Does D810 set minimum shutter speed for non-CPU lenses?
Started Jul 19, 2014 | Questions
digitalphotographer Contributing Member • Posts: 689
One of the annoyances of my previous D800E was that it defaults shutter speed to 1/30 instead of raising ISO in A mode even if I have set the minimum shutter speed to "fast or faster" when a non-CPU lens was used. For a camera that requires high shutter speeds to get pixel perfect shots, going M was the only way to set the desired shutter speed that's either 1/FL or 1/2xFL.
My Df on the other hand, respects minimum shutter speed settings regardless of what lenses I use, as long as "non-CPU lens feature" is activated.
Has Nikon fixed this in D810? I can't find this mentioned anywhere.
 digitalphotographer's gear list:digitalphotographer's gear list
Sony RX1R II Nikon Z7 Sony a7R IV
Nikon D810
OP digitalphotographer Contributing Member • Posts: 689
Re: Does D810 set minimum shutter speed for non-CPU lenses?
Sorry for digging tihs up, I have a few AIS lenses that I am wondering if they would be compatible with the new D810.
Maybe enough time has passed after release date existing owners would know the answers to this? Thanks in advance.
Adriel Victus Regular Member • Posts: 127
I have the D810 and I can confirm that auto iso shutter speed can work with non-CPU lens as long as you enter it correctly in the non-CPU lens menu (focal length and aperture). I use the D810 with my old 28mm f2.8 AIS, my 50mm f1.2 AIS, and I can set the auto iso shutter speed to 1/F or 1/2F if I want, the camera will read the focal length data from the "non-CPU lens" menu and automatically choose minimum shutter speed for me.
 Adriel Victus's gear list:Adriel Victus's gear list
Canon EOS R Canon EF 50mm f/1.2L USM Canon EF 135mm F2L USM Canon EF 16-35mm F4L IS USM Canon RF 35mm F1.8 IS STM Macro
inasir1971
inasir1971 Veteran Member • Posts: 4,105
Yes, the D810 works just like the Df and the FL set in the selected Non-CPU Lens Data is used for minimum shutter speed.
I think this is the new (improved and sensible IMO) Nikon Auto-ISO behavior after the Df.
 inasir1971's gear list:inasir1971's gear list
Nikon Z6 Sony a6400 Sony a7C Sony a7 IV Nikon AF-S Nikkor 24mm f/1.4G ED +17 more
