Maximum Video Recording Length on NX300 and NX30?
Started Jul 24, 2014 | Discussions
Philip Scott
Philip Scott Senior Member • Posts: 1,179
Anyone know what the maximum video recording time is (assuming external USB power and sufficient SD card space) for the NX300 and for the NX30? Let's say with them set to best quality video.
Thanks!
 Philip Scott's gear list:Philip Scott's gear list
Olympus PEN-F Olympus 40-150mm F2.8 Pro Olympus 7-14mm F2.8 Pro Olympus 8mm F1.8 Fisheye Pro Olympus M.Zuiko 300mm F4 IS Pro +26 more
Samsung NX30 Samsung NX300M
xorgh Forum Member • Posts: 84
Re: Maximum Video Recording Length on NX300 and NX30?
If you bought the cam in europe:
29 minutes 59 seconds
(because of dumb import tax laws)
 xorgh's gear list:xorgh's gear list
Samsung NX1 Samsung NX 50-200mm F4-5.6 OIS Samsung NX 45mm F1.8 Samsung 16-50mm F2.0-2.8
Philip Scott
OP Philip Scott Senior Member • Posts: 1,179
nster Regular Member • Posts: 114
it's either 25 or 30 minutes I forget
YCemAygun
YCemAygun Regular Member • Posts: 186
Well this is also playing to manufacturers hands. Honestly most manufacturers are happy with it because they use this as an excuse to prevent cannibalizing their more expensive "camcorders". I know there is the sensor overheat concern but almost all the modern cameras can start a new recording right after the previous one is finished, so it cannot be as severe as claimed.
The question is why don't they implement SSC (stop, save, continue) into their cameras if it was only for the tax laws, since a $70 action camera can easily do this. (Actually Mobius even has a 2 sec overlap in between the multiple sequential recordings for easy sync at post production). The answer is: "Because they don't want to"
SSC has been around for quite some time, but it was primarily used when the 4GB file limit was hit, to be able to continue recording seamlessly.
I honestly don't know whether implementation of ssc would still put a camera into the "camcorder" zone (the extra tax zone), or it would help to avoid the zone, as any single file recorded does not exceed 30 minutes; but in the end where there is a will, there is a way.
And apparently there is no will...
gameguru1360
gameguru1360 Regular Member • Posts: 448
30 minutes
 gameguru1360's gear list:gameguru1360's gear list
Canon EOS RP Panasonic FZ1000 Canon EOS Rebel SL1 Olympus E-M5 II Olympus OM-D E-M10 II +2 more
The problem with starting another recording immediately after 29 minutes 59 seconds is that you lose some time untill the recording begins again. In some situations it is surely a no go (e.g. weddings: Oh sorry, your "Yes" isn't on record...).
It's the first time I hear about SSC. With a 2 sec overlap it would really remove the need for a camcorder.
well obviously you be careful with the time and be strategic
YCemAygun
Well that is the point Mobius (the $70 Chinese action camera) can do it, as long as you set a clip length that would generate a file less than 4 gigs. I generally use 15 minutes per clip restriction, and I can record for hours without loosing a single second.
If I don't use clip duration restriction, Mobius still saves and continues after reaching 4 gigs (whenever that may be, depending on the quality settings and scene), but I loose roughly about 5 seconds between clips. At least it keeps recording...
I just resent the idea that some things are crippled on purpose, not for technical reasons, just to make sure they can squeeze more money out of people.
I generally despise the video quality on NX2000 anyways. With the lens and sensor involved, it should at least be able to surpass cameras that cost one tenth of it's initial price.  Unfortunately it cannot. I would be shocked if this was a hardware issue though.
For one thing, as far as I can tell, during video recording NX2000 does some sort of sub-sampling on the sensor readings instead of down-sampling, and inevitably you get the excessive moving noise. Anything properly down-sampled to 2MP from that sensor would look smooth as silk (actually it would need on the fly sharpening, which every other camera also does). On top of that,  I am sure the processor is capable of running circles around this simple task, yet again, "if they wanted to"...
And little things like not being able to use single auto focus, or having the convenience of locking the focus during video recording (unless you use full manual focus); not being able to change the shutter speed beyond 1/30th of a second even when you are shooting at 20x time lapse mode, are simply inexplicable.
Anyway it is what it is. For it's current price NX2000 is still a blessing. It is just sad seeing all this potential go to waste.
Sorry for bothering you guys with my frustrations...
Marcos Caballero New Member • Posts: 1
has someone cracked the code on the NX30 yet? I have seen a custom mod for the NX300 out there
http://op-co.de/blog/posts/modding_the_nx300/
Would LOVE to run code on the thing and sync recording on several NX cameras on wifi and pipe remote video to a computer (like a mixer preview)
khattemoat New Member • Posts: 11
I can honestly say that I haven't read the whole thread, and the NX300/NX30 are probably becoming less relevant these days. But still very good!
Anyway, I stumbled upon this video about a hidden developer menu, initially intended for fixing the "no lens" error when using vintage lenses, but it also has a nice set of features, apparently including a removal of the video recording limit.
https://www.youtube.com/watch?v=ktpGF1yELlg
I haven't had the time to look into it myself, but it might be worth checking out. That is, if you haven't seen it already. Which you probably have. Maybe.
 khattemoat's gear list:khattemoat's gear list
Samsung NX500
Artur - Brasil New Member • Posts: 9
You can override this recording time accessing the service menu.
Both cameras allow you do this. my NX30 gets a bit hot when recording for more than 40min.
