E-PM2 with Panasonic 14mm f2.5
Started Jul 27, 2014 | Discussions
sin77 Junior Member • Posts: 33
My photos seem to have very strong CA or purple fringing each time I shoot again a back-light and can hardly be corrected via post-processing. Is this normal? Is it the E-PM2 that is giving most of the problem or is it the Panasonic lens? I can't use most of the photos and now I am considering switching to Panasonic body or Sigma 19mm f2.8 lens.
Olympus PEN E-PM2
GingerBread Regular Member • Posts: 384
Re: E-PM2 with Panasonic 14mm f2.5
This topic has been covered in detail in past threads, so a search in the forum might help explain it in more detail.  It is common with Panny lenses on Oly bodies, and can be significantly reduced (from what I recall of those threads) by a particular filter.
Ging
 GingerBread's gear list:GingerBread's gear list
Sony RX100 Panasonic Lumix DMC-LX7 Nikon D700 Sony Alpha NEX-7 Panasonic Lumix DMC-GX1 +3 more
baxters Veteran Member • Posts: 5,319
The Panasonic 14mm is especially prone to purple fringing of back lit edges in the corners. I've been able to use the fringe tool in Lightroom4 to remove it. It's not confined to the EPM2. I see it in the EPL1 and EM5. I don't believe it's the kind of fringing that is removed by the Panasonic bodies as I can turn on CA removal in LR4 (I am told this is essentially the same algorithm as Panasonic in-camera) and nothing happens.
If it bugs you, I agree this is not a good lens for you, but to me the specific lighting conditions which cause big time fringing on my 14mm also cause it on other lenses to different degrees.
 baxters's gear list:baxters's gear list
Olympus OM-D E-M5 Panasonic Lumix DMC-GX85 Olympus M.Zuiko Digital ED 75mm F1.8 Olympus M.Zuiko Digital 17mm F1.8
Jeff4500
Jeff4500 Senior Member • Posts: 1,921
LR does some removal but you must use the manual tools to get it all. Really no big deal to have such a small, good lens. And I've found on my EP5 this only happens in very bright back lighted images.
 Jeff4500's gear list:Jeff4500's gear list
Panasonic 12-35mm F2.8 Panasonic Lumix DMC-GX85 Panasonic Lumix DC-G9 Panasonic Lumix DC-GH6 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 +9 more
alfredo_tomato
alfredo_tomato Veteran Member • Posts: 4,382
Any banding issues?
 alfredo_tomato's gear list:alfredo_tomato's gear list
Olympus PEN E-PL1s Olympus PEN E-PM2 Olympus OM-D E-M10 Panasonic Lumix G 20mm F1.7 ASPH Olympus Zuiko Digital ED 40-150mm 1:4.0-5.6 +13 more
Jeff4500
Not in my use of the lens. Nothing beats having it on the EP5 sans finder in a pocket.
(unknown member) Regular Member • Posts: 221
Dxo Optics Pro is very good at correcting this automatically as they have lens/body specific profiles.
secretworld Senior Member • Posts: 1,734
Yes using a wratten 2A filter fixes this, it did here with my 20mm on a PM2. Really night and day....
 secretworld's gear list:secretworld's gear list
Panasonic Lumix DMC-GH3 Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GM1 Panasonic Lumix DMC-GM5 Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS +7 more
Hen3ry
Hen3ry Forum Pro • Posts: 18,218
Sin, try a UV or 81A filter.
That has been shown to drastically reduce/totally remove the CA fringing.
Cheers, geoff
Geoffrey Heard
Down and out in Rabaul in the South Pacific
http://pngtimetraveller.blogspot.com/2011/10/return-to-karai-komana_31.html
 Hen3ry's gear list:Hen3ry's gear list
Panasonic Lumix DMC-GX7 Panasonic G85 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Olympus M.Zuiko Digital 45mm F1.8 Panasonic Lumix G X Vario PZ 45-175mm F4.0-5.6 ASPH OIS +7 more
alfredo_tomato
I am in the process of deciding how to spend my money. I already have the Sigm 19 and 30mm. Not sure what other FL I need. The 14 would get me a wider FOV, but so would the Panny 14~45.
Maybe I will just buy a new iPad. Whatever.
I am thinking of replacing it with the equally compact 12-32mm f3.5-5.6 zoom for the same pocketability purpose.  What do you reckon?
alcelc
alcelc Forum Pro • Posts: 19,005
+1, it works like a miracle.
alfredo_tomato
Re: Sin, try a UV or 81A filter.
Thanks for telling me that.
Is there any problem with banding with the 14 on an Oly body?
C Sean Veteran Member • Posts: 3,423
I don't own any Olympus bodies so it difficult for me to recommend this lens without knowing any protential side effects. However the Panasonic 12-32 has better IQ than the 14mm 2.5 at 14mm and it so good it give the 15mm 1.7 some run for it money aswell.
