples (first two with the 100-300, last with the 40-150) were all shot with extension tubes. I haven't yet had the time to shoot much close-ups with the 75-300 II since I bought it only a few months ago. But I expect it to work just as well as the 100-300 for this purpose.
Panasonic Lumix DMC-G1 Olympus PEN-F Olympus E-M1 II Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS Panasonic Lumix G Vario 7-14mm F4 ASPH +20 more
ysal
ysal Veteran Member • Posts: 8,769
I've used extension tubes with my Panny 100-300mm and works very well.  Except I bought a cheap set of tubes and I found some light leaking into the system resulting in hazy images when the camera is pointed towards a bright background.  I think if I buy a good quality set of tubes (Kenko's), I should have great results.  I'm also experimenting with attaching a diopter in the front.  I'll report out when I get good results.
yuki
 ysal's gear list:ysal's gear list
Panasonic Lumix DMC-FZ150 Panasonic Lumix DMC-GX7 Canon EOS 80D
Anders W
What you might be seeing is reflection of light off the inner barrel of the tubes rather than "leakage". See the post to which I link below and the subthread that follows for a discussion of this problem and a cheaper alternative to the Kenko tubes that appears to be free from this issue:
http://www.dpreview.com/forums/post/51893286
OP MarkLeeds2k5 Regular Member • Posts: 115
Anders, are these the extension tubes you use?
http://www.amazon.co.uk/automatic-extension-Olympus-panasonic-thirds/dp/B00CANGBIK
Anders W
Right. Build-quality is definitely so-so. They feel really cheap. But they are light, gets the job done, do have an inner barrel properly designed to reduce inner reflections and don't cost much.
Ordered a set. Given how little room/weight they'll take up in my camera bag, figure they're worth having for the few occasions when I will want to get even closer.
