Are your 16-35 VR corners unusable?
Started Jul 17, 2014 | Discussions
Paul Liukas
Paul Liukas Regular Member • Posts: 362
Hi friends,
I have Nikon 16-35 f4 VR and 18-35G, want to love 16-35 for VR and build quality, as I like to shoot without tripod when traveling. Use it on d800.
If I focus to second half of frame or infinity even f8-f10 corners are unusably even resized to 2000px. Is there 1) lens issue and I need to send for calibration 2) some secrets with focus points on UWA?
When focus on half of frame, or 1/3 first half of frame, corners are acceptable.
The same focus points with 24-70 or 18-35 has good corners, acceptable. Comparing with 16-35 they are perfect.
Any ideas about this lens? Thanks for help.
focused on middle house
I still don't believe that my new 70-200 f4 beats Zeiss 100 f2 and Nikon 85 f1.8. But this is true!
http://500px.com/pauliukas
http://photo.foodphotography.lt
turbsy
turbsy Contributing Member • Posts: 909
Re: Are your 16-35 VR corners unusable?
I had the same issue with the copy I tested. I didn't find that the lens warranted it's price. The corners were really not good and it's just too big for an f4 lens in my opinion.
I have seen great things from this lens though so I guess it's down to sample variation.
 turbsy's gear list:turbsy's gear list
Olympus XZ-1 Nikon D50 Nikon D300 Nikon D800 Nikon AF-S Nikkor 300mm f/4D ED-IF +11 more
simonkit1 Regular Member • Posts: 284
Try another copy or get it checked... I think it's a great lens, have some excellent shots from it
Simon
MoreorLess Veteran Member • Posts: 5,442
I was actually doing some garden shots with this yesterday pretty similar to your example in terms of focusing distance although at 16mm and F/8 rather than 18mm.
There is definitely some corner softness at 100% but less so than your example and further into the corners.
sd40 Senior Member • Posts: 1,555
I have been looking for corner softness with my copy and do not generally find it. Supposedly the acid test is at 16mm, where some owners say it's soft. Here's one at 16mm and f/8.
My first copy of this lens was defective so I agree with those who suggest that there may be some sample variation.
 sd40's gear list:sd40's gear list
Nikon D750 Nikon AF-S Nikkor 24-70mm f/2.8G ED Nikon AF Fisheye-Nikkor 16mm f/2.8D Nikon AF Nikkor 105mm f/2D DC Nikon AF-S Nikkor 85mm F1.4G +8 more
thelenspainter Senior Member • Posts: 1,906
Paul Liukas wrote:
Hi friends,
Focusing far away is the wrong strategy for a UWA lens unless everything in the scene is at infinity.
This is the correct strategy.
The 16-35 has strong field curvature at the corners, at the wide end of the zoom range. The field curves sharply away from the camera. This means if you want the corners sharp when nearby objects are visible there, you need to use hyperfocal distance to focus as close as possible while keeping distant objects sharp.
Further, I would question the application of the term 'usable' to the extreme corners of the image area. It is very rare that a composition works best with important elements positioned so far in the corners. So in reality, a bit of corner softness matters very little. As described above you can minimize it using correct focusing technique.
 thelenspainter's gear list:thelenspainter's gear list
Leica TL2 Nikon Z7 Nikon AF-S Nikkor 70-200mm F4G ED VR Leica Summilux-TL 35mm F1.4 ASPH Leica TL 18mm F2.8 +4 more
Dan_168 Forum Pro • Posts: 11,431
I have the same lens and found my copy has horrible edge too when compare to my 14-24G and Samyang14, but I think that has more to do with the field curvature than anything else, so now when I use this lens I pay special attention to the edge and make sure I adjust my focusing a bit to make sure the edge appears to be sharper, I am shooting my landscape picture on tripod and using LV manual focus 99% of the time, so that's a easy to do, I found I got much better edge performance this way.
Leonard Shepherd Forum Pro • Posts: 25,716
Re: Why focus on infinity?
