Took a day trip to Great Sand Dunes National Park yesterday. Four hour drive there, spent five hours there, and four hours back. Brought with me the E-M1 and E-PM2, with 11-22 f/2.8-3.5, m.Zuiko 40-150 f/4.0-5.6, and OM 50mm f/3.5 macro.
Full selection of photos here: http://www.photoklarno.com/piwigo/index.php?/category/28
Got to the top of the Star Dune, the tallest sand dune in North America (rising 750 feet over the valley floor, which is a greater prominence than some of Colorado's fourteeners and probably a more strenuous climb just because sand doesn't believe in traction). Then I did a no-no: After getting frustrated with the lens I needed most not having a viewfinder on it, I (gasp) swapped lenses between my cameras! Popular wisdom says not to do that if there's visible dust within a mile, and I did it in a lull between gusts of sand-filled wind. My sensors seem to be just fine.
I really wouldn't say no to a reasonably priced dust sealed telephoto zoom, however-- I'm still trying to blow grit out of my 40-150's zoom helical and I'm fresh out of duster. The 40-150 f/2.8 will probably be priced out of my range. The existing 40-150 is still, IMO, pretty much unbeatable for its light weight and great optics.
I could try to find a deal on the 50-200, but then I'd lose out on the light weight of the 40-150. I also ought to pick up either the 50mm f/2 macro or 60mm f/2.8 macro, as I got some unpleasant sounding sand in the helical of the 50mm f/3.5, and it would give me an intermediate lens to put in my landscape kit which usually omits a lens capable of close focus.
Some sand got under the wheel and Fn button of my E-PM2 but it worked itself out.
Toward the end of the day the light was so low and the winds were so high that it was difficult to get a sharp telephoto shot, even on my tripod (Markins Q10 + Manfrotto 055XPROB). Blocking the tripod from wind as much as I could with my body, as well as using touch shutter seemed to help some. Maybe next time I'll try removing the lens hood.
Because of the large size of the dunes in Great Sand Dunes, you'll generally be hiking along the dune crests, and that's generally better for telephoto compositions (and if you go into the valleys between them your calves will learn to hate you, because you almost always have to climb back up to get out). I haven't done telephoto in White Sands, but as the dunes are much more modestly sized there which makes low details more easily accessed, and makes wide angle lenses more useful (plus the gypsum sand at White Sands is water-soluble and very soft, so it's less of a problem when it gets into your everything).
And if you go here, bring lots of water. Generally in the desert you're to budget on a full gallon of water per day, per person. I went through about 2 liters in 5 hours and this was a relatively cool day.
Full, edited selection of photos here: http://www.photoklarno.com/piwigo/index.php?/category/28
Sony Alpha NEX-6
Olympus E-M1
Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R
Olympus 12-40mm F2.8 Pro
+9 more
Comment & critique:
