Help! My brand new Canon Powershot a1400 no longer focus :(
Started Jul 20, 2014 | Questions
dpstudy New Member • Posts: 3
Hello,
I just baught this great cheap cmaera, and made great photos with it over the last month.
Now I tried to cover the glowing metal cricle around the lens.
I did so using cyanoacrylate adhesive (very powerful super glue) by cutting a dark plastic cover that only fit the metal strip around.
I did so with very attention to not get neither the glow, nor the plastic cover to touch the lens movable body parts
Now the camera can be used to catch photos in crowd, while people will not notice it because the light-reflexing metal strip is covered (the reason why I did that). Great.
But:
Camera is no longer giving me the "green box" in the middle of the screen as usual, in all focus ranges, in all light conditions, in all ISOs!
.. that for the semi-manual P (Program) option, which I always use to control ISO.
Only when I use "Auto" - wich also uses a hight ISO all the time - it can get the focus green box.
HD video seems working OK too.
Semi-Manual settings using "P" option no longer gives me "green".. but blue, no-focus indicator.
Did I cover AF sensor or something I don't know about???
Please help me!
What did I do wong, and how can I get it back to normal!!?
Thank you so much!
Canon PowerShot A1400
Dale Buhanan Veteran Member • Posts: 4,280
Re: Help! My brand new Canon Powershot a1400 no longer focus :(
dpstudy wrote:
Hello,
But:
Please help me!
Thank you so much!
Blue is usually a sign that the tracking AF has been enabled. Put the camera in P mode first. Try checking in the menu to see if tracking AF has been turned to on, (Or servo AF). Next in the menu set your focus mode to single point. That should give you a single green box when focus is locked on. If that no longer works... Then try a full reset of all functions to factory default. That should get you back to the way it was when you bought it. Hope that helps.
kind regards
Dale
Moderator Canon Powershot and 7D/XXD forums
 Dale Buhanan's gear list:Dale Buhanan's gear list
Canon PowerShot SX50 HS Canon G1 X II Canon EOS 70D Canon PowerShot SD500 Canon PowerShot G5 +35 more
OP dpstudy New Member • Posts: 3
Dale!
Thank you so much.
Wow! I heavenly could get it back to its Awesome state. I tried Tools-> Reset All. and it's back to normal! Really happy I could get it back, with my black strip still on
dpstudy wrote:
Dale!
Thank you so much.
I am so glad that helped!   Have a super day.
kind regards
Dale
