Loss of GPS in the NEW A77II
Started Jun 24, 2014 | Discussions
TroyMich
TroyMich Regular Member • Posts: 123
5
I own the A77 and do not see the need obviously to upgrade. I surely would not if I had to sacrifice GPS for Wifi. GPS is a great feature for travel. For them to forego GPS for Wifi is a mistake. For me, the A77 is more valuable than the A77II.
They just updated the Sony RX100II with the RX100III which also does not have GPS. Now, this is probably one of the best small travel point and shoots on the planet and for Sony not to add this feature is a miss!
What's up with Sony and GPS?
 TroyMich's gear list:TroyMich's gear list
Sony RX100 III Sony SLT-A77 Sony a99 II Sony 100mm F2.8 Macro Sigma 8-16mm F4.5-5.6 DC HSM +2 more
Sony RX100 Sony SLT-A77
headfirst
headfirst Contributing Member • Posts: 670
Re: Loss of GPS in the NEW A77II
There are parts of the world (like China, a major market) where GPS is not allowed. previously they had 2 SKUs with  the additional costs of that.
The A77 II battery life is already down on the original - what would it be with GPS enabled as well?
& that's before we've even discussed packaging, heat, cost etc.
 headfirst's gear list:headfirst's gear list
Konica Minolta Maxxum 7D Sony Alpha DSLR-A200 Sony Alpha DSLR-A700 Sony Alpha DSLR-A580 Sony SLT-A77 +8 more
sybersitizen Veteran Member • Posts: 9,683
Re: Loss of GPS in the (name any new camera from Sony)
Simple, sad answer: It has been eliminated from all their recent cameras. They assume your smartphone will be the answer to all your GPS (and other) needs. That or some still-unannounced-and-unavailable GPS device that costs extra and has to sit on top of the new hot shoe.
SteveJnerChicago Regular Member • Posts: 384
5
How does one not know nor remember where they took a photograph? I turned my battery draining GPS off on my A77 after one day.
 SteveJnerChicago's gear list:SteveJnerChicago's gear list
Sony SLT-A77 Sony a77 II Sony 70-400mm F4-5.6 G SSM Sony 300mm F2.8 G +5 more
rio911
rio911 Contributing Member • Posts: 973
I don't know about Sony, but for me I have the GPS in my A77 on all the time.
That being said, I still haven't found a proper use for the GPS data stored in my images.  I have done the gimmicks of looking at where some image has been taken, but it is nothing more than that, a gimmick.  The way I see it: it is a good thing to have, but it is not a "must", there is no added value behind it.
 rio911's gear list:rio911's gear list
Sony RX100 Sony SLT-A77 Sony 50mm F1.4 Sony 70-300mm F4.5-5.6 G SSM Sony DT 16-50mm F2.8 SSM
vw671 Contributing Member • Posts: 539
Never used the GPS in my A77....don't miss it in my A77ii.
 vw671's gear list:vw671's gear list
Sony RX100 Sony SLT-A57 Sony a77 II Tamron SP 70-300mm F/4-5.6 Di USD Sony DT 16-50mm F2.8 SSM +2 more
Jim Funston Senior Member • Posts: 1,698
Agreed.... never enabled GPS on any of my camera's...... Nor have I ever shot a video on a still camera either. If I want to shoot a video I'd buy a video camera.
J.R.M.
J.R.M. Contributing Member • Posts: 680
The only use for GPS is that others know where the picture was taken.
John
 J.R.M.'s gear list:J.R.M.'s gear list
FinePix S1 Canon EOS 40D Sony SLT-A65 Canon EF 50mm f/1.4 USM Sony 100mm F2.8 Macro +4 more
VirtualMirage
VirtualMirage Veteran Member • Posts: 3,956
I agree with this thought.  Sony previously had to have two different models and SKUs for all cameras that had GPS as an option.  For those countries that GPS was permitted, the GPS option was sold and for those where it was not permitted, the model without GPS was sold.
