5D3 took a swim (halp)
Started Jul 16, 2014 | Discussions
chromatropic New Member • Posts: 8
I was doing a photoshoot, holding onto what was essentially a post in a wall as I stepped around a swimming pool. Pole came popping right out and sent me into the pool with my 5D3, 180mm F/3.5L and a 128 gig Lexar CF card and a 64 gig Sandisk microSD in an adaptor. I my back hit the bottom in a 4 foot deep swimming pool so it was not a trivial dunk. I did get it out very fast though.
CF card is fine.
microSD card is fine.
Lens is fine.
Shutter was firing by itself when the camera came out of the water. I pulled the battery immediately, and left it to dry for a while. When I put the battery back in the LCD was coming up as Error 30 so I sent it in to Canon Canada (CPS) for repair.
CPS sent me a repair estimate that said there was too much rust on the inside of the camera, that it was beyond repair, and enclosed an invoice for a new 5D3. Since it powered up and was able to diagnose itself at least to Error 30 I don't buy that it is a complete write off.
I told them to send it back to me disassembled and they did. Thing is they never really took it apart they just took off the case. There was some white residue on the inside which is probably left over from the water but there is no rust on anything. So I don't feel like they pulled the boards and tested to find out what needed replacing. Much easier to send me an invoice for a new camera. They didn't make any attempt to get it to work (no judgment there whether that is the right or wrong choice, just stating, they opened it up, had a look, then wrote me an invoice for a new camera).
At the same time I sent in an 85mm F/1.2L that the focusing ring had seized on. This had some exposure to water at some point but the seizing happened years after. They sent me back a repair estimate of $1,500 and said it needed a new USM motor. The thing is the lens autofocuses just fine so the motor I think must be fine. It's just the focusing ring is seized. So I was expecting them to take it apart and unjam the focusing ring.
Overall then my "repair bill" came to $5,000 and I just told them to do nothing.
I sent the two mated together. When Canon sent them back, I guess because I asked for the camera to be disassembled, they just stuck the lens in a plastic bag with the rear element exposed and packed it randomly with the camera. I was pretty surprised. Even if the lens is in need of repair there is no reason to expose the rear element to scratching during shipment and *further* repair.
Overall, it is feeling like it was not treated adequately so I am skeptical that this is something that should be thrown into the garbage as they imply.
I'm trying to figure out what my options are from here. Some photos of the irretrievably rusty interior of my 5D3 are attached. There's white residue in the bottom corner near where the clock battery goes. And a little bit in some other places but the boards look pretty untouched, and I think if they would have been absolutely unsalvageable then the unit would not power up at all? I say that as a question.
I'm looking for any suggestions to at least try to mitigate the financial damage. Sell it off like this, try with an alternate repair shop who will actually test it, whichever. I already bought a new camera based on Canon's response and it is en route.
Halp?
Not sure if what I posted will be accessible on high res, so I put low and high res versions of the images here:
http://www.chromatropic.com/5d3
Canon EOS 5D Mark III
John Zeman Regular Member • Posts: 378
Re: 5D3 took a swim (halp)
For your sake I hope one of your options is to turn in an insurance claim.
Omexis Contributing Member • Posts: 514
According to Canon, an Err 30 is a malfunction with the shutter
 Omexis's gear list:Omexis's gear list
Sigma DP2 Merrill Canon EOS 5D Mark III Canon EF 24-105mm f/4L IS USM Tamron SP 150-600mm F5-6.3 Di VC USD Adobe Photoshop Lightroom 5
Serickmetz
Serickmetz Contributing Member • Posts: 944
It's toast man.  Get your insurance claim in, stat!
