Olympus 25mm problem... or Operator problem?
Started Jul 26, 2014 | Discussions
BHPhotog Contributing Member • Posts: 812
These two shots were taken in the same way, same time, etc. with my new Olympus f/1.8, tripod mounted, IS off, 2 second delay, auto WB. Matrix metering, one is AF and the other is manual focus on exactly the same spot.
I'm used to the 'kit' 12-50 with a widest f/3.5 aperture, so this kind of narrow DOF is new to me and I don't know what's going on. Is the aperture causing the camera to AF somewhere else than what it shows in the VF? Do I have to always use manual focus at this wide an aperture?
Any and all comments appreciate...
 BHPhotog's gear list:BHPhotog's gear list
Olympus OM-D E-M5 Olympus M.Zuiko Digital ED 40-150mm 1:4-5.6 R Olympus M.Zuiko Digital ED 12-50mm 1:3.5-6.3 EZ Epson Stylus Photo R1900
lambert4
lambert4 Senior Member • Posts: 2,313
Re: Olympus 25mm problem... or Operator problem?
It just appears to me that the AF chose slightly behind the subject, for some reason.  Probably not an issue just verify focus is on what you wish.
Here's to learning something new everyday, and remembering it the next.
 lambert4's gear list:lambert4's gear list
Nikon D500 Sigma 10-20mm F3.5 EX DC HSM Nikon AF-S Nikkor 70-200mm F4G ED VR Tamron SP 150-600mm F/5-6.3 Di VC USD Nikon 35mm F1.8G ED +3 more
OP BHPhotog Contributing Member • Posts: 812
Re: OP response
I agree, and that's what concerns me. I'm not always going to want to double check focus manually.
hindesite Veteran Member • Posts: 4,036
Yeah, but what AF scheme were you using? You haven't said, and that is probably the most important information.
(BTW, looks painful
(unknown member) Veteran Member • Posts: 3,010
Re: OP response
Is this a common occurrence with this lens? I like to suggest you repeat it numerous times say 10 and then see what happens. I would focus the camera some where else each time and then refocus on the test subject.
Guy Parsons
Guy Parsons Forum Pro • Posts: 30,787
Which AF box?
Are you using the smallest AF box (via latest firmware), or using the smallest Magnify AF box?
If a larger AF box the camera often sees better contrast behind where you intended so focuses there instead.
Regards.... Guy
Olympus PEN E-P5 Sony RX100 VI Olympus PEN E-PL1 Olympus PEN E-P3 Olympus PEN E-PL5 +2 more
Skeeterbytes Forum Pro • Posts: 14,686
(BTW, looks painful
Yup, if you want concise focus, select small, single-dot SAF and double-check your release priority setting. This should be a piece of cake.
Rick
p.s. The 25 is a great little lens.
"Whiskey is for drinking, digicams are for fighting over."
—Mark Twain
SkiHound Veteran Member • Posts: 3,406
Don't know what your focal point was. I pretty much always use a small single point. You certainly need to be much more careful with a fast lens and large aperture. I can set my 17mm lens at somewhere around 10' and f/10 and get almost everything in reasonable focus. A 25mm at f/1.8 just doesn't have much depth of field. Don't know if this is user error or not since I don't know the focus point, but shooting at f/1.8 you need to be pretty precise.
OP response #2
The focus point is marked on the image...
OP response #3
Rick
I agree about that, but it kinda defeats the purpose of using the 25 as a general walk-around lens with matrix metering. For setup shots, the smallest single point and manual focus works with the large apertures, but if I have to go up to f/4 or f/5.6 to use it for an all purpose lens I can get 95% of the same IQ from the 12-50 @ 25mm and f/5.6 with a lot more flexibility.
OP response #4
Regards.... Guy
Yep. I have the AF box at the smallest and same with the magnify.See response #3 for some further thoughts...
Re: OP response #3
I use center-diamond AF pattern for general walking around but switch to single-dot when I want concise focus. Don't think I've tried this lens with CAF+Tr so can't comment on its abilities there. With such a fast lens, very high shutter speeds are accessible for action shots, which is a good thing.
E-M1 25/1.8
Rick
—Mark Twain
jack Hoggard
jack Hoggard Contributing Member • Posts: 825
Which is which?
jaxupra
 jack Hoggard's gear list:jack Hoggard's gear list
Olympus Stylus 1 Sony Xperia Z Ultra Google Nexus 7 +1 more
jack Hoggard
You said one is autofocus and one is manual.  The first (left) image is fine, which I assume to be AF, and the second (right) is not - manual?
jaxupra
OP response #5
Nope, the other way around. The AF is on the right, and it has focused on the background to the left of the mannequin; the MF (focus acquired using the lens focus ring override, but the camera is still in AF) for is on the left and that is focused on the mannequin (box area). That's the issue, the AF is picking something off-center to focus on.
Guy Parsons
Re: OP response #5
Earlier on in the forum there were some suspicions that the AF leaks outside the indicated focus box. Maybe it's something for me to test one rainy day when there's nothing else to do.
When things look tricky I often use the 2x DTC (assigned to Red button in my case) to give a quick check of the AF, then recover the full image from the RAW.
Regards..... Guy
Re: OP response #6
I'm sorry, but I don't understand what this means:
What is "DTC" and what has RAW to do with the focus point?
Guy Parsons
Re: OP response #6
Using a 2x DTC magnified view it is easier to see if the AF (or MF) worked properly.
Shooting Menu 1 - Digital Tele-Converter - On/Off, in my case assigned to the Red button.
If taking the shot with 2x on then the middle 4MP is interpolated up to 16MP to make the jpeg, meanwhile the RAW file is the full 4:3 original 16MP frame.
Regards..... Guy
Optical1
Optical1 Senior Member • Posts: 1,096
3 Questions:
1) Were you close to the minimum focus distance for this lens (~10in)?  In some cases, when the focus cannot rack past the focus point, the camera will give up and not focus properly.
2) Can you expand on your procedure with the AF shot?  I'm struggling to think of why you would proceed with taking the picture if you didn't attain focus.  Did you fully press the shutter button to take your shot without half-pressing to attain focus?  If so, the camera will simply wait the two seconds (from your delay) and then expose.
3) Do you have "release priority" enabled?
 Optical1's gear list:Optical1's gear list
Canon PowerShot S95 Sony RX100 Ricoh GR Olympus PEN E-PM1 Olympus OM-D E-M5 +18 more
Bob Tullis
Bob Tullis Forum Pro • Posts: 36,579
In addition to some advice already offered, the contrast here is stronger on the b/g than on the subject, and unless you insure the AF area is solely on the subject you may well expect this result.   Not understanding this would fall under operator error.  While AF is good in general, there are times one needs to take command (or give up and blame the gear).
...Bob, NYC
http://www.bobtullis.com
http://www.flickr.com/photos/bobtullis/
"Well, sometimes the magic works. . . Sometimes, it doesn't." - Chief Dan George, Little Big Man
 Bob Tullis's gear list:Bob Tullis's gear list
Fujifilm X-Pro2 Fujifilm X-H1 Fujifilm X100F Fujifilm X-T2
