Samsung NX1000 Refuses to Take Pictures Sometimes
Started Aug 3, 2014 | Discussions
Crazybubba New Member • Posts: 1
I have a lovely NX1000 which works well 90% of the time. I use it to take pics for my ebay business (vintage clothing). However, sometimes I'll flip a jacket over and the camera will decide to zoom in, zoom out, focus, zoom in, zoom out, focus and refuse to take a picture.
Lighting conditions, and item being photographed are identical to when it is functioning..
Samsung NX1000
CMurdock Contributing Member • Posts: 819
Re: Samsung NX1000 Refuses to Take Pictures Sometimes
I just want to say that I'm sorry that no one replied to you.  Did you try calling technical support?
I just ordered an NX1100 (which is the same as the NX1000).  I hear it is a very buggy camera, but the price was low.
OrdinarilyInordinate
OrdinarilyInordinate Veteran Member • Posts: 3,741
Sounds like it has trouble focusing, hence not taking a photograph.  You can try manually focusing when it has trouble doing so automatically--I am guessing it happens in low light conditions or else low contrast.
 OrdinarilyInordinate's gear list:OrdinarilyInordinate's gear list
Nikon Coolpix A Fujifilm X-T2 Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 23mm F1.4 R Fujifilm XF 56mm F1.2 R +4 more
Ian Leach Senior Member • Posts: 1,475
I take it you have the 20-50mm lens and that will only zoom in and out if you zoom it by hand. So I guess you are talking about it hunting for focus. There will be two main possible causes. First the light maybe to low on an object with little contrast or second there is an issue with your camera. I suggest when you next experience the issue point the camera immediately at something bright and contrasty to check it actually works OK. If you think you have a duff one send it in for service.
I have owned one for some time and it is not buggy at all. I am very happy with it.
nster Regular Member • Posts: 114
I have this issue with many cameras, usually caused by low contrast or not as good lighting and or too close to focus
I usually just switch to MF for the time of shot you take anyways
Toby Newman New Member • Posts: 3
Just to report that I'm getting this issue on my NX1000 now also. It happens equally regardless of which lens is fitted so it's an issue with the body I think.
I've tried running the sensor cleaning, no help.
