Can't get all the dust off my UV filter
Started Jun 24, 2014 | Questions
Nezhin Forum Member • Posts: 91
I tried blowing on it, brushing it, and of course cleaning it with a lens cleaning fluid and a microfiber rug. The dust is still there, on this shot it is highlighted with a light source placed at an oblique angle.
I am worried that this dust might cause veiling flare. Is there a way to get rid of it? Or perhaps it doesn't matter that much?
lambert4
lambert4 Senior Member • Posts: 2,313
Re: Can't get all the dust off my UV filter
Looks more loke lint from your cleaning rag.  try a different cloth, and I like a  white distilled vinegar  to remove water spots from my filters just a drop rubbed around with the same cloth, and then dried.
Here's to learning something new everyday, and remembering it the next.
 lambert4's gear list:lambert4's gear list
Nikon D500 Sigma 10-20mm F3.5 EX DC HSM Nikon AF-S Nikkor 70-200mm f/4G ED VR Tamron SP 150-600mm F/5-6.3 Di VC USD Nikon 35mm F1.8G ED +3 more
Skeeterbytes Forum Pro • Posts: 13,995
This might be what is occurring. If your tap water isn't too hard (high mineral content) perhaps wash it with a little mild dish detergent, rinse it and dry it with a very clean, hopefully lint-free cloth, or lens tissue. That's what I do with stubborn dirt and smudges.
Have had filters delaminate, giving a pattern somewhat similar to this, but it's easy enough to see surface debris by looking at the reflection on the glass.
Rick
"Whiskey is for drinking, digicams are for fighting over."
—Mark Twain
OP Nezhin Forum Member • Posts: 91
Yes, I think this could be it. I'll get a new rag tomorrow, and I'll keep your vinegar tip in mind. Thanks!
Paulmorgan Veteran Member • Posts: 7,427
Something else that works well are those disposable spectacle wipes.
Michael L NYC 99
Michael L NYC 99 Veteran Member • Posts: 5,206
I use these wipes for my lenses.
http://www.amazon.com/Zeiss-Pre-Moistened-Lens-Cloths-Wipes/dp/B0030E4UIQ/ref=sr_1_1?ie=UTF8&qid=1403633598&sr=8-1&keywords=zeiss+lens+wipe
They dry in a few seconds, so there's no need to use a cloth afterwards. They're inexpensive as well.
Regards
Michael
See my Flickr photostream here Michael.Lee.Pics.NYC
 Michael L NYC 99's gear list:Michael L NYC 99's gear list
Olympus E-M5 II Sony Alpha a7R II Nikon AF Nikkor 85mm f/1.8D Panasonic Leica D Summilux Asph 25mm F1.4 Panasonic Lumix G Vario 100-300mm F4-5.6 OIS +15 more
Rick
This stuff seems to be moving around, so it's definitely not delamination. Thanks for another tip, I'll have to get a new microfiber cloth in the morning, and find out if this lint decides to be stubborn about staying or not.
jalywol
jalywol Veteran Member • Posts: 9,425
Regards
Michael
I use these also, they work great (my local WalMart has them in their optical department).
-J
ron_9
ron_9 Veteran Member • Posts: 3,714
that isn't dust but I'm gonna take a guess and say tree pollen which can be very sticky.  Using wipes and/or/plus a good screen cleaner should take care of it---also get several micro cloths to use.--Aren't ya glad you got it on the filter and not the lens     ----------ron s.
Keeping it sane in an insane world is an inconvenience at an inconvenient time!!
www.pbase.com/ron9ron
Chas2 Veteran Member • Posts: 3,524
for all optical cleaning, I use these.  I can get them from my local optometrist, also use them in the lab.
http://www.amazon.com/KIMWIPE-SM-280-PK/dp/B001D8XLKE
 Chas2's gear list:Chas2's gear list
Panasonic Lumix DMC-GM1 Panasonic Lumix DMC-GX7 Panasonic G85 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Panasonic Lumix G 20mm F1.7 ASPH +12 more
PSCL1 Veteran Member • Posts: 3,770
To the OP:  If none of the above suggestions work, just buy a new filter.
 PSCL1's gear list:PSCL1's gear list
Leica X1 Nikon D80 Olympus PEN E-PL1 Panasonic Lumix DMC-G3 Sony Alpha NEX-3N +27 more
Solved -- Re: Can't get all the dust off my UV filter
Rick
A few dust particles remain, but I don't think they dispurse enough light to create a noticable flare.
I bought some single-use lens cleaning fiber paper from an optitian (thanks Paulmorgan for the idea), and cleaned the filter in the usual manner, by spraying it with a lens cleaning fluid first, and cleaning/drying it with the microfiber paper. I also put the filter under running tap water for a few seconds, just for good measure (before the previous step).
So it was it was loke lint, as ambert4 suggested. I bought the previous cloth in a reputable store, so this is a bit weird. I guess I'm now blacklisting the brand. Thanks for the help!
Re: Solved -- Re: Can't get all the dust off my UV filter
Success!
Thanks for following up. We all learned a little, I think.
Rick
—Mark Twain
Macintosh Sauce
Macintosh Sauce Contributing Member • Posts: 706
Sergey_Green
Sergey_Green Forum Pro • Posts: 11,391
You will not see it in your images.
So I would not bother too much. Wash it, wipe it off with silky cloth, and be done with it. What is there, will be there.
- sergey
