Basildon Park (Downton Christmas 2013 location)
Started Jul 9, 2014 | Photos
Auster Pilot Senior Member • Posts: 1,222
Continuing my travels this week with friends from Australia who are big Downton Abbey fans. So we went to Basildon Park - a National Trust property not far from where I live. This was the location used for shooting the Christmas 2013 special episode of Downton Abbey.
No flash allowed in the building, but the NX1100 really excelled again in conjunction with processing from RAW via Capture One Pro.
Neil....
The Sky is a Beautiful Place
 Auster Pilot's gear list:Auster Pilot's gear list
Panasonic Lumix DMC-FZ200 Panasonic Lumix DMC-ZS40 (TZ60) Panasonic Lumix DC-ZS70 Pentax K-01 Pentax K-30 +2 more
Comment & critique:
Samsung NX1100
gameguru1360
gameguru1360 Regular Member • Posts: 448
Re: Basildon Park (Downton Christmas 2013 location)
Those are really nice pics. I just got an nx30 so it looks like my pics can look like that without the flash. I'm curious how it'll do with its auto tracking auto focus. Looking to also get a prime lens like the 45 mm 1.8f
 gameguru1360's gear list:gameguru1360's gear list
Canon EOS RP Panasonic FZ1000 Canon EOS Rebel SL1 Olympus E-M5 II Olympus OM-D E-M10 II +2 more
OP Auster Pilot Senior Member • Posts: 1,222
Thanks for your positive comment.
I don't have the nx30 so difficult to advise on whether it will do what you wish. Hopefully someone else here can.
Neil....
ianbullock Forum Member • Posts: 50
Nice pictures. NX30 should do at least as well as that sensor wise, but lens would likely be a bigger factor. I am assuming the 16mm pancake prime is being used here which wide open tends to have very good center sharpness and slightly iffy edges, if you are using 18-55 and both shots are hand held, with stabilization you can probably get similar results (would need a slightly longer exposure, but will have extra stability).
Of course, if you wanted everything in focus across the frame, you can stop down a bit, but would probably need a tripod or some sort of handy object to rest your camera on.
 ianbullock's gear list:ianbullock's gear list
Samsung NX300 Samsung NX 30mm F2 Pancake Samsung NX 20-50mm F3.5-5.6 ED Samsung NX 50-200mm F4-5.6 OIS Samyang 85mm F1.4 Aspherical IF +2 more
