Panasonic 15/1.7 vs. Olympus 17/1.8 Comparison
Started Jun 26, 2014 | Photos
BarnabyJones New Member • Posts: 21
10
Just a quick and dirty comparison of both lenses. Both lenses were shot on two seperate e-m1s. Settings were kept consistent, though I was pretty inconsistent in matching the field of view. All images were shot in RAW and converted to jpeg through Lightroom 5 (100% quality, not re-sized.) Bokeh tests, brick walls, and flowers!
Key Points:
Wide open the PL is just a smidge sharper in the centre, but loses in the corners to the Oly.
Stopped down to F/2.8 the PL i say is still a bit sharper in the center. I have a hunch I'm not perfectly parallel to the wall when I shot with the PL, but if I was I think it's safe to say the extreme corners beat my Oly. Either that or I've got a copy that's slight off center.
At F/4 my Oly takes the lead in the center. The PL looks like extreme corners might be better, but only on the right. On the left you can see either my user error or the lens imperfection. My hunch is that it's me.
I personally prefer the Bokeh of the PL, which seems just that extra bit creamy, but they're so close I think for most people it would be a wash.
There's a lil something special with the PL that I feel is missing with the Oly, but I'll let you all draw your own conclusions.
 BarnabyJones's gear list:BarnabyJones's gear list
Sony 85mm F2.8 SAM +3 more
Comment & critique:
Adamant Contributing Member • Posts: 797
Re: Panasonic 15/1.7 vs. Olympus 17/1.8 Comparison
Thanks for this. It is consistent with my own conclusions about another pair of m43 cousins: the PL 25 vs. Oly 25 1.8. The Olympus's rendering is more bracing/clinical. The Panasonic's is more organic/creamy. Personally, I prefer the Olympus, but agree that they're very close.
ntsan Contributing Member • Posts: 963
Thanks for the compare
15mm really outclass 17mm, but it is up to people decide if it is worth the extra cost.
 ntsan's gear list:ntsan's gear list
Nikon Coolpix 5400 Canon EOS R Canon EF 85mm F1.8 USM Canon EF 70-300mm f/4-5.6 IS USM Tamron SP 24-70mm F2.8 Di VC USD +4 more
12
Where are you seeing that in these samples?  Honest question, not trying to pick a fight.
(unknown member) Veteran Member • Posts: 3,010
To me the Olympus has better saturation and contrast. I'd pick it over the 15mm. They are pretty comparable though.
Kelpie Regular Member • Posts: 440
Thanks for this it's not often I see a lens comparison were I like the pictures.
 Kelpie's gear list:Kelpie's gear list
Canon PowerShot G3 Nikon D300 Olympus E-1 Olympus E-30 Olympus OM-D E-M5 +18 more
oeoek Contributing Member • Posts: 532
Well done!
It is nice to see comparisons like these, very straight forward and well executed. I am still in doubt if I need a lens between 12 and 25mm, but this comparison shows I have more then one to choose from
Thank you.
 oeoek's gear list:oeoek's gear list
Olympus M.Zuiko Digital 25mm F1.8 Olympus OM-D E-M5 Olympus PEN E-PM2 Olympus M.Zuiko Digital ED 14-150mm 1:4-5.6 Olympus M.Zuiko Digital 45mm F1.8 +4 more
sigala1 Veteran Member • Posts: 3,911
Oly 17/1.8 sharpness advice
1. Because the lens has field curvature and the edges are front-focused relative to the center, you can increase edge sharpness by not using the center focus point but instead using a focus point closer to the edge. I like to use row 1, column 3 (for older Olympus cameras with a 5 row 7 column grid). This even helps when shooting at f/5.6.
2. The lens is sharpest center-corner at f/5.6 and using the trick above.
3. Stopping down to f/2.2 increases sharpness a lot, although i still think the lens is still quite useable wide open. I think between f/2.2 and f/5.6 is a no-man's land of not-too-useful apertures.
Understanding how the field curvature affects your images is a very big factor in getting the best images from this lens.
The other characteristics of this lens, which are bad characteristics, are that it has low contrast and is susceptible to blooming (if a very bright and a very dark object are next to each other, the brighness will seep into the dark area creating a veil of low contrast.
The low contrast creates the illusion that the lens is less sharp. That's why they say that images from this lens takes well to sharpening, because the detail is there but you can't make it out without sharpening.
chris_j_l Regular Member • Posts: 355
5
The hyperbole of comparison and value of comment. People like to think they are doing more than "bikeshed painting" - when with things like this (2mm FL diff and both are very good quality items - so essentially interchangeable in a large number of situations) are brought up. As a result comments like "A slaughters B" or "B kerbstomps A" are easily translatable into "A is marginally different to B and I prefer A".
It's like student politics - the arguments are so vicious precisely because the stakes are so small.
C
G1Houston Senior Member • Posts: 2,985
I too like the 15mm better because ...
