E-P5 shutter shock ...
Started Jun 21, 2014 | Discussions
Anders W
Anders W Forum Pro • Posts: 22,144
Re: Analysis paralysis ..
Sergey_Green wrote:
Anders W wrote:
Saying it is within acceptable levels is not the same as saying that you don't have it (at all). Based on my own testing with my E-M5 and various lenses, I'd say it is within acceptable levels with some of them (7.5/3.5 FE, 12/2, 20/1.7, 45/1.8, 7-14/4, and 14-45/3.5-5.6 if I use OIS rather than IBIS) but unacceptable with others (75/1.8, 40-150/4-5.6, 100-300/4-5.6). I don't know of anyone here among those who have actually tried to test for this in a systematic manner who would claim that the problem is always of such a magnitude as to be easily visible and disturbing.
Time wasted on tests and measurements is time not spent learning useful aspects of photography.
Time used to determine what shutter speeds work with what lenses is not wasted but well spent to learn a useful aspect of photography.
Whether he has it or not, is up to him to decide.
Did I say anything to the contrary?
Panasonic Lumix DMC-G1 Olympus PEN-F Olympus E-M1 II Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS Panasonic Lumix G Vario 7-14mm F4 ASPH +20 more
Anders W
Re: E-P5 shutter shock ...
ABCMO wrote:
Anders W wrote:
NCV wrote:
tt321 wrote:
NCV wrote:
It would be nice to see some of the photographs that have this problem to help others form perhaps a more balanced opinion.
I wonder in the general case when we encounter problems like this with our cameras and lenses whether it would not be better to have the camera checked out by a technician before posting on the web. In a certain sense we are accusing the manufacturer of putting on the market a defective product with all that implies, which is then possibly read by many prospective buyers of these goods.
It's exceedingly difficult, for most of the public, to have anything checked by a technician. Many, if not most, of the people even buy equipment without having talked to the seller face to face.
The very first batch of such discussions were originally started by people who did check with the manufacturers, or the manufacturers' contracted service providers and essentially got bland 'within spec' verdicts without any more detail. That motivated them to go online and check with other users whether there was a pattern. That got more people to scrutinize their own gear and got some testing sites to test for this kind of thing - this kind of thing being sharpness not related to shutter speeds in a monotonic manner. At some point increasing the shutter speed causes sharpness to decrease.
Following on from above I am surprised the Olympus and Panasonic and the others do not have somebody to cast their eye over what is written on some of the major Forums and Blogs now and again.
What makes you think they don't? Canon developed the electronic first curtain, not for nothing. Sony picked it up to use in their NEX line, again not for nothing. Panasonic found an elegant solution in the fully electronic shutter which could be marketed for silent operation purposes and help avoid any admission of shutter shock. In contrast, the electronic first curtain has a single purpose and is tantamount to admitting that your previously sold lots of stuff with shutter chock embedded, or for this particular camera implemented a shutter with such a problem. Olympus first said they did not see an issue, but left the door open by saying they would certainly investigate, then followed up with the 0 setting, which cures the problem for most people. Now even Nikon is adding electronic first curtain to the D810.
The last development is interesting because that makes Sony's assertions that the 36MP sensor in the A7R makes it not practical to do an electronic first curtain shutter arrangement. Well Nikon has done it and so probably soon Sony could too. And then non-m43 mirrorless would be strengthened and m43 needs to respond.
It is true that the vibration caused by the focal plane shutter in every camera with this type of shutter summed together with the optical limitations of our lenses causes image degradation .This fact is as old as photography and we just have to live with it. It is also possible that a camera also has a design fault.
With the electronic first curtain and full electronic shutter options as readily available solutions, not including them is a design fault from the shutter shock point of view. But it may not be a design fault from the point of view of how much you are going to get charged for licensing the tech, and how much effort you need to include it on a particular model at the point of its introduction. Olympus' adding such a feature using firmware is an excellent example of a manufacturer doing more for its customers at no additional cost or the virtual blackmail situation of requiring them to buy a new model.
Some of the replies above strongly criticize a camera that I happen to own (EM5) and which has produced pictures free of shutter shake to a degree that has rendered them unusable for printing to a large size.
This came out of people who have noticed the problem. If you don't have this problem, why worry? The only 'problem', as it were, would be if this affects the resale value.
All very valid and true points.
You are right I come from a time when in a town of 100.000 we had two camera repair shops. In this case things have changed for the worse. But still, if I saw that of my EM5's was giving me un-sharp pictures in certain circumstances then I would send it off to Olympus for a service by courier.
