Using Olympus EPM2 with m.Zuiko 12-40/2.8 Lens
Started Jul 16, 2014 | Discussions
Bach65 New Member • Posts: 1
I'm planning to take photographs of my stepson's upcoming wedding but due to budget constraints I will not be able to purchase an EM1 (hopefully a future acquisition) and the m.Zuiko 12-40 PRO lens so I'm considering getting just the lens at this time.  I do have an EPM2 but I'm concerned about the handling/ergonomics of the 12-40 on such a small body.  Does anyone have experience with this set-up?  I'm also considering purchasing the VF-4 viewfinder as I'm assuming bracing the camera to my face will improve the stability (plus I'd rather compose/focus using a viewfinder).  Any suggestions and/or feedback would be greatly appreciated.
Olympus PEN E-PM2
Guy Parsons
Guy Parsons Forum Pro • Posts: 40,000
Re: Using Olympus EPM2 with m.Zuiko 12-40/2.8 Lens
In my case the not much bigger E-PL5 and 12-40mm and it's a good combination. The extra mass of the lens does help make the camera steadier.
Holding the camera involves more the left hand doing the work of supporting the lens and left side of the body, and the right hand with a light grasp and in my case with a snugly fitting wrist strap for extra right side support.
Some say shutter shock is an issue with the lighter bodies but it has never troubled me. Besides, I use anti-shock setting of 1/8 second which possibly helps.
Unless really needed it would probably be best to leave stabilisation off and only turn it on when you start to see shake or the shutter speeds are getting too slow.
Auto ISO works fine but everyone has an upper limit that is different, I change between upper limit of 800/1600/3200 for average situations, but if totally desperate to get some sort of image in the dark then I let it run to 25600.
Advice would be to always take RAW+jpeg as problem shots can be better recovered via the RAW. I wish that I had taken RAW+jpeg from day 1 as now I'm slowly getting better with RAW converters and some old favourites will come to look a bit better.
Have a spare battery or two and some spare card capacity and for 'round the tables shots even the diminutive FL-300R flash works fine, better than the supplied slide-on flash (which would give lens/hood shadows with that camera & lens). The FL-300R is my carry-all-the-time flash as it does maybe 90% of what I need for flash.
In my case I never use the VF-2 any more, I am fully converted to LCD use where in tests I did find that slightly more stable than to-the-head with VF-2 shots. Maybe IBIS is tuned better for holding away from the face and not to the head?
Regards...... Guy
Virtual Photon Senior Member • Posts: 1,701
Buy the 12-40 - wonderfully built, sharp and reasonably fast.  Good glass is the way to go.
Rent the M1 - It is relatively cheap for four days.  Get it a couple days before to play with it and get it set for what you want to do.
 Virtual Photon's gear list:Virtual Photon's gear list
Nikon D500 Nikon Z7 Nikon Z6 Nikon AF-S Micro-Nikkor 60mm F2.8G ED Voigtlander 20mm F3.5 Color Skopar SL II +9 more
(unknown member) Veteran Member • Posts: 3,010
I think the VF4 is almost 300 dollars. That is a lot for something you will sell for a loss later if you upgrade the body. I wouldn't worry about the handling issue. Its smaller and lighter than the 75-300mm zoom I use on my E-PM2 and that's manageable. I personally believe in viewfinders maybe my eyesight isn't as good as it was when I was younger but in bright light its a huge help for me. I use the VF3 its OK and it does the job but not as nice as the VF4. However it's a lot cheaper and I will keep it on the EPM2 as my macro setup and backup camera if and when I upgrade.
http://www.flickr.com/photos/90891174@N04/
Cychen Regular Member • Posts: 243
I don't think there's any problem with the setup. I used to shoot the E-P2 with the 14-54mm MKII through the adapter. The lens size is definitely too much for the little camera but surprisingly, it handles pretty well (albeit the sluggish focus speed) with my left hand supporting the camera(by holding the lens.) The EPM2 belongs to the new breed of Olympus cameras, I'm sure it will fare pretty well with the 12-40mm.
Personally, I don't think the VF4 is needed. Because the reason for using one, if I'm right, is to stabilize better in slow shutter speed. But if you do it in weddings, it will not work.
 Cychen's gear list:Cychen's gear list
Olympus XZ-1 Olympus E-1 Olympus PEN E-P2 Panasonic Lumix DMC-G2 Olympus OM-D E-M5 +17 more
luigibenet
luigibenet Regular Member • Posts: 309
I used my 50-200mm on a PL2, using the tripod ring attached to my shoulder strap......
Biggest issue I had was when I heard tourists laughing when I was at the Desert Botanical Garden and turned around just in time to see them pointing at my set up!! LOL!!
 luigibenet's gear list:luigibenet's gear list
Olympus TG-6 Olympus E-M1 II Olympus 12-40mm F2.8 Pro Leica Nocticron 42.5mm Panasonic Leica DG Summilux 15mm F1.7 ASPH +1 more
m3th0s New Member • Posts: 2
I currently have both of these camera bodies and the lens you note. I thought you might want to see how the setup looks like together (I have a VF-3, but not attached in this shot). In my mid-sized hands, this feels light still, not badly balanced or unstable once you bring your eye to the viewfinder area.
EPM2 with m.Zuiko 12-40/2.8 lens (not extended)
 m3th0s's gear list:m3th0s's gear list
Olympus E-M1 Olympus 12-40mm F2.8 Pro Nikon D80 Olympus PEN E-PM2 Nikon AF-S DX Nikkor 18-135mm f/3.5-5.6G ED-IF +6 more
