Olympus E-PM2: Small Camera, Big Surprise
Started Jul 23, 2014 | Discussions
(unknown member) Forum Pro • Posts: 15,724
Overall the camera shocked me in a good way. Its fun and enjoyable to use. Glad to knock the dust off my m4/3 lenses and have a body worthy of using them on. I put much more in writing on the camera here:
http://www.photographic-central.blogspot.com/
Carl
http://www.photographic-central.blogspot.com (Gear reviews)
http://www.carlgarrard.blogspot.com/ (Best work compilation)
Also formerly AlphaMountWorld.com (Now off the web)
Olympus PEN E-PM2
Guy Parsons
Guy Parsons Forum Pro • Posts: 40,000
Re: Olympus E-PM2: Small Camera, Big Surprise
5
Carl
Interesting read, thank you for that.
My comments will concern some of the end remarks. Your list.....
A few recommendations for improvement on its successors, etc. :
  • Use the standard USB and HDMI ports instead, get over yourselves Olympus
    The odd USB port is needed to enable the usual connections plus the Oly ability to control the camera from the port, we are stuck with it. The HDMI is a standard size, it is the so called Type D Micro HDMI and suitable cables are available everywhere.
  • Never omit a 100 ISO setting again, for the successor to the E-PM2 or any camera you make
    When desperate we can fake that with over-exposing at 200 and then hoping the highlights have not suffered too much, just the same as the "100" does in the later cameras.
  • When you state an ISO value, make _sure_ it's the value you state
    The ISO test results seem to vary with the testing procedure, just go take photos and watch the blinkies and it is all sorted out.
  • Noise reduction, off should mean OFF, not low
    Noise filter off may or may not interfere (I've never checked), but no worries as I use the RAW anyway. Meanwhile the Sharpening at -2 definitely sharpens a bit and that adds noise and edge halos, again avoided by using the RAWs.
  • Get rid of the banding
    Never troubled me. Usually super high ISO is a total compromise anyway, so banding is an insignificant issue for me.
  • Abandon the 16:9 aspect LCD screen when you have a 4:3 native aspect ratio/sensor
    Then the camera would get clunky in size, I use the 16:9 screen of my E-PL5 by shooting 16:9 to make the details as large as possible, and recover the 4:3 from the RAWs.
  • Always put the tripod mount inline with the center of the lens
    Agree, but the camera will get taller again, and ruin the small size.
  • Organize the Menu system better, just don't remove anything
    It is weird but workable. I'm used to it now.
  • Include an HDR function that stacks several images into one file, automatically
    Usually enough HDR effect can be recovered from a single RAW so for me not a worry.
  • Include a panorama function that auto stitches into one big file (or even in camera after shots are made)
    That would be nice if it could combine images as nicely as Microsoft ICE or Hugin etc. and be at full resolution.
Regards..... Guy
perry rhodan
perry rhodan Senior Member • Posts: 1,964
banding with pana pancake
Thank you! A very nice write up from a personal point of view. Gives a good impression of the fine tools that are around for not much money at all.
Did you percieve the banding with the pana pancake only? If so, this was acknowledged in 2012 on the EM-5. And not corrected untill now.
http://www.dpreview.com/articles/4199580748/olympus-acknowledges-om-d-e-m5-banding-with-panasonic-20mm-f1-7-lens
Regards Perry
OP (unknown member) Forum Pro • Posts: 15,724
Welcome!
amalric
amalric Forum Pro • Posts: 10,839
Carl
Very rational review. E-PM2, which I bought a month ago was never much reviewed, but I find it delightful.
I don't agree with the ISO thing, because it's brand specific anyway. Where Olympus has ISO 100, it has poor DR. Also I just listened to the click, and it's very soft, v. good for stealth.
Would have liked some notes on the pair PM2 & 17/2.8, since you use them.
Carl
So do I
Ok we dont agree.
Maybe I'll add some. Offhand they make a good pair and the 17 although not the sharpest lens for m4/3 is very decent. It's a bit slow to focus compared to other lenses, but its affordable, nice and relatively bright.
Carl
amalric
cgarrard wrote:
Carl
So do I
Ok we dont agree.
Carl
Carl, about ISO, There have been v. long threads on the difference between Olympus ISO scale and the DxO one, until a very analytic mind redefined the thing in terms of Brightness only (amplification), in an article at DPR. You might check both, because it's a core concept in Digital.
Another feature you might find interesting is the digital 2X zoom: contrary to others it is a high quaity one, with pixel binning to give the full 16 Mpx while cropping.
There is also Auto gradation, a relighting feature, which helps with High Contrast days, and a Tone control one.  B&W filters (I use the orange one) give v. impressive B&W.
I mwntion this because Olympus grows these festures across all the models, and one might miss them, when looking at one one camera only.
Basically it's like having a small dragster in your pocket.
'Photo & Poetry'
http://amalric2014.blogspot.it/
http://www.flickr.com/photos/amalric
Bhima78 Senior Member • Posts: 2,850
Its a good little camera to be sure as I have one that I use as the smaller camera at work. I think a used Panny G5 is likely a better option though since it can be had for a pretty good price and actually has an EVF. Also, I don't find the IBIS on the E-PM2 to be of much use compared to say, the 3-axis em-10 or the 5-axis em-5/em-1.