To reduce manufacturing costs, simplify production runs, and to make these other countries happy Sony decided to nix the built in GPS.  This probably also helps Sony's strategy in becoming profitable again too by following their ultimate goal of slimming down, reduce redundancy, and becoming more efficient.
They probably also saw it as not a huge loss or hit against them being that none of the competition have built in GPS (they rely on third party or external accessories).  I'd imagine Sony will be going that direction too.
 VirtualMirage's gear list:VirtualMirage's gear list
Sony RX100 Sony a77 II Tokina AT-X Pro 11-16mm f/2.8 DX Tamron SP AF 90mm F/2.8 Di Macro Tamron SP 70-200mm F/2.8 Di VC USD +18 more
K E Hoffman
K E Hoffman Senior Member • Posts: 5,102
In camera GPS convenient but incomplete
12
Camera GPS is a very lossy data system. You have the GPS, but it only encodes when an image is taken.
You are much better off GEOTAGGING with a device that captures the entire story. So when you open the log file in an application like Lightroom.. you get your path.. you can see how you got from point a to point b etc.    I have an A77.. with an GPS.. it was a check box feature.. I would rather Sony spend money on a better LCD, better focus, sensor improvements vs. tooling and inventory management of two versions of a camera.
I wrote this in another thread...
Use your Phone free apps galore.
There are a ton of free phone apps. (that will work on an used phone that is not even set up with a plan) they create a .GPX log that will track where you were. As long as you sync your phone and camera clock. It auto tags the photos and since it is logging all the time... you actually get path on the map of where you were which a camera GPS won't do.
Don't have smartphone.. don't want to run the battery down?
This ties voice notes to location..
http://www.amazon.com/Columbus-Bluetooth-Driverless-waypoints-Compatible/dp/B001JJRBU8/ref=sr_1_12?ie=UTF8&qid=1403375266&sr=8-12&keywords=gps+logger
Sony has not yet added a note taking feature like some camera have which would be useful.  This  + camera could be the perfect solution.  Geotagged images and voice notes.. like names etc.
cheaper tools
http://www.amazon.com/i-gotU-GT-120-Chipset-Software-Included/dp/B001IMJV0E/ref=sr_1_9?ie=UTF8&qid=1403375266&sr=8-9&keywords=gps+logger
http://www.amazon.com/Canmore-GT-730FL-S-Rechargeable-Waypoints-Compatible/dp/B002UWKUZQ/ref=sr_1_7?ie=UTF8&qid=1403375266&sr=8-7&keywords=gps+logger
How to use the log file
If you use Lightroom you can add tags to your images in the DB with included functions.
http://tv.adobe.com/watch/creative-suite-podcast-photographers/how-to-use-gpx-logs-to-geotag-your-photos-with-lightroom-4/
If you want the RAW tagged.. before Lightroom or other tool...
Free apps.
http://www.geotagphotos.net/user-guide#toc-supported-image-formats
http://www.dslrsoftware.com/gps_embedder.php
K.E.H. >> Shooting between raindrops in WA<<
Don't Panic!.. these are just opinions... go take some pictures..
 K E Hoffman's gear list:K E Hoffman's gear list
Canon EOS 450D Nikon 1 J1 Sony a6500 Sony E 18-200mm F3.5-6.3 OSS Sony E 50mm F1.8 OSS +3 more
Keith Hanlan
Keith Hanlan Regular Member • Posts: 384
Re: In camera GPS convenient but incomplete
That's a great collection of links. I've bookmarked your post. Thank you.
 Keith Hanlan's gear list:Keith Hanlan's gear list
Konica Minolta Maxxum 7D Sony Alpha DSLR-A580 Sony a77 II Tamron SP AF 10-24mm F/3.5-4.5 Di II LD Aspherical (IF) Tamron SP AF 90mm F/2.8 Di Macro +10 more
Lensmate
Lensmate Senior Member • Posts: 2,239
I've never ever had the need for GPS.....drain on the system. Good riddance....
Never used the movie feature either.....would like to see that gone and other features added that are more related to photography. [I have a camcorder, don't need extra...]
