E-PM2 and VF-2 usage questions
Started Jul 16, 2014 | Questions
Drahila New Member • Posts: 15
I'm planning to buy E-PM2 and VF-2 or VF-4. I have searched answers to these questions and read the manual, but still confused.
In single focus point mode, how do I re-center the focus point? Especially if I'm looking throught VF-2 and want the focus point to jump back to the center and don't want to take my eye out of VF-2.
When in aperture priority mode, can I set minimum shutter speed for auto ISO?
How easy it is to change shooting modes, in your opinion? Will I miss the mode dial?
Olympus PEN E-PM2
skeys Veteran Member • Posts: 3,191
Re: E-PM2 and VF-2 usage questions
Thread moved from the Oly SLR forum.
My comments and opinions are my own. I am neither a staff member, nor a paid employee, of DPReview.
Guy Parsons
Guy Parsons Forum Pro • Posts: 40,000
More talk than answers....
Somehow the combination of E-PM2 and VF-4 seems wrong to me. The very small body with a large viewfinder attached seems to counter the whole idea of a small camera.
If you MUST have a viewfinder then the E-M10 makes much more sense.
In my case E-PL5 with tilting LCD which eliminates many of the screen view problems and so far in over 18 months now I have not had to use my VF-2, I'm fully converted to LCD use but not everyone can handle that.
There's two AF schemes, one is the regular default as you turn on where the green AF box appears briefly when you half press the shutter for AF, assuming that the camera Mode is set to half press AF (the Custom Menu Control Modes can alter that).
In my case I have a small central focus point and leave it there, I half press focus then hold and re-frame and full press to shoot. That way the AF does not jump to some unexpected or undesired point as it can do with multi point AF. I sometimes change to face recognition for family shots and that is the only time I use jumpy AF spots.
The second AF scheme is via the Magnify function (already on a dedicated button with E-PL5 and some others but needs to be assigned to the Fn button with other bodies. The Magnify AF scheme is also invoked when touch screen AF/shoot is used. That scheme has the rectangular green focus box on the screen all the time in live view. The box can be slid around with the up/down/left/right buttons or by the finger in touch screen AF/shoot modes. It is returned to centre by holding the OK button for a second.
Not sure on the E-PM2 how that one is reset back to the regular AF scheme but on my E-PL5 I hold the Magnify button to get it back to default AF mode, but that may depend on other custom settings with the rather complex Custom Menus.
Not fully tested by me but the strange act of setting a minimum shutter speed for flash helps do that, generally though the camera does follow the old rule of shutter speed = 1/(equivalent focal length) and bumps the ISO when it gets too slow for the focal length seen.
Can't answer that one but most seem happy with the dial-less E-PM2. In the dial world on my E-PL5 I have assigned MySets to the Mode dial positions and that makes life so easy and predictable, no more turn on with accidental silly settings, the assigned MySets make sure that the camera works as expected.
My general M4/3 stuff starts here, but not much help for E-PM2 as I've never used one. Other general stuff is there like how to see the true shutter count of a camera, a good idea to check that on a newly acquired camera to see if really new. New means an initial shutter count of around 100 but can be near 200 in some extreme cases of factory testing.
Summary.... To me the E-PM2 only makes sense keeping it as a viewfinder-less camera to keep the whole package small (adding an expensive viewfinder to a cheaper small body is possible but weird). The E-PL5 makes more sense again in a viewfinder-less mode, but if you really must have a viewfinder then the E-M10 makes most sense of all (and has the latest features of all).
Regards.... Guy
Guy Parsons
Missing link....
Yes I know, that probably applies to me, but where I said.....
"My general M4/3 stuff starts here", then the "here" now has a link here .
Regards.... Guy
Paulmorgan Veteran Member • Posts: 9,499
Personally I go with the VF3, it locks to the shoe and its small and neat on the EPM2.
(unknown member) Veteran Member • Posts: 3,010
That's the combo I use. It works not the primo solution but workable.
http://www.flickr.com/photos/90891174@N04/
Guy Parsons
Ummm, your message was hidden until reveal signature. That's caused by the double hyphen that you used in front of the text.
