Epoca Libera wrote:
My ideas that may help:
- For the mount you can use a Body Cap (US $1.99 on ebay with Rear Lens Cap included). This cap could be used for turning the NX mini into a pinhole camera also.
http://www.ebay.com/itm/171480520186
Excellent! It would be easy to take dimensions off that. It probably doesn't lock, but close enough. A couple of those and a body would probably be enough to work-out and test the design. However, I still haven't seen an NX mini body cheap enough to just grab one... I will start watching more carefully.
- For the pins you have to make or modify something like the "AF confirm Chips for Canon Eos" they sell on ebay for US $4)
No. Despite the low cost, those are actually processors on shaped little boards. The cost would be a lot more for just a simple shaped board in low quantity unless it could be milled on a hobbyist CNC router (which it probably could be, but I don't have one of those quite yet... I'll probably be getting one within the next month or two).
Now for more pins: If accidentally you connect (short circuit) pin1+pin2+pin11 (clockwise) camera will turn off and this is not a good sign. From my tests only pin2+pin11 work and I discovered this by searching for short-circuity connections on the mount of the nx-mini lens (I used a multimeter on the "audible continuity test" mode).
Sounds like short of power and ground isn't happy. Oh well. It would have been easier to just have a continuous metal strip over all the pin contacts (or any contiguous set of pins), but I still think shaped metal duct tape spanning the appropriate contacts is the right way to go for a simple 3D-printed adapter. I have a 2D programmable paper cutter, so it shouldn't be hard for me to use that to cut a precisely-shaped pattern out of the metal duct tape. The other possibility would be conductive paint, but that is more likely to have wear issues.