I wouldn't say that the 15 outclass the other but I like it better because:
(1) better rendering of the bokeh, which is smoother especially when there is busy highlight in the background.  This is quite remarkable considering that the 15 is a wider lens.
(2) better rendering of color, it is just so slightly warmer, see the color of the brick in the first two pictures.  Now, this could also be affected by the camera's auto WB so we should hold judgment for now.
These two plus the fact that it has an aperture ring making this lens an excellent value for the quality/features that it delivers.
 G1Houston's gear list:G1Houston's gear list
Nikon D7100 Olympus OM-D E-M10 II Panasonic Lumix DC-GX9 Panasonic Lumix G 20mm F1.7 ASPH Panasonic Lumix G 14mm F2.5 ASPH +5 more
arbuz Senior Member • Posts: 2,247
Bokeh. Looks much better.
 arbuz's gear list:arbuz's gear list
Nikon D600 Samsung NX300 Panasonic Lumix DMC-G6 Samsung NX30 Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS +14 more
Henry McA Forum Member • Posts: 58
Re: Oly 17/1.8 sharpness advice
I noticed the blooming too and thought that my camera was "ill". Very interesting, it never crossed my mind that it could be caused by the lens.
I compared the Oly 17 1.8 with the Pana 15 1.7 too and came to a very similar conclusion like so many here.
To me the 15 had the nicer bokeh and slightly warmer colors but higher distortion and a more organic or analog look. The 17 was more clinical, cooler colors, higher contrast, lower distortion, better manual focus, and more interesting focal length. But neither was special and both felt overpriced.
In the end, I did send them both back.
Neurad1
Neurad1 Senior Member • Posts: 2,498
I have what I believe to be a practical question....Let's say I was considering buying one of these two lenses, and read this post for guidance in my choice.
My question: For any given lens, what is the expected, "manufacturer-acceptable", copy to copy variation in lens quality (sharpness, microcontrast, etc)? If I decided that the 15mm looked "better" for whatever reason and ordered it, could I be certain that the copy I received would result in the same relative IQ observations if I were to do the comparison myself with a random copy of the 17mm? If not, how are these comparisons helpful?
 Neurad1's gear list:Neurad1's gear list
Sony RX1 Sony RX100 III Olympus OM-D E-M5 Olympus PEN E-PL5 Olympus E-M1 +44 more
When you look at all the "reviews" you see a pattern ...
Any A vs B comparisons even done under well controlled conditions are not very meaningful if the perceived difference is small.  However there have been several reports now on the 15 mm f1.7 lens and I think it is safe to say that this is an outstanding walk-around lens that delivers high center sharpness, nice bokeh, and a nice warmish color.  The corner will be slightly soft wide open — most likely a design compromise to deliver a good bokeh. Why is this such a big deal, considering the size and cost of this lens? Corner to corner sharpness seems most important to landscape photographers who will most likely use it stop down.  For people who use it wide open, they will be using it in dim light or to get the shallow DOF look, in both cases c-to-c sharpness is not critical.
The 17 does not seem to be designed to be sharp corner to corner at F1.8 either.  A lens like that will cost a lot more and be bigger and heavier.  I thus think that both of these lenses are designed to do more or less the same thing, so the first question you need to ask is whether you need the 15mm fl or the 17 mm fl.  The 15 will be slightly better, I think, in bokeh and color, plus the aperture ring, but you will pay more for those, plus the wider fl.
Neurad1
Re: When you look at all the "reviews" you see a pattern ...
Thanks. For the difference I saw in this comparison, I wouldn't spend the money. I own the MZ 17 1.8 and the Panny 14 already. Also the MZ 9-18.
jack Hoggard
jack Hoggard Contributing Member • Posts: 825
Don't forget that the aperture ring is only a decoration on an Olympus camera.
jaxupra
 jack Hoggard's gear list:jack Hoggard's gear list
Olympus Stylus 1 Sony Xperia Z Ultra Google Nexus 7 +1 more
jvt Regular Member • Posts: 194
Although these are fine, I'm still seeing better results from the original Panasonic 20/1.7...even though it is a slightly longer focal length.
Of course, someone will bring up that it's sooooo slow in the AF department.
Jim Tardio
BarnET Veteran Member • Posts: 3,581
Yup it's slow.
Still I love my 20mm
 BarnET's gear list:BarnET's gear list
Panasonic Lumix DMC-GX7 Fujifilm XF 18-55mm F2.8-4 R LM OIS
The 17/1.8 is my favorite lens. Just because it's overpriced is no reason to send it back if there's no better-valued alternative.
Bhima78 Senior Member • Posts: 2,850
Agreed... though I am keeping my new 15 even though, truly, both it and the Oly 17 are vastly overpriced.
 Bhima78's gear list:Bhima78's gear list
Panasonic Lumix DMC-GX8 Panasonic Lumix DMC-GX85 Panasonic G85 Panasonic Lumix G Vario 7-14mm F4 ASPH Panasonic Lumix G X Vario 35-100mm F2.8 OIS +12 more