"Our imagination is nothing compared to nature's awesome reality." - Neil deGrasse Tyson
 Serickmetz's gear list:Serickmetz's gear list
Fujifilm X100S Canon EF 50mm F1.8 II Canon EF 24-105mm f/4L IS USM Adobe Photoshop Lightroom 5
Phil
Phil Veteran Member • Posts: 3,142
Re: 5D3 took a swim (halp) FUBAR
5
I'm a retired silicon valley reliability engineer. If you've read some of my numerous post on what to do and when to do it in the past you might have sent a perfectly working camera to Canon for a check up.
Instead, because you dried the camera without flushing it with de-ionized water first Canon is correct. Your camera is now toast.
Pure water (de-ionized water) is a fantastic insulator, you can put thousands of volts on two probes in a beaker of de-ionized water and virtually no electric current will flow. In fact it is used in the cleaning process during manufacturing for electronic equipment all the time.
When it's a salt water pool, ouch! And a chlorine pool is ouch too. They test the water every week to adjust the ph of pools so it was either an acid or a base but far from de-ionized water.
But still I recommend you carry at least a gallon of de-ionized water in the trunk of your car just in case. Turn it off, pop out the batteries, close the doors, rinse the exterior with DI and towel it dry. Open each door looking water intrusion, if it's there (and will be on such a bad dunk) rise it out with DI. Remove the lens, rinse it with DI. If the sensor cavity is wet rise it gently with DI.
Rinsing out a camera that submerged in water is what I'd call a Hail Mary Pass, but just drying it out will likely kill it off.
The ionic contamination left behind even when tap water dries can set up conduction paths between IC pins and circuit board traces that quickly become shorts after power is applied and copper starts to migrate down these paths.
Once you've rinsed with DI pat dry every thing you can safely and start the drying using a desiccant to dry the moisture out. I keep a brick sized desiccant with moisture indicator on the side sold for use in gun cabinets on hand along with a small space bag (a giant zip lock) for dying. It could take a day or two but you oven dry the desiccant (when the indicators say it is time) and resume when it cools.
If you are going to shoot around water you need to be prepared. Even if you never fall in again, some idiot can always run up a do a canon ball before he figure out it's a photo shoot.
We even have rouge waves that come ashore on Northern California beaches occasionally. It's only happened to me once but the water went from being 50-100 feet of beach to the cliff to lapping at the cliff in one wave leaving me in 2-3 feet of water half way to the cliff.
Phil Agur
“Imagination is more important than knowledge..." -- Albert Einstein
 Phil's gear list:Phil's gear list
Canon EOS 5D Mark II Canon EOS 5D Mark III Canon EF 17-40mm f/4.0L USM Canon EF 24-70mm f/2.8L USM Canon EF 70-200mm F2.8L IS II USM +4 more
Al Downie Senior Member • Posts: 1,407
Assuming there's a reason why you can't make an insurance claim... it might be worth taking it to a non-Canon-authorized camera repair shop, and negotiating a price for them to open it up properly and have a look, and do their best to clean & fix it without buying any replacement components. If Canon are anything like Apple and other computer manufacturers, their 'repair' policy is to examine the machine and replace any 'affected' components, without even having a close look to see if simply wiping the affected components would fix the problem. Their 'authorized' repair centres will be under strict instructions to do the same.
As a last resort, if the damage is local to one corner and nowhere near the sensor or any optics, you could try suspending the exposed section in a bath of clean (boiled?) water again for a few hours, then giving it a scrub with some q-tips, then bathing again and repeating the cycle until there's no visible residue on the part, and the water looks clean on rinsing, and then put the camera on a low-heat radiator for DAYS to dry out completely. I've had some success with laptops in the past using this method.
Good luck!