Exactly how did you test for the possibility that your E-M5 shows signs of shutter shock? And if you didn't test systematically, how do you know that it doesn't?
If it came back with the same problem then I would sell it quietly and move on to something else.
Why remain quiet about it? If nobody complains, then cures of the kind now offered would most likely have remained unavailable.
I believe the drawback to the electronic shutter is this:
Correct me if I am wrong.
You are right.
I worry because these posts remove the confidence one may have in ones equipment.
I had a Nikon D70 back in the mists of time and every other Nikon forum post talked about the “green light of death” that these cameras suffered from. In my subconscious I was always expecting my camera to die at any moment. It never happened. This fine little camera travelled all round Europe and even got crammed into my briefcase for a work assignment in Mexico. I sold it and as far as I know it may still be helping someone enjoy photography.
I sometimes wonder if some of these scares are started by competitors. I believe there is even a name for this type of marketing.
So I reply when I have got time to kill remembering the Nikon D70 incident.
I don't know what the "green light of death" was really about. But I don't think the proper solution to problems of the type you mention is to keep quiet.
The "green light of death" was actually known as the "Blinking Green Light of Death," which produced the acronym BGLOD. It was called this because a small green light on the back of the Nikon D70 would start blinking unexpectedly, and when this happened, the camera would be locked. A temporary solution was to turn off the camera, remove the battery, wait a short time, reinsert the battery, and turn the camera back on. I don't remember the exact technical problem that produced this, but as the problem was discussed on the appropriate dpreview Nikon forum, it became clear that the problem was largely, but perhaps not exclusively, confined to D70's purchased during the first 2-3 months it was on the market. In my case I had purchased my D70 during the first week it was on the market, so mine was definitely in the danger zone. Indeed, I remember that back in either 2006 or 2007, I was reading about BGLOD on one of the Nikon forums, picked up my D70, switched it on, and for the first time the green light on the back of the camera started blinking! Yes, I had passed over into the Twilight Zone.:-) The next day I took the camera to my local camera store where I had purchased it, and they sent it to Nikon for repair. After I got it back, it never displayed that problem again. To Nikon's credit and if my memory is correct, they repaired D70's with this problem at no charge, even if the warranty had expired. Part of the problem with this malfunction was that the problem usually wouldn't start to happen until several months of camera use had passed.
It's been seven or eight years since BGLOD reared it's ugly face in the Nikon world, so I thought a little history might be of interest.
Thanks for chiming in with the full story on this. Sounds like BGLOD was an easier problem to fix than shutter shock after all.
Anders W
rz350 wrote:
I had always wanted a higher spec m4/3 camera. I was extemely pleased with my PM-1 and GF3 other than focusing my 100-300 lens. So when I got my EP-5 and the VF-4, the first thing I tried was focusing with the 100-300 and it worked because of the smaller focusing window. I went downtown and tried my 9-18 and had it set to P to let it do it's own thing exposure wise. That was when I personally discovered SS. At 1/320 and the 9-18 lens it was simple to induce.
One of the concepts at the time was that it was the fault of the IBIS. We now know that it is the first curtain bounce. I compared photos with my GF3 and EP-5 taken at the same settings of the same subject and no SS on the GF3 and SS with the EP-5.
Yes, but that does not demonstrate that IBIS is actually to blame. See for example here:
http://www.dpreview.com/forums/thread/3247661
It just means that your GF3 has less SS than your E-P5, which may be the case for many different reasons.
What this does is destroy the confidence that you have using a camera. In the back of your mind, you are never quite sure. Plus over time I have discovered that it does not focus as well as I would like with the 100-300. Sometimes it surprises me but less often than I would hope.
I certainly do not dispute that there are problems like these. But in my experience, there is no such thing as a camera completely without shortcomings, including unreliabilities of the kind you encounter. My solution in cases like these is to investigate a bit to try to pinpoint when the problem occurs and find a work-around.
The exposure accuracy that it gives me is one area where it is superlative. Having had Canons and a Nikon, their exposures have to be tweaked. Also the high ISO capabilities are superb. But there is the niggling thought in the back of my mind, is it going to be sharp? At 1/320 0r 1/60 or even 1/30 it should be, but will it be?
(unknown member) Veteran Member • Posts: 3,010
Time wasted on tests and measurements is time not spent learning useful aspects of photography. Whether he has it or not, is up to him to decide.
Speaking for myself learned a lit about my camera operation by testing. I hope this leads to better photos. It wasn't a waste of time for me.
http://www.flickr.com/photos/90891174@N04/
