Re: Real Estate Photography Tips Pretty Please
fuesting wrote:
My friend (realtor) has asked me to shoot a very nice home that he just listed, so I'm throwing my hat into the world of real estate photography sometime this week. It's a vacant house that is apparently beautiful. I do not think it's furnished at all. I will have as much time as I need in the house. I really don't know what I'm doing in the sense that I have never shot real estate and my strategy is to just copy what others have done.
Would any of you have any tips for me? I'm looking for pretty much any information.
My gear consists of an E-M1, 12-40mm f2.8, 25mm f1.4, 45mm f1.8, 75mm f1.8, and a 40-150mm f-cheapo. I also have a sharp Canon FD 50mm f1.4 w/ adapter. Of course an old tripod that "works".
My game plan is to shoot most of it at 12mm and maybe HDR? Maybe do HDR in post. The house itself has an incredible view of Pittsburgh. I figure I better show that off. Should I bring a ladder for a more top-down approach to showing rooms? Any panoramas?
Thanks in advance!
First, I've only done architecture shots for fun, so salt and all that.
Depending on how large the rooms are, 12mm might not be wide enough. The 9-18, 7-14, and normalized fisheye 9, 8, and 7.5mm lenses would be better for interior shots. Unfurnished will make it easier and harder. Not as much stuff in the way, but also not as much in the photo. This also might let you use the 12mm, but the wider angles make the rooms look bigger, a plus for small rooms.
Make sure the verticals are straight up and down. Furnished this is usually easier from 3-4 ft off the ground, as then the chairs and tables don't look tilled. Unfurnished, I guess halfway between the floor and ceiling might work better. Non-normal views also draw the eyes; another reason the 3 ft shots work well. A ladder might give a cool view, but I wouldn't expect it to unless it's a split level house, or one level can over see a lower one.
Try shooting from corners, walls, and through doors. Wireless remotes help shooting the corner shoots after it's set up. If it's unfurnished, what are you going to do for lighting?
If it has a great view, use it! Use a window to frame that view. If there are large windows, give half the image to the interior and half to the view. HDR will help for sure, and PP can give better images than in camera if you know what you're doing. I don't like the super HDR look, and I think the HDR that looks like a normal shot works better for realtor shots. If you have all day, and aren't pratived at PP HDR, shoot both in camera and bracketed. I'd try to make sure it doesn't look fake or PSed.
Outdoor shots depend on the house size and property size. A ladder here might help a lot to show the house and the view.
edit: listen to the others more than me.