<edit>Apologies - this was written at the same time as Phil was writing his more complete description of the de-inonised water thing</edit>
 Al Downie's gear list:Al Downie's gear list
Fujifilm X-Pro2 Fujifilm XF 35mm F1.4 R Fujifilm XF 23mm F1.4 R Fujifilm XF 56mm F1.2 R APD +1 more
hotdog321
hotdog321 Forum Pro • Posts: 21,150
Sorry, I've got nothing. You did what I would have done. But I really appreciate your post and learned some good stuff from the other posters.
 hotdog321's gear list:hotdog321's gear list
Canon EOS 5D Mark IV Canon EF 100mm f/2.8 Macro USM Canon EF 70-200mm F2.8L IS II USM Canon EF 24-70mm F2.8L II USM Canon EF 16-35mm F4L IS USM +3 more
Mike921 Regular Member • Posts: 301
Sorry to hear about your trouble.  Here's another view, with electronics, especially when they've been submerged, even if they power up, you never really know how long they will continue to function.  I suggest that the only way Canon could assure a reliable repair was to replace everything.  The last thing they (and you) want is a camera being returned every few weeks/months for some random problem caused by water damage to a part they did not replace.
You indicated you were on a shoot, so I'll assume you're a pro - do you really want to take gear into the field which could fail at any moment?
 Mike921's gear list:Mike921's gear list
Canon PowerShot S400 Canon PowerShot S2 IS Canon PowerShot G12 Canon EOS-1D X Canon EOS 5D Mark III +12 more
OP chromatropic New Member • Posts: 8
Thanks guys for the spectrum of feedback.
I've dumped water on my macbooks before to the point where they would not power up at all, or just lost a few keys. Repairs involve replacing the affected components.
I just wish I had the equipment to test it board by board. So I will probably go the route of trying to further disassemble within my skill level and look for anything that seems effected inside. It's not like I have a warranty to worry about.
If the lens had failed, and both memory cards had failed, I think I would look a bit more along the lines of complete writeoff is reasonable. These three other electronic elements survived and are 100% functional, camera battery is fine, clock battery is fine, basically anything I can touch and verify myself is all fine. So it seems a leap to me to say that everything else is 100% destroyed, while the LCD lights up, the shutter actuates (forgot to mention that, it goes up, but then does not release), and it runs diagnostics. So I will try to scrub it from here and see.
Insurance? What's that?
If anyone knows a shop I can contact online that is capable of testing / swapping components to see if it can come back to life that would be awesome. At least then I might know which components can be salvaged for ebay.
Worst case scenario I just video what it does, show the disassembled pictures, and ebay it at $1.
Thanks again. Don't take my refusal to give up as disrespect. Nobody wants a $3,000 paperweight.
qianp2k Forum Pro • Posts: 10,350
Sorry to hear you loss. Hope you can find another way to rescue the camera.  There are success stories from someone with similar experience.
http://blog.planet5d.com/2009/06/two-canon-eos-5d-mark-iis-go-for-a-swim-and-survive/
TTMartin
TTMartin Veteran Member • Posts: 7,304
Re: 5D3 took a swim (help) FUBAR
Thanks Phil.
Is there are reason to simply rinse the camera with de-ionized water as opposed to submerging it in a container of it? Perhaps with one or two changes of the de-ionized water.
Would submerging it in or rinsing it with 97% isopropyl alcohol as a final step before drying have any negative effects? Luckily, I haven't had to deal with anything besides cell phones.
I was successful using 97% isopropyl alcohol on my daughter's cell phone that had gotten wet, dried leaving some white residue. I disassembled it and submerged the parts in the 97% isopropyl alcohol and wiped all residue off. I then dried it as much as possible and put the phone in the oven over night on its lowest setting (125 degrees Fahrenheit). Put the battery in the next day and the phone worked fine till it was replaced a year later.
Obviously, dSLRs are constructed differently than phones as there are moving parts. So that's why I'm asking. It's good to have a plan in mind if this should ever happen.
Thanks again.
All statements in my posts represent my interpretation of data, research opinion or viewpoints.
The opinions expressed are not representations of fact, and are subject to change without notice.
 TTMartin's gear list:TTMartin's gear list
Canon PowerShot S100 (2000) Canon PowerShot SD1000 Canon PowerShot G1 X Canon EOS 40D Canon EOS 400D +26 more
FUBAR? NUBAR!!!! It lives!
