300mm f/4 L IS - focus issue?
Started Aug 2, 2014 | Discussions
Earguy Regular Member • Posts: 122
I recently purchased a 300mm prime, and wonder if I have a focus issue. Attached to a 70D body, back-button focus, I've tried center single point an all the other autofocus settings.
If I'm focused on something relatively close (20 feet), and then try to focus on something farther away (say, 60-100 feet), it simply doesn't focus. It might search once, never come close, and stops. The same thing happens going from distant to close. Smaller increments of distance, it's dead on accurate. If I turn the manual-focus ring to bring the object even into the neighborhood of focus, it focuses fine.
Is this normal behavior for this lens, or do I have a problem?
For what it's worth, here's a successful shot with the lens:
 Earguy's gear list:Earguy's gear list
Canon EOS 5D Mark III Canon EOS Rebel SL1 Canon EOS 70D Canon EF 50mm F1.8 II Canon EF 24-70mm f/2.8L USM +1 more
Canon EF 300mm f/4.0L IS USM Canon EOS 70D
R2D2 Forum Pro • Posts: 26,551
Re: 300mm f/4 L IS - focus issue?
Go into the menu and turn "Focus Search" ON. (I usually keep it OFF BTW).
Hope this helps.
R2
ps. nice hummer
olmail Senior Member • Posts: 1,492
no help for you from me . hopefully r2d2's suggestion will help. just want to offer that it's a great lens, you should enjoy it a lot once you get it working properly.
 olmail's gear list:olmail's gear list
Canon EOS 7D Canon EOS 7D Mark II Canon EF 50mm F1.4 USM Canon EF 300mm f/4.0L IS USM Canon EF-S 10-22mm F3.5-4.5 USM +4 more
OP Earguy Regular Member • Posts: 122
I checked my 70D and it was enabled...but that led me to check the tracking sensitivity, which was set all the way to the left, "locked on."  Set it to the middle between that and "responsive."  And now it works!
Thanks nudging me in the right direction.  Hopefully now others will benefit.
Thanks for the update.  Good to see how that works (or doesn't). I'll have to remember that one.
Happy shooting!
R2
