Questions about NX1000 and NX1100
Started Aug 4, 2014 | Discussions
CMurdock Contributing Member • Posts: 819
In my search for a camera with accurate colors, I discovered that the NX1000 produces JPGs with some of the most accurate colors on the market, so I'm looking at that camera or the NX1100, which appears to be substantially similar.  However, I have some questions:
1. Are these old cameras?  They are available on Amazon, but the large camera retailers have stopped carrying them.
2. Are macro photos sharp?  A web site which reviewed the NX1000 said that very close-up macro images are soft in the center; but I photograph my products from about a foot away.  Can I expect sharp images at that distance (with the kit lens)?
3. I had a Nikon camera which I returned because it displayed the camera settings (accompanied by a multitude of icons & symbols) on the screen for 3 seconds after each shot.  That made it hard to frame the next shot.  Can I set these cameras so that they show nothing on the screen after a shot except the view through the lens?
I sell colorful glass beads on the internet, and I'll be using the camera to take product shots; but I also want to use it as my all-around camera.
Thank you!
Samsung NX1000 Samsung NX1100
vatazhka
vatazhka Regular Member • Posts: 355
Re: Questions about NX1000 and NX1100
Yes, they've been both discontinued - which means no more firmware updates, i.e. no support for 2014 and newer lenses (The 2014 ones work with the camera but are reported to zoom more slowly, miss some functionality etc.). However, I find the software to be quite stable - I haven't experienced any software freeze during few hundred hours I used this camera. Tizen-based ones (e.g. NX2000 and NX300) are reported to hang occasionally.
This obviously depends on lens. I'm not sure what kit lens you were referring to, but I found 20-50mm to be sharper than 18-55mm in good lighting. Just keep in mind that autofocus may struggle with object close to minimum focussing range (28cm for both kit lens IIRC).
However, I wouldn't bother that much since you probably don't need to publish these pictures in A4 format and "softies" when downscaled will look much sharper (Downscaling can be performed in-camera.). If this bothers you - there are nice primes (incl. the 60mm macro) in the NX lineup which help to achieve better IQ.
Yes, you can disable UI elements selectively (icons on the left / on the right of display, histogram etc.). If you disable displaying preview of the photo after capture, you should get the behaviour you want. I can check this for you when I have some time to play with the camera.
I can assure you that this is a great all-around camera thanks to its size & weight.
 vatazhka's gear list:vatazhka's gear list
Samsung NX1000 Samsung NX mini Samsung NX500 Samsung NX 20-50mm F3.5-5.6 ED Samsung NX 50-200mm F4-5.6 OIS +3 more
OP CMurdock Contributing Member • Posts: 819
Vatazhka, thank you for answering all my questions.  I'm very grateful.  Usually when I post questions like this, I get incomplete answers.
The NX1100 was introduced just about 15 months ago.  I wish they wouldn't change models so rapidly.  Who knows if the replacement camera will have as good color reproduction.
vatazhka
NX1100 is actually a re-packaged NX1000, which was released in April 2012. The NX1100 might have been an attempt to sell the remaining NX1000 production in a more attractive package. The real NX1000 follow up was NX2000, which was released in May 2013, just a month after NX1100.
Samsung is known for its scattergun approach in TV and smartphone market. They refresh the lineup each year and spawn multiple variants of the base models throughout the year. It seems that they are trying to follow this model with their camera division as well - we just witnessed the transition from NX2000 to NX3000 this June.
With regard to color reproduction - the Samsung sensor develops through evolution rather than revolution. I'm not sure about the in-camera image processing part, though.
Helen
Helen Veteran Member • Posts: 7,606
As the other responder said, they are technically discontinued - having been replaced by the (initially more expensive) NX2000, which itself is now being replaced by the (cheaper) NX3000.  As the other respondee also said, the NX1000 and NX1100 are effectively the same camera, except that the later NX1100 came bundled with free Lightroom 4, at least in the UK where I am.
They ought to be sharp - most cameras turn out pretty sharp macros (of course, you need to watch the depth of field with larger sensor [than compact digital] cameras like these as it's narrower).  Most Samsung lenses seem optically very good.
I wonder if your Nikon was one of the Nikon 1 series?  They are unusual in that for a lot of the models you can't actually turn the image review feature off (or make it longer if you need it) - you can do both of these things on Samsungs.  However, even with the Nikon 1 cameras, just half-pressing the shutter release button clears the review - as it does on all other brands these days when they are showing an instant review.  So it needn't be a big problem, even if you eventually decide to have it turned on for the instances you might find it useful.
Thank you!
Hope that helps too.
Thank you for the additional information!
The Nikon camera that I returned was the P7700.
Since 2005 I've been using an old Canon A620 (7 MP compact with no RAW output).  I turned the 2-second review feature off on that camera, and that allows me to take rapid-fire shots of my products.  What I'll do is I'll take about 8 shots at 3 different exposure compensation settings, and then I'll choose the best shot later.  After each shot, I see nothing but the view through the lens.  With the Nikon, however, the camera settings (with icons) stayed on the screen for 3-4 seconds after.  The fact that I could remove them by half-pressing the shutter release didn't appease me because I have a heavy finger and tended to take a picture by accident.  Besides, I just didn't want to go through the trouble of the extra press.
The NX1100 can be purchased for as little as $270 right now; and since my business makes me less than $20,000 per year, I need to find a cheap camera.  To get a camera with an APS-C sensor and detachable lens (and good color reproduction) for just $270 is a chance I can't miss.
Thanks for the information you shared.
vatazhka
I checked the behaviour of the display between shots - it's perfectly possible to disable all UI overlays save the bottom bar which display shutter speed, f-stop, ISO value etc. and it is retained between shots (You can quickly cycle between UI settings by pressing cursor up key when needed.). The bottom bar is very small & transparent - it does not obstruct the live view significantly.
Thank you!  However, I'm now concerned about the NX1100 because I think it may have some reliability issues.
I am passing by the NX2000 because it is a touch-screen camera, but the NX3000 is very interesting to me.
ConcertPhotog Regular Member • Posts: 144
Is this true? Does discontinued really mean no support for new lenses and no firmware updates? Is this common for other manufacturers? (Nikon, Canon, Sony?)
It seems odd that a camera body would not support newer lenses of the same system. People seem to routinely use much older Canon and Nikon DSLR bodies. Can anyone confirm this?
 ConcertPhotog's gear list:ConcertPhotog's gear list
Canon EOS 5D Canon EOS 6D Samsung NX1100 Canon EF 50mm F1.4 USM Canon EF 100mm f/2.0 USM +7 more
