Fuji x-t1 + 10-24 + lee seven5
Started Jul 6, 2014 | Discussions
twan Senior Member • Posts: 2,392
I'm considering to buy the lee seven5 system but it seems to vignet with the 10-24.
Does anyone has this lens and filter system and could share his experience and samples of the vignetting? If it's correctable in lightroom or not that worse, it saves me some money over the 100mm system.
 twan's gear list:twan's gear list
Fujifilm XF 35mm F1.4 R Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 10-24mm F4 R OIS Fujifilm XF 100-400mm F4.5-5.6 OIS WR +1 more
Fujifilm X-T1
Just a Photographer Senior Member • Posts: 1,368
Re: Fuji x-t1 + 10-24 + lee seven5
I went with the Hitech 85mm system.
It works fine with the 10-24 IF you can live with a 2 filterholder instead of 3.
Just remove one of the filterholders and replace the screws with the shorter ones that are in the bag as spares.
Even though the LEE has somewhat better filters, you pay so much less with the Hitech system that I couldn't put myself into buying the seven5 filter system due to its extreme high price.
 Just a Photographer's gear list:Just a Photographer's gear list
Nikon D4 Nikon D800E Fujifilm X-T1 Fujifilm XF 23mm F1.4 R Fujifilm XF 56mm F1.2 R +9 more
OP twan Senior Member • Posts: 2,392
Do you have some samples online?
Unfortunately not yet. Have just bought them myself this last friday.
But there are some good reviews available.
All say the same thing.
Lee is the best, but Hitech is not a bad investment considering the price difference.
They seem to come out second best in each of the comparison tests.
Avoid Cokin as it has very bad colour shift.
Camera.nu and Cameratools.nl have them available:
Hitech - http://www.cameranu.nl/nl/c11922/filters/hitech-filters/hitech-85x110mm-filters
vs.
Lee - http://www.cameranu.nl/nl/c11802/filters/lee-filter/resin-filtersets-75x90mm
Reviews on Amazon:
http://www.amazon.co.uk/Hitech-Grad-stops-Graduted-filters/dp/B0076YB9NA/ref=sr_1_3?s=photo&ie=UTF8&qid=1404645479&sr=1-3
Mo Kwart
Mo Kwart Senior Member • Posts: 1,084
I have Hi Tech, but have only used the system once. I shot a mountain stream in bright sunlight. All of my photos had a strong magenta cast. I have not pulled them out since, but will before long to give them a fair test. Not encouraged.
I would be pleased to hear that I did something wrong.
 Mo Kwart's gear list:Mo Kwart's gear list
Fujifilm X-T1 Fujifilm X-T2 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 23mm F1.4 R +3 more
Thanks.
Cameranu is nice (so you are dutch too?)
I'll check them out first. If you put some online, i'm still interested
cybersimba
cybersimba Senior Member • Posts: 1,316
This article describes how you can use seven5 with 10-24:
https://richardbowdenphotography.wordpress.com/2014/07/21/can-you-use-lee-seven5-filters-with-a-fuji-10-24mm-lens/
hope that helps,
-Cybersimba
Its all about light
https://www.flickr.com/photos/sachinsawe/
 cybersimba's gear list:cybersimba's gear list
Canon EOS-1D X Mark II Fujifilm X-T2 Canon EOS 5D Mark IV Sony a7R III Canon EF 85mm f/1.8 USM +17 more