The Sony A77m2 took away the remote feature that was on the A77 and I miss that a lot........even though I have the cable trigger, I found the wireless remote more useful.
C'est la vie...
PS useful links and help there Ken~
Martin P
https://www.flickr.com/photos/photosauraus_rex/
K E Hoffman
C'est la vie...
Martin P
Wireless trigger for wired cable..
http://www.amazon.com/Wireless-Shutter-Receiver-S1R-Fancierstudio/dp/B004HR2W4E/ref=sr_1_15?ie=UTF8&qid=1403667586&sr=8-15&keywords=sony+wireless+trigger+shutter+Minolta
I didn't use the remote much.. but that is a shame.  I guess I need to take that tablet with me for detailed control of the system.
eddiewood Contributing Member • Posts: 626
C'est la vie...
Martin P
"The Sony A77m2 took away the remote feature that was on the A77"
Are you sure?
 eddiewood's gear list:eddiewood's gear list
Sony a77 II
MikeNannie
MikeNannie Regular Member • Posts: 446
C'est la vie...
Martin P
Are you sure?
The remote control option is still there. It's on the setup menu, screen 3. I just looked at my camera. If I remember correctly, on my a580, it was on the drive menu, so maybe that is what is causing the confusion?
You can also use a wifi connection and your phone. My testing around the house however seemed to indicate a relatively short range. You have to use the Sony My Memories app on your phone for connectivity. Not sure if any other apps work, but it doubt it, it's probably a proprietary connection protocol.
 MikeNannie's gear list:MikeNannie's gear list
Sony a77 II Sony DT 16-80mm F3.5-4.5 ZA Carl Zeiss Vario-Sonnar T* Sony DT 35mm F1.8 SAM Tamron SP 70-300mm F/4-5.6 Di USD Sony DT 16-50mm F2.8 SSM
You had to go and spoil it!
Sony a77 II
MikeNannie
Sorry
Had me worried so I had to go check. I like that feature.
nandbytes Senior Member • Posts: 5,966
SLT (and mirrorless especially) already have less battery life than a traditional DSLR. So if I am on travel and need to conserve battery guess what gets turned off first. the GPS...
Focus on what you have, not on what you don't.
https://www.flickr.com/photos/nandbytes/
 nandbytes's gear list:nandbytes's gear list
Panasonic LX100 Sony Alpha a7 Sony Alpha a7R II Canon EF 100-300mm f/4.5-5.6 USM Sony E 16-50mm F3.5-5.6 PZ OSS +3 more
tbcass
tbcass Forum Pro • Posts: 35,696
Probably due to cost and the fact that few people actually use the feature. I keep it turned off to extend battery life. Unfortunately it's one of those features where a small number of people get screwed because the market place doesn't want it.
Tom
Look at the picture, not the pixels
Misuse of the ability to do 100% pixel peeping is the bane of digital photography because it causes people to fret over inconsequential issues.
http://www.flickr.com/photos/63683676@N07/
http://www.flickr.com/photos/25301400@N00/
 tbcass's gear list:tbcass's gear list
Sony RX100 Tamron SP AF 90mm F/2.8 Di Macro Sony DT 35mm F1.8 SAM Tamron SP 70-300mm F/4-5.6 Di USD Sony RX10 III +10 more
Claudio Galli Contributing Member • Posts: 562
I think you are right
As it happens to me to travel around the world for tourism, the first thing I do when I buy a camera is to buy two additional batteries. Having the GPS on all day long has never been a problem. Why nobody suggests the simple solution of an additional battery? By the way, even with the GPS on, many times I arrive at the end of the day without the need to change the battery.
Unfortunately I am one of those! So for my RX100II I use the iPhone with gps4cam app.
Anyhow, thanks Tom for your always interesting comments on these forums, I rarely miss one!
Claudio
Tom
 Claudio Galli's gear list:Claudio Galli's gear list
Sony RX100 II Panasonic FZ1000 Olympus Tough TG-4 Olympus OM-D E-M5 Olympus E-M5 II +3 more
