Any way to fire 2 f42am flashes wirelessly
Started Jul 16, 2014 | Discussions
Antonlm
Antonlm Regular Member • Posts: 470
From a sony a-580? (Using the popup flash) tried searching, but couldn't find any info.
Sony A-580
Sony A-100
Tamron 17-50 2.8
Tamron 70-200 2.8
Minolta 50 1.7
Minolta 35-105
Tamron 70-300 LD DI
Minolta 28-85
Sony HVL-F42AM
 Antonlm's gear list:Antonlm's gear list
Sony Alpha DSLR-A580 Sony a77 II Tamron SP AF 70-200mm F/2.8 Di LD (IF) MACRO Tamron SP AF 17-50mm F/2.8 XR Di II LD Aspherical (IF) Tamron SP AF 90mm F/2.8 Di Macro +3 more
cplunk Senior Member • Posts: 1,834
Re: Any way to fire 2 f42am flashes wirelessly
Same way you'd fire one of them.
Set the camera to wireless flash, put it on the camera and press the shutter to set the channel on each of them, popup the flash and they should both fire the same as if you were only using one.
 cplunk's gear list:cplunk's gear list
Sony RX100 Sony Alpha DSLR-A900 Sony Alpha DSLR-A330 Sony Alpha a99 Sony a6300 +19 more
Antonlm
OP Antonlm Regular Member • Posts: 470
Thought I did that, but it only fired the last flash that was attached. When I get home Ill try pressing the shutter with each flash, maybe I did not do that. Thanks for the reply.
Sony A-580
Sony A-100
Tamron 17-50 2.8
Tamron 70-200 2.8
Minolta 50 1.7
Minolta 35-105
Tamron 70-300 LD DI
Minolta 28-85
Sony HVL-F42AM
Calico Jack Senior Member • Posts: 2,306
Did you check the HVL-F42 FAQ page on the Sony website?  See here.
Mark (aka Pirate!)
 Calico Jack's gear list:Calico Jack's gear list
Sony Alpha DSLR-A850 Konica Minolta Maxxum 7D Sony Alpha DSLR-A100 Sony DT 11-18mm F4.5-5.6 Tamron SP AF 90mm F/2.8 Di Macro +26 more
I believe this just sets the channel on them, and that can be done through the menu also, I think (I've never tried).  I used to have two of these, and I'm pretty sure I've used them both at the same time successfully. It is possible that maybe the camera is switching "channels" when you go from setting one to the other, and you should be able to check that on somewhere on the flash's menu to make sure they are the same.
But, if each works independently (you have verify it's not just one that doesn't work at all?) I can't think why else they wouldn't work together.
Antonlm
Thanks again...I'm pretty sure I'm doing something backwards...I tried to change the channel on one but it would only select ch2.
Sony A-580
Sony A-100
Tamron 17-50 2.8
Tamron 70-200 2.8
Minolta 50 1.7
Minolta 35-105
Tamron 70-300 LD DI
Minolta 28-85
Sony HVL-F42AM
carljervis Senior Member • Posts: 1,000
Put each flash on the hotshoe, turn on, remove and repeat with the second. Check both are set for same channel. Should work. I've fired 2 and a Nissin di866 at the same time with just the pop up.
IanML Senior Member • Posts: 1,654
It sounds like the flashes are set to different channels. Choose one channel, and set both flashes to it (Custom settings - pages 44 & 45 of the manual). Then put one on the camera and power camera and flash, then select WL on the camera and half-press the shutter release. This will set the camera to the chosen channel, which will be indicated on the flash.  Repeat with the 2nd flash if you wish, but it is only necessary to set it to WL using the mode switch, as the camera is already set.
Ian
 IanML's gear list:IanML's gear list
Sony Cyber-shot DSC-HX90V Sony RX10 IV Sony SLT-A33 Sony Alpha NEX-5N Sony a77 II +1 more
Antonlm
Found what I was doing wrong...I didn't realize that changing the channel was a custom setting and I needed to  press hss for the 3 seconds to be able to put the flash that was on channel 2 to channel 1. Thanks for all the help.
Sony A-580
Sony A-100
Tamron 17-50 2.8
Tamron 70-200 2.8
Minolta 50 1.7
Minolta 35-105
Tamron 70-300 LD DI
Minolta 28-85
Sony HVL-F42AM