 Bhima78's gear list:Bhima78's gear list
Panasonic Lumix DMC-GX8 Panasonic Lumix DMC-GX85 Panasonic G85 Panasonic Lumix G Vario 7-14mm F4 ASPH Panasonic Lumix G X Vario 35-100mm F2.8 OIS +12 more
knickerhawk Veteran Member • Posts: 7,615
I'd LOVE to see your source for this creative explanation of Oly's digital zoom function.
Anders W
Anders W Forum Pro • Posts: 22,144
Panasonic Lumix DMC-G1 Olympus PEN-F Olympus E-M1 II Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS Panasonic Lumix G Vario 7-14mm F4 ASPH +20 more
amalric
Here it is, from the horse's mouth:
When assigned to the Fn1 button, the digital tele-converter function produces a telephoto effect which magnifies the center part of the image by two times. The excellent pixel interpolation performance of the TruePic VI image processor makes it possible to zoom while maintaining high image quality. Using this function allows a 75 - 300 mm super-telephoto lens to provide a zooming range equivalent to 1200 mm on 35 mm camera lenses, making it easy to achieve high magnification.
http://www.olympus-imaging.co.in/products/dslr/em5/feature/05/
You do realize, I hope, that "pixel interpolation" is not at all the same as "pixel binning" and that "magnif[ying] the center part of the image by two times" means that you are not using the "full 16Mpx while cropping" as you claimed above.  Sorry to burst your bubble, but there's no magic going on that allows Olympus to avoid cropping (throwing away) a large amount of the image when it does its digital zoom.
Anders W wrote:
Based on amalric's reply, it appears he either didn't see your smiley face response or didn't realize that it really meant "DANGER - YOU'RE ON THIN ICE!"
amalric
As always you are putting words in my mouth, little man.
And as always, you're bungling basic concepts.  Let's start with YOUR words from YOUR "mouth."  How is Oly utilizing "pixel binning" in its digital zoom function?  Once we clarify that, we can move on to the next part about how Oly is "giv[ing] the full 16Mpx while cropping."
veroman Veteran Member • Posts: 4,904
Hi Carl. First, good to see you finally had a buyer for your LC1.  I was following that auction in complete disbelief that it took so long to sell it.  Almost changed my mind and bought it myself!  Amazing that it had to be sold for so little.
But I didn't buy it 'cause I, too, have an E-PM2 and find it to be quite a remarkable little camera, quirks and all. Purchased mine about 3 months ago.  It led me to purchasing an E-P5.  I use both cameras almost daily.  I haven't touched my larger DSLRs since owning them.
I enjoyed your review very much.  I wish other reviewers had paid more attention to the E-PM2, for it's quite an amazing little package.  Indeed, I think it's quite a bit better than "good," especially when paired with an EVF and first-rate lenses.  I've compared it to some of my older full frame Canons, like the 1Ds, and find it quite similar in IQ, but without some of the FF advantages.
So ... thanks again for the review.  I look forward to more of the same.
SteveG
'When love and skill work together, expect a masterpiece.'
— Found in a Chinese Fortune Cookie
www.stephenmichaelgarey.com
 veroman's gear list:veroman's gear list
Leica X Vario Ricoh GR II Panasonic Lumix DMC-GF1 Pentax K-01 Pentax K-5 II +2 more
alfredo_tomato
alfredo_tomato Veteran Member • Posts: 4,382
How much advantage can one gain going from the VF-3 to the VF-4 on my EPM2?  I shoot a lot with manual lenses.
 alfredo_tomato's gear list:alfredo_tomato's gear list
Olympus PEN E-PL1s Olympus PEN E-PM2 Olympus OM-D E-M10 Panasonic Lumix G 20mm F1.7 ASPH Olympus Zuiko Digital ED 40-150mm 1:4.0-5.6 +13 more
I recently read a review comparing the two. Can't remember where I saw it or else I'd send you the link. The reviewer thought the VF-4 was significantly better. He thought that color and finer details were far better with the VF-4.
I once viewed the VF-3 on my old EP-2 and thought it nowhere near as good as my VF-2. The VF-2 and VF-4 are very close, with the VF-4 edging out the VF-2 in the finer details. Still, I saw little reason to upgrade to the VF-4. The VF-2 serves my purpose.
Perhaps others in this forum can give you a more detailed answer!
SteveG
sderdiarian Veteran Member • Posts: 4,248
I respectfully disagree, here, Guy.  The GM1 manages a 3:2 aspect ratio and a built-in flash in a much smaller body:
http://j.mp/1tGnXKi
I had an E-PM1 (same silly video-oriented 16:9 aspect ratio) and the resultant small usable screen area (2.3"!) when used in native 4:3's was a key reason I sold it.
I'd buy a GM1 were it not for Panasonic leaving out a hot shoe for an EVF.  One can only scratch one's head over these decisions.
Sailin' Steve
 sderdiarian's gear list:sderdiarian's gear list
Panasonic Lumix DMC-GM1 Olympus OM-D E-M10 II Panasonic Lumix G 20mm F1.7 ASPH Olympus M.Zuiko Digital ED 60mm F2.8 Macro Olympus M.Zuiko ED 75-300mm 1:4.8-6.7 II +1 more
Thanks Steve, yah that surprised me too! Took very long indeed!
Glad you enjoyed the review and I've enjoyed your comments!