5
Why focus on infinity when there is close detail as in your picture?
At infinity focus your lens instruction book says depth of field is from 7 feet to infinity at f4, 10 feet to infinity at 20 mm,  14 feet to infinity at 24 mm, 19 feet to infinity at 28 mm and 29 feet to infinity at 35 mm.
This assumes viewing a 10 inch wide print at 12-15 inches. If viewing at 100% on a monitor you may get no more than 35 mm dof at 20 mm
You should get more usable results focussing closer than infinity.
Leonard Shepherd
Producing good quality photographs, or being good at sport or art, involves a little more than buying appropriate equipment. Practice, some learning and perhaps natural talent often play a bigger role than the equipment in your hands.
Nikon Z9 Nikon Z8 Nikon AF-S Micro-Nikkor 60mm F2.8G ED Nikon AF Micro-Nikkor 200mm f/4D ED-IF Nikon AF-S Teleconverter TC-17E II +18 more
JOrmsby Regular Member • Posts: 420
As one who owns the 18-35G and has tested it against the 16-35 VR, I'd say soft corners are not that unusual on the 16-35. I know some are very happy with it, but I have to admit as a Nikon shooter, I'm really jealous of Canon's new 16-35 f/4, which has gotten great reviews, especially for the corners. As a mostly wide-angle shooter, I really think Nikon missed an opportunity with their 16-35. It's pretty mediocre for the price. The newer 18-35G is better but still not on the level of Canon's new wide angle.
 JOrmsby's gear list:JOrmsby's gear list
Olympus E-M5 III Nikon Z6 II Sony a6700 Sigma 56mm F1.4 DC DN | C Nikon Z 85mm F1.8 +3 more
Yes, the new Canon lens looks very impressive, almost enough to make a wide-angle lover consider buying a Canon body...
Paul Liukas
OP Paul Liukas Regular Member • Posts: 362
Thanks everyone for posts and advices.
I tried several images to take with different focus points and found that when focusing to 1st third of the frame in most cases corners are pretty usable and after processing they are good.
The main thing we all use 16-35 I think is VR. I cannot take photos in the morning or early evening at f8-f11 @ 1/5 sec. when walking around without tripod. Photo with softer corners or noting at all
It seems that lenses can be usably with extreme accuracy on focus point. If we had a new Canon 16-35 IS
Here are some shots with focus to 1/3rd taken 2 days ago. I think pretty usable. Thinking to leave this lens in my bag and sell 18-35. VR + build quality the main reasons.
Paul Liukas
this is true and some bad ideas are coming to head 6d + 16-35 and 24-70 But hope Nikon will release some new version of wide lenses with VR.
Paul Liukas
thanks for post. where was your focus point?
Paul Liukas
thelenspainter wrote:
Paul Liukas wrote:
Hi friends,
thank you for advices. I agree with you, just some times, when you have near to far composition, these corners can ruin a photo completely. Actually for such images one should you PCE I think.
Hey, you better be careful making such statement in the Nikon forum, "we' Nikon owned the WA territory, LOL, yeah as current owner of 14-24G and 16-35G I also wish Nikon upgrade the 16-35 sooner rather than later, it's one of my most frequently used Focal range lens, so a upgrade is welcome and I am willing to pay for the premium price.
GlobalGuyUSA Senior Member • Posts: 2,147
Very nice updates!  Thanks for posting pics to show how a different technique can dramatically affect the outcome of the image.  I guess these "tips" are what we call the "art" of photography.
The images you shared are more than acceptable, they are very good.  I'm not sure whose going to complain about it for most work, even meant for artistic presentation.
Someone can say, "that's pretty sharp!"
Sincerely,
GlobalGuy
 GlobalGuyUSA's gear list:GlobalGuyUSA's gear list
Nikon D810 Nikon AF Nikkor 135mm f/2D DC Nikon AF-S Nikkor 85mm F1.4G Nikon AF-S Nikkor 58mm f/1.4G Nikon AF-S Nikkor 20mm f/1.8G ED +9 more