"Instead, because you dried the camera without flushing it with de-ionized water first Canon is correct. Your camera is now toast."
Well it ends up that this is not so.
My feeling as I had written was that whatever board or component was affected could be replaced and the camera should be functional. I had written that it powered on and displayed an error code. Canon just opened it, saw water damage, wrote it off and sent me a bill for a new camera.
This is disservice in the highest degree. It's like if your car blows an exhaust manifold and you brought it in to the dealer, and the dealer just shrugged and says well, you need to buy a new car.
Who wins and who loses in that scenario? The dealer, the manufacturer win. The customer loses.
I sent the camera to Sun Camera Service ( www.suncameraservice.ca ) and talked to two other shops who had experience in bringing a water damaged 5D3 back to life. They all expressed measured confidence that it was possible. I picked Sun Camera Service because they're in Canada and I'm in Canada.
I'm going to make a full report and mention the other two shops once the camera comes back. Here's the list of damaged parts:
REPLACE SD-MAIN CABLE, BOTTOM-FRONT FPC, BOTTOM-MAIN FPC, MAIN PCB, SD-MAIN FPC, MIRROR BOX UNIT & AM FPC ASS'Y
They did a full cleaning then and I guess calibrated it all.
Cost to me was $620 for parts, $160 for labor, $25 for shipping back and $100 in tax for $900 Canadian (about $800 US).
Compare this to Canon who only removed the cover basically, saw water damage and punted without disassembling and testing parts. Their report was this:
"Upon Inspection tech found too much rust inside camera, on top cover, mirror box, back cover, front PCB, bottom PCB,.... condition beyond repair. Suggestion of replacement to new EOS 5D MARK III in exchange for damaged unit." About $3,100 US including tax. I would have to trade in my "condition beyond repair" camera in order to get this special price on a replacement unit.
So... I am much, much, much happier. Will take some photos with it and post them and make a full report as soon as it arrives and I get home from my current trip.
Cameron Habib Contributing Member • Posts: 896
Re: FUBAR? NUBAR!!!! It lives!
I think you're taking this too personally. Likely what they meant by "beyond repair" wasn't that they couldn't take it apart and diagnose what was wrong with it repairing only that part, it was that it wasn't worth the risk and time to them.
Lets say they spend a tech's full day diagnosing it, and it winds up it's $900 in parts and you decide to decline the repair. Or you give the go-ahead, get it back, and in a week or two something they missed (or unrelated) broke. They would either wind up with a very disgruntled customer, have to eat the costs of the additional repairs (since the camera they sent back to you should have been in "original working order"), or a combination of the both. It's for this very reason that when an engine blows, they don't just replace a cracked cylinder or rod and remount everything, they just install a new or rebuilt crate engine from the factory. Sure you can get that one rod replaced at a shop willing to take the time and effort to do so on your dime, but most manufactures are unwilling to accept that risk.
camhabib.com
 Cameron Habib's gear list:Cameron Habib's gear list
Nikon Z7 II Rokinon 14mm F2.8 IF ED MC Nikon Z 50mm F1.8 Nikon Z 24-70mm F2.8 +1 more
Phil
It would be interesting to know if that list of parts is all the electronics or not. And of course a one year report on how the repairs held up.
I'm sure my Fujica Drive (my first camera) was unrepairable after a family member let it tumble down the steps at the Notre Dame Cathedral. The frame was bent with the lens sticking out at an odd angel and the light meter jammed by another crushed corner, All ready a total loss in my mind so I peeled off the rubber covering and went to work. It didn't take long with a machinist hammer, a punch, and a dial indicator to beat the machined brass frame back into reasonable shape, level the lens, and free the meter. Putting the rubber amour back in place was the the hardest part, adhesives has come a long way since then. And several years later while it still had a tattered look it worked fine. Well as fine a 35 mm 1/2 frame view finder fixed lens can be.
