28-105 vs new 55-250
Started Jun 16, 2014 | Discussions
JavaM New Member • Posts: 3
Hi folks,
I have an 28-105mm 3.5 - 4.5 USM lens. I am thinking of replacing this lens with a 55 - 250mm 4-5.6 IS STM. Is it worth the upgrade. 2 Big difference I notice is, one I have is EF EOS. The lens i am considering is EF-S EOS. So cant use it on my film body.
The new lens is one stop slower.
But lens seem to be better in terms of sharpness.
Can anybody who has used both lenses chime in?
Java.
 JavaM's gear list:JavaM's gear list
Canon EOS 40D Canon EF 50mm F1.8 II Canon EF 28-105mm f/3.5-4.5 II USM Sigma 150-500mm F5-6.3 DG OS HSM
brian1366 Contributing Member • Posts: 514
Re: 28-105 vs new 55-250
Interesting upgrade as the focal lengths are different.   I could never live with the 55-250mm as my main lens. I would need something wider.
 brian1366's gear list:brian1366's gear list
Canon PowerShot S110 Canon EOS 600D Canon EOS 70D Canon EF 50mm F1.8 II Canon EF-S 15-85mm f/3.5-5.6 IS USM +5 more
jitteringjr Veteran Member • Posts: 3,608
Actually the 55-250 STM is not really that much slower.  The 28-105 doesn't even offer the focal lengths where the 55-250 is limited to 5.6.  It's not any more than a 1/3rd stop slower at any focal length and it's equal most of the time.  Still I would want a 18-55 STM to use with the 55-250.
 jitteringjr's gear list:jitteringjr's gear list
Canon EOS 7D Canon EF 50mm F1.4 USM Canon EF 50mm F1.8 II Canon EF 85mm F1.8 USM Canon EF 135mm F2L USM +9 more
OP JavaM New Member • Posts: 3
Yes and no. On a full frame camera, it is true they are different. But I have APS-C camera. so 1.6 multiple. When you convert, 28-105, it becomes 45-168. So, 55-250 is not that far off.
OctaneZ
OctaneZ Forum Member • Posts: 68
Well yes on the 28-105...
but the 55-250 has the same field of view as an effective 88-400.
 OctaneZ's gear list:OctaneZ's gear list
Canon PowerShot G11 Canon EOS 60D Canon EF 50mm F1.4 USM Canon EF 100-400mm f/4.5-5.6L IS USM Tokina AT-X Pro 11-16mm f/2.8 DX +9 more
msowsun
msowsun Contributing Member • Posts: 740
If you want to apply the 1.6 crop factor to the 28-105, you also need to apply it to the 55-250. It does not matter whether or not the lens is EF or EF-S. The focal length is always the true focal length of the actual lens.
With the crop factor, you would be comparing a 45-168 to a 88-400. That is a very big difference in focal lengths!
 msowsun's gear list:msowsun's gear list
Canon PowerShot S110 Canon EOS D30 Canon EOS 5D Mark III Canon EOS Rebel SL1 Canon EOS 80D +27 more
Thanks for the explanation. I did learn something new today. Guess i need to go hunting for different lens.
Looks like EF-S lenses are better in terms of sharpness.
Mark B.
Mark B. Forum Pro • Posts: 29,756
JavaM wrote:
Hi folks,
Java.
The 28-105 is an old design.  I had it with my EOS A2, but it had noticeable softness on my digital SLR bodies.  I dumped it a long time ago.
That said, however, the 55-250 has a different range than the 28-105, though it will be far better.  You
should look for something to cover the wide end as well.
Mark
msowsun
A Canon EF-S 18-135 STM is a fantastic lens.  So is the 18-55 STM or 55-250 STM.
In addition to the benefits of STM Auto-focus, the STM lenses are sharper and also have non-rotation front elements. I highly recommend them.
Jon_T
Jon_T Veteran Member • Posts: 6,407
I agree with msowsun's EF-S 18-135 IS STM recommendation.
Seeing that you have the Sigma 150-500 OS HSM, the 18-135 IS STM (35mm angle of view equivalent to a 28.8-216mm) would be a good replacement for your 28-105.
Based upon several reviews I've seen the 18-135 IS STM overall IQ is close to the EF-S 15-85 IS:
http://www.the-digital-picture.com/Reviews/ISO-12233-Sample-Crops.aspx?Lens=809&Camera=736&Sample=0&FLI=0&API=0&LensComp=675&CameraComp=0&FLIComp=0&APIComp=0
http://www.dpreview.com/reviews/lens-compare-fullscreen?compare=true&lensId=canon_18-135_3p5-5p6_is_stm&cameraId=canon_eos7d&version=0&fl=18&av=3.5&view=mtf-ca&lensId2=canon_15-85_3p5-5p6_is&cameraId2=canon_eos7d&version2=0&fl2=15&av2=3.5
You can get a Canon Refurbished 18-135 IS STM for $439.99 with a 1 year warranty:
http://shop.usa.canon.com/shop/en/catalog/lenses-flashes/refurbished-lenses/ef-s-18-135mm-f-35-56-is-stm-refurbished
Later on you could get the new EF-S 10-18 IS STM, and with the three lenses you would have an angle of view equivalent 16-800mm. The EF-S 10-18 IS STM has the same 67mm filter size as the EF-S 18-135 IS STM.
I suspected you might be thinking that a EF-S lens already has the crop factor applied to focal length. No worries. That is a common misconception.
