Are you using original lens hoods?
Started Jun 21, 2014 | Questions
61094125 Forum Member • Posts: 92
Hi,
are you using original lens hoods or alternative ones? I'm thinking if getting one for my 50/1,4 and want to know, if the original one is better, or if you are paying only the Canon brand.
Zdenek Luzny
 61094125's gear list:61094125's gear list
Canon EOS R6 Canon EF 70-200mm F4L IS USM Canon EF 24-70mm F2.8L II USM Canon EF 16-35mm F4L IS USM Irix 11mm F4 +1 more
Darren N Regular Member • Posts: 345
Re: Are you using original lens hoods?
Hi
all my canon L lenses I use canon hoods only because they come with the lens but my 50.mm f1.8 / 18-55is & 55-250is all have cheap 3rd party hoods & I have no problem with them.
Darren
tonyjr
tonyjr Veteran Member • Posts: 5,295
I use after market [ cheap ebay ] ones in field .
Canon hoods have fuzzy stuff that collects dust and seeds and I lost a few in brush - you don't know till ready ro take shot and no hood .
The cheap ones break , don't fit as well / tight - warp easier and sometimes are a different color .
 tonyjr's gear list:tonyjr's gear list
Canon EOS 400D Canon EOS 7D Canon EF 35mm F2.0 Canon EF-S 10-22mm F3.5-4.5 USM Canon EF-S 17-55mm f/2.8 IS USM +14 more
Jonathan Brady
Jonathan Brady Veteran Member • Posts: 6,725
I've had 1 third party lens and 3 Canon (OEM) hoods. The fog of the OEM hoods is better, the 3rd party wasn't bad, but it wasn't quite as precise. Also, Canon hoods have a felt lining which will absorb additional stray light.
My experience with 3rd party hoods is limited and while I see nothing wrong with them as an option (especially for the $ difference), I prefer the OEM hoods for their flawless fit and felt lining. In fact, just yesterday I ordered the OEM hood for my wife's 50/1.4.
QUOTE: "Another conclusion: After having read a few hundred instances of “fanboy” references during research for this article, it’s clear to me that the word has lost whatever potency it might once have had as an insult. It’s too much of a cliché, too inappropriately dismissive, too likely to be tossed in as an ad hominem attack by someone who shows signs of extreme fanboyism himself."
In other words - takes one to know one. And you lack creativity.
http://gizmodo.com/5540818/the-fascinating-origin-of-the-word-fanboy
rebel99 Veteran Member • Posts: 4,025
the only original hood i don't use is the canon 17-40 f4.0, i use the 24-105 f4.0 hood on it and it works quite alright but no after market hoods.
cheerz.
FJG3
FJG3 Senior Member • Posts: 1,034
Only if the lens comes with a hood, otherwise I've had good luck with cheap ones. I can't see spending $25+ for one from Canon when I can get one for $5 and it fits fine. Confucius says "shade is shade".
 FJG3's gear list:FJG3's gear list
Sony RX100 III Sony a7 II Panasonic Lumix DMC-G7 Sony a6300 Sony E 10-18mm F4 OSS +17 more
photofanzM Regular Member • Posts: 104
i've been using the Rubber collapseable Lens Hoods on my Lens for several years, They work as well as the Plastic or Metal Lens Hoods and take up less space in a Camera Bag. They are easy to clean also  The inexpensive Generic Brand appear to be well made and do the job.
 photofanzM's gear list:photofanzM's gear list
Canon PowerShot A590 IS Canon PowerShot SX10 IS Fujifilm FinePix 3800 Olympus C-5050 Zoom Canon PowerShot G11 +12 more
Thomas Kachadurian
Thomas Kachadurian Veteran Member • Posts: 3,733
Different for all my lenses.
Canon:
24f2.8IS and 35f2IS I use canon clones from amazon.
24-105f4 I use the hood from a version 1 24f1.4L. It's narrower than the new one.
70-200f4 screw in straight tele hood, plastic. Again much narrower Than the huge canon version.
100macroL canon hood it comes with.
Sigma 50f1.4 last version. Screw in metal hood again because it's both deeper and narrower than the hood it came with.
Canon hoods are nothing to write home about.
Tom
www.kachadurian.com
Call me crazy. I happen to like photos of cats.
 Thomas Kachadurian's gear list:Thomas Kachadurian's gear list
Panasonic Lumix DMC-GX8 Panasonic Lumix DC-G9 Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS Panasonic Lumix G 20mm F1.7 ASPH Panasonic Leica Summilux DG 25mm F1.4 +7 more
GordonAtWork
GordonAtWork Regular Member • Posts: 482
The only hood I have which isn't a Canon one is for the 50mm f1.4. I did have one which screwed into the filter thread but since the 50 is famed for its fragility, if it got a knock then the lens barrel would take the force and no doubt break the af drive.
I got a third party one from China which is a proper bayonet fit and that protects the lens properly and does a good job of shading the lens too. Overall, I'm happy with my choice and it's made of a very similar quality/feel plastic as the Canon ones I own.
Signature ? You can't handle my signature !!
 GordonAtWork's gear list:GordonAtWork's gear list
Canon EOS-1Ds Mark II Canon EOS D60 Canon EF 20mm f/2.8 USM Canon EF 50mm F1.4 USM Canon EF 400mm f/5.6L USM +9 more
msowsun
msowsun Contributing Member • Posts: 740
I have tried a few 3rd party hoods but now only use Canon. Here is why I don't like 3rd party hoods...
1) they don't fit as well (sometimes too tight, sometimes too loose)
2) they are made from cheaper, thinner plastic
3) they don't look as nice (unpainted black plastic)
4) they almost never have interior "flocking" or "fuzz"
 msowsun's gear list:msowsun's gear list
Canon PowerShot S110 Canon EOS D30 Canon EOS 5D Mark III Canon EOS Rebel SL1 Canon EOS 80D +27 more
tr573 Senior Member • Posts: 1,329
I use these too - I just got a few in the sizes I use for filters (that I have step up rings for) and use them.  2 hoods > a dozen different ones
hotdog321
hotdog321 Forum Pro • Posts: 21,141
61094125 wrote:
Hi,
I've tried aftermarket lens hoods and always return to Canon's--even though they are overpriced which annoys the heck out of me. They are designed for specific lenses so they fit perfectly and provide maximum protection from impact and lens flare.
Some use black flocking which can pick up dust over time that needs to be periodically removed (I use Scotch Tape). But that black flocking is wonderful for killing extraneous reflections inside the hood to provide clean images.
 hotdog321's gear list:hotdog321's gear list
Canon EOS 5D Mark IV Canon EF 100mm f/2.8 Macro USM Canon EF 70-200mm F2.8L IS II USM Canon EF 24-70mm F2.8L II USM Canon EF 16-35mm F4L IS USM +3 more
tonyjr
I have had the rubber hoods with both the plastic and metal mounting rings get stuck .
I only use them on my CPL's .
