Canon EF 16-35mm f/4 L IS USM quick review
Started Jul 3, 2014 | Discussions
dmurphey
dmurphey Junior Member • Posts: 37
.Just did a quick new comparison between the new Canon EF 16-35mm f/4 L IS USM lens (June 2014 release) to the Canon EF 17-40mm f/4L USM and the Canon EF 35mm f/2 IS USM. Why the Canon 35mm f/2? Because it’s the sharpest wide angle I own.
The 35mm is clearly much sharper on the borders and corners than both zooms. Comparing the zooms, center crops look about the same, but the corners are really improved on the 16-35 f4.
I posted cropped images and descriptions to my website: http://www.davidmurphey.com/canon-ef-16-35mm-f4-usm-lens-review
Aloha,
Dave
Shot with the Canon EF 16-35mm f/4 L IS USM
 dmurphey's gear list:dmurphey's gear list
Leica Q Fujifilm GFX 50S Fujifilm X-E3 Fujifilm X-H1 Canon TS-E 17mm f/4L +12 more
kevindar
kevindar Veteran Member • Posts: 4,426
Re: Canon EF 16-35mm f/4 L IS USM quick review
the great weakness of 17-40 is corners and not as much the sides/borders.  would be useful to see the stopped down difference between the new lens and 17-40 in the corner.
 kevindar's gear list:kevindar's gear list
Canon EF 85mm f/1.2L II USM Canon EF 70-200mm f/2.8L IS II USM Canon EF 24-70mm f/2.8L II USM Sony Alpha a7R II Sony a6300 +25 more
Joachim Gerstl
Joachim Gerstl Veteran Member • Posts: 7,665
Aloha,
Dave
Thank you for the good comparison. This is what I was waiting for. Finally a good super wide angle zoom from Canon.
 Joachim Gerstl's gear list:Joachim Gerstl's gear list
Canon PowerShot G7 X Fujifilm X100F Fujifilm X-Pro2 Fujifilm XF 35mm F1.4 R Fujifilm XF 14mm F2.8 R +8 more
dmurphey
OP dmurphey Junior Member • Posts: 37
Should have been clearer in my writing.  Sorry.  The test was down at f/8.  That's about the best you're going to get out of both lenses.
bronxbombers4 Veteran Member • Posts: 3,387
surprised you got such bad borders at 35mm f/8 from the 16-35 f/4 IS (of course it's a complex scene and placement of focusing depth makes a HUGE difference, so it may all be down to just that)
here is a full image sample I took with 16-35 f/4 IS at 35mm f/8:
https://farm4.staticflickr.com/3866/14374449498_905b8368a5_o.jpg
Scott Larson Veteran Member • Posts: 6,054
The best thing about this lens is that it has flooded the used market with "old" but still wonderful 17-40mm f4 lenses. I got one and haven't found a reason to have bought the 16-35mm version instead.
 Scott Larson's gear list:Scott Larson's gear list
Canon EOS-1D Mark III Canon EOS 5D Canon EOS 5D Mark II Canon EOS-1D Mark IV Canon EOS-1D X +13 more
Just another Canon shooter
Just another Canon shooter Veteran Member • Posts: 4,691
If he focused in the center, then the corners are slightly OOF.
 Just another Canon shooter's gear list:Just another Canon shooter's gear list
Canon EOS 5D Mark II Canon EF 15mm f/2.8 Fisheye Canon EF 35mm F1.4L USM Canon EF 50mm f/1.2L USM Canon EF 135mm F2L USM +4 more
yeah although the prime pulled it off anyway, so it would be more than perhaps he ended up focusing the 16-35 just a trace deeper into the scene, it might just be that, i've been noticing how sensitivty these tests are, just a little difference in placement of focus and stuff can happen that can make it be hard to sure if it is the lens or the focus placement
