Slim filters necessary for NX12-24mm lens?
Started Aug 2, 2014 | Questions
JJNG New Member • Posts: 8
I'm planning to purchase a 58mm CPL filter for my 12-24mm (&18-55mm kit) lens. Not sure if I should get a slim or standard version. The standard one will be nicer to operate and easier to remove. Therefore I would only get the slim version if absolutely necessary. Anyone here experienced vignetting with a standard /non-slim filter on the 12-24mm?
JJ
 JJNG's gear list:JJNG's gear list
Nikon D90 Samsung NX300 Nikon AF-S DX Nikkor 18-105mm F3.5-5.6G ED VR Nikon AF Nikkor 85mm f/1.8D Samsung NX 30mm F2 Pancake +9 more
Kaziklu Senior Member • Posts: 1,301
Re: Slim filters necessary for NX12-24mm lens?
you'll get a little vignetting either way. I honestly can't say if it is needed, I'd try the slims standard you can find.
 Kaziklu's gear list:Kaziklu's gear list
Samsung NX20 Samsung NX1 Samsung NX 30mm F2 Pancake Samsung NX 18-55mm F3.5-5.6 OIS Samsung NX 50-200mm F4-5.6 OIS +1 more
viking79
viking79 Forum Pro • Posts: 14,157
No, should be able to stack at least 2 standard filters without vignetting.
If you shoot RAW and use a program besides Lightroom (or other program which automatically applies the lens corrections in the RAW file) you might see some light vignetting with 2 stacked normal filters, but 1 should still be fine.
Eric
Sony a7R Samsung NX1 Samsung NX 30mm F2 Pancake Samsung NX 85mm F1.4 ED SSA Samsung NX 60mm F2.8 Macro ED OIS SSA +5 more