Back to thread ...... Looking at Sydney prices the E-PM2 has disappeared from almost all sellers (the E-PM3 looming?), but the equation of E-PM2 kit plus VF-4 pushes the price here to near E-M10 levels so it sounds a bit odd to make the E-PM2 choice if needing a viewfinder.
Regards....... Guy
Regards....... Guy
That's a good point. The E-M10 is a better camera.
Guy Parsons
That signature hyphen problem
You did it again, do not put any text after the double hyphen that separates the signature from the posting.
Use the plain text editor to see those symbols. Everything after a double hyphen becomes a part of the signature and the plain text editor shows where they sit.
Regards.... Guy
You haven't said how you intend to use the camera.
For a simple street combi using a small body and a prime I find the good old optical plug on viewfinders good and shop around they can be picked up quite cheaply, I paid about a fiver for this one and it works just great combined with a 17, 19 or 20mm (its not quite so good with the 14mm pictured though)
Re: That signature hyphen problem
Regards.... Guy
Testing one two three..
Guy Parsons
Regards.... Guy
Heh, heh, that's better !
Sorry to sound like a pedantic geek but that double hyphen thing catches a lot of people. The casual lurker who does not realise what has happened sees only an info-free post when people put their text down with their signature or accidentally use a string of hyphens to separate some text blocks.
Most times I have "hide signature" situation so it's hidden to me as well.
Regards.... Guy
Secret text that some may not see.
Regards.... Guy
Regards.... Guy
No problem Guy. It's OK.
traveler_101 Senior Member • Posts: 2,203
Hi Drahlia
I have the E-PM2 with a VF-2; I don't think it is contradictory to have a small camera with an attachable viewfinder; in fact this is a very old solution. Sometimes if you are using a favourite prime lens you might prefer an ocular attachable finder for minimising size as someone suggested, but the electronic finder is really nice and I would recommend it, especially if this camera will be your main kit (i.e. not a second camera). I would recommend VF-2 for its quality and price.
With the directional arrows . . . after you bring up the screen that lets you set focal point. I use centre point focus and have assigned focus function to the Fn button right adjacent to the shutter. This makes it very easy to focus, reframe quickly and shoot.
Don't know. I set ISO manually which is very easy to do on the Super Control Panel.
Not too bad, but it takes more time than turning a dial. Some of the features on the dial are available on the Super Control Panel--specifically art filters, if you use them. Other than using an art filter from time to time, I shoot Aperture priority so I don't care about the PASM dial; however if I were planning to constantly switch shooting modes i would be looking at an E-PL5.
It's a nice camera; I would say that I wish it had a flip screen (I find myself wishing for that from time to time), but you compensate for that somewhat by flipping the finder on the vf-2 into an up position allowing you to focus by looking down into the finder, like an old twin reflex viewfinder. I would really recommend getting the vf-2; it adds a lot to the camera and of course when you don't want to use it you just detach and place in a shirt pocket (light and small). Overall, the E-PM2 is sturdy, lightweight and takes good photographs--at a very reasonable price.
 traveler_101's gear list:traveler_101's gear list
Olympus PEN E-P1 Olympus PEN-F Olympus M.Zuiko Digital ED 40-150mm 1:4-5.6 Panasonic Lumix G 14mm F2.5 ASPH Olympus M.Zuiko Digital 45mm F1.8 +3 more
OP Drahila New Member • Posts: 15
Sorry for the late reply.
It seems that traveler_101 really understood what I was looking for 3 weeks ago: an affordable little camera that has an EVF that can be removed to make it even smaller.
It also seems that the rest of you knew what I really was looking, even better than I did. After a couple of weeks of thinking, I think I'll buy a second hand E-M5. It will be affordable enough, have a tilt screen, EVF and it's not that big. Plus the weather sealing. Now that I think of it, it's a good extra. I just need a weather sealed lens too.
Thanks everybody!