I hope your repairs are that successful in the long run.
Phil Agur
PhotoKhan Forum Pro • Posts: 11,954
When Canon said "condition beyond repair" they did not meant it could not be repaired. They meant it couldn't be repaired to the standard levels they're obligated to comply with, i.e., durability of the repair.
As Phil so aptly and knowingly explained, after water damage and even if repaired, there's no way to know how the camera will behave in, say, 6 months.
I hope the intervention by SCS proves to be a long-term successful one.
PK
“Loose praise may feed my ego but constructive criticism advances my skills”
http://www.pbase.com/photokhan
(PBase Supporter)
ylco Forum Member • Posts: 54
I have a post in here call 5D Mark III only good as a trophy siting on tablet.
It' s not swimming pool water but rain from our beautifull country Canada.
I was told that Canon don't do cleaning process, they prefer sending a stupid answer as they did for you, PAY MAN!!
My cam is on a repair shop in Montréal. The guy cleaned all circuitry he could and needed to do.
Also Canon Canada are the best pain in.. for customer as they answer like stupid.  That well worth say. lets show how now.
The first picture you puted on this post, on the left side of the mirror box there is a PCB circuitry.
I sended a similar picture to Canon Canada and asked if the PCB can be bough alone and if they can provide piece number for it. N.B. I need only the number of the circuitry to get back my camera out from the repair shop.
They send back some pages from a part book that is not clear neither to me and the repair man.
The repair man told me that for the 5D2 the piece was available but he can't find a number for 5D3
He gave me a photocopy of what he is looking for with a round draft to identify the piece. I see CG2-2294 and he call it FPC ASS' y Front. That piece cost around 100$
I couldn't find this part anywhere from Google.
On the 5D Mark III I was told by a part seller from Internet that it is part of the Mirror box and need to be bough together, the number is CY3-1652-000, the price is 302$ US butt I will need to pay custom and shipping witch boost the price.
We had a place here global-semi who were selling it for 324$ CDA but it's close and no one is replacing that place here yet. If they were open we could have better answer.
For now our only way to get piece is passing by Canon Canada. If you buy a piece there is no return on it, so you must be shure on what you buy.
Is your camera still open and can you identify the piece number?
If you cover camera properly and keep wiping out water off body/lens (as I did in the Alaska wheal watch under heavy rain in swift boat with 60D and 100-400L that both are not weather-sealed), it's not a problem to shoot even a Rebel camera under heavy rain. As a matter of fact, in my last week trip to your beautiful country Canada (agreed), the first afternoon day at Niagara Falls was under constant raining, heavy at times and 30mph gusty wind (so strong that I could not use tripod). I had no problem to shoot with 5D3 and A7R under rains with a plastic bag covered on the top, and I carefully, frequently and quickly wiped out water off bodies/lenses. It's an user error   If you don't cover and don't wipe out water frequently and quickly it can damage even 1DX and D4s.
I ounce covered the XSi with a plastic bag and lastic and the camera went capout. The guy actualy having my 5D3 fixed the XSi in 2 weeks for 120$ CDA.
The 5D3 went capout the last time and I had a cover rain with sleeves and ropes to tighten harms.
I don't want to go back on that subject cause I wrote so many reply and so not easy to follow.
I actually need a part number for the piece I need, I try from forum since we can't get any good service from Canon Canada and no other distributor does provide parts in our Country since Global Electronics is close, not long ago.
I would like to complain about them in the International HQ but I don't have email to reach the top one man and I speak medium English, NONA Japanese. Maybe a good cleanup on employees could bring them a better appreciation from customer, as I read some from Taiwan that are very good from many peoples comments.
I wrote them but they can't service me, I must go with local one witch is Canon Canada where best pilicy is their stupidity. I am not the only one telling it now!
